07-18-2008, 06:31 PM | #1 |
Member#: 135252
Vehicle:2002 WRX Wagon |
Herky Jerkiness
From 1000-3500 rpms the car is VERY jerky to the point it looks like I can't drive. What could be a possible cause that I can start checking? Fuel filter changed 20k miles ago, plus changed and gapped 15k miles ago, problem started roughly 10k miles ago.
Running XPT Extreme Stg 2 GM BCS map (the one you pay for). Also have a non-firing condition: http://forums.nasioc.com/forums/show....php?t=1559402
07-18-2008, 06:35 PM | #2 |
Member#: 143522
SWIC
Vehicle:1987 Brat GL 4 Speed 98 Forester L (RIP) |
I kinda have the same problem sometimes where it feels like the clutch is grabbing and slippin and then grabbing during 1k rpm to about 2.5k rpm.
i think its cuz i have a stock clutch and flywheel and need it replaced....so it could be a clutch slip if you know what it feels like, unless your talking like the engine is the problem and not a transmission feel like i have. |
07-18-2008, 08:29 PM | #3 | |
Member#: 135252
It does it really bad in 1st gear, less bad in 2nd gear, and hardly in 3rd gear, but ALWAYS at that RPM. |
07-18-2008, 08:39 PM | #4 |
Member#: 140163
Vehicle:03 STi hellaflunctional |
it sounds like you might have a pre-turbo intake leak.
have you tried using the maf tool? or logging a/f learning and a/f correction? |
07-18-2008, 08:46 PM | #5 |
Member#: 135252
Similar Threads | ||||
Is this kinda jerky, or really jerky, or not jerky at all? | Sharkbait | Off-Topic | 51 | 11-11-2008 04:30 PM |
Rough idle, herky-jerky take-off | poison | Normally Aspirated Powertrain | 18 | 08-08-2008 12:24 AM |
Herky Jerkiness | Superorb | Service & Maintenance | 6 | 07-21-2008 06:39 PM |
new txs firmware to cure crossover herky jerk? | TexRex2002 | Engine Management & Tuning | 3 | 10-13-2005 03:08 PM |
Herky jerky acceleration with unichip? | Fubaru | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 38 | 01-20-2002 03:29 PM |
