10-05-2012, 08:49 AM | #1 |
Member#: 296602
Vehicle:2012 WRX Limited Satin White Pearl |
What do you think the weak parts are on the 2012 WRX?
Just curious from peoples opinion: What do you think the weak points are on the 2012 WRX? Such as the tranny mounts... Or transmissions... Or suspensions...etc? What do you feel are the weak points of the vehicle.
10-05-2012, 08:56 AM | #2 |
Member#: 70151
Vehicle:2011 WRX Limited Black |
Not to be a jerk, but this exact same question was asked and answered 2 weeks ago. Please do a search and you'll find your info. Also The stickies at the top of this forum and the newbie section contain a lot of this information as well.
Search is your friend here, it'll help you avoid a lot of nasty flame posties. |
10-05-2012, 08:59 AM | #3 | |
Member#: 332887
Vehicle:2012 WRX stage 2+ DGM (sedan) |
1) throttle body to TMIC hose - the rubber gaskets and worm clamps are to blame for this mainly 2) Shifter bushings - they're squishy as hell 3) The ECU map itself - a TP stage 1 map is safer, gives a bit of power, and can add more mpg Once you start going stage 2 or higher: 1) Engine mounts - your engine will look like it wants to jump out from under the hood without them 2) Tranny mount - you may hear your tranny knocking about when shifting at higher RPMs 3) Transmission - look up "glass tranny" and you'll see what I mean 4) Pitch stop - yet another part that holds the engine in place 5) Tires, suspension, etc etc... |
10-05-2012, 09:01 AM | #4 | |
Member#: 296602
But, I didn't know this exact question was already asked, so if that's so; my apologies. |
10-05-2012, 09:10 AM | #5 | |
Member#: 169539
Vehicle:2004 WRX sedan JBP 2013 BRZ GBS, 2000 2.5RS |
For instance: If the engine looks like it's going to jump out of the bay, maybe someone could take a video of this before and after upgrading the engine mounts and pitch stops so we can see what you are talking about, and see if it's not an exaggeration. Also, perhaps some data showing exactly why the stock tune is "bad" and an aftermarket tune is better. This could really be a good selling tool for tuners also, if there is truth behind it. Assembling information like this in a way that it doesn't sound like an opinion could benefit everyone, although it is more work than simply saying that "so-and-so heard from his friend that his tuner said that this is bad and you need to buy this part, oh and here we have them on sale right behind you..." ...which I think is often the case. This can lead people to be even more doubtful and distrusting of those who are supposed to be experts or vendors, and then people ask even more questions. Some well put-together data or a write-up could really minimize a lot of the repeated questions. |
10-05-2012, 09:16 AM | #6 | |
Member#: 332887
10-05-2012, 09:26 AM | #7 | |
Member#: 70151
The 09+ (possibly 08 as well don't remember) have a much better transmission. It's not even close to STI level, but it's a heck of lot better than previous years. Long story short, they stuck the legacy's 5 speed in and ditched the old one. History has taught us that people tend to ignore the sticky's and keep posting the same questions. There you have it. Oh and the stock headunit (aka radio) sucks the big one. |
10-05-2012, 09:29 AM | #8 | |
Member#: 221580
Vehicle:2011 WRX STI Satin White Pearl |
I can see where you are coming from. But with cars some modifications you cannot see "visible" results. For example changing shifter bushings. I mean we know how the stock felt but with the new ones it "feels" different and "better". Thats all we get to say about that. We cant record any more than that. As for the tuners using the catchphrase "Stage 1 is better, buy my services or tuner". They are not going to use it because only one company owns that market. Cobb. |
10-05-2012, 09:47 AM | #9 |
Member#: 263329
Vehicle:2011 Impreza WRX DGM |
Just throwing in a comment to keep track of this thread. I'm creeping up from stage 2 power (probably ~330ish-whp, 350+tq) and dont want my engine to pop out from under the hood, nor for the tranny to split like a coconut.
10-05-2012, 09:50 AM | #10 |
Vehicle:OK buy Nates beans westcoastroasting.com |
weak parts???
the parts between the ears of the driver are ALWAYS the weakest |
10-05-2012, 10:08 AM | #11 |
Member#: 302438
SWIC
Vehicle:10 WRX SS DMrally tuned! |
Proof stage 1 OTS Cobb tune is better than stock? Buy one (or go open source) datalog the stock tune, then load or tune to stage 1 and look at the timing curve. This alone will enlighten you on how bad the stage 1 tune is. Also, with opensource, you cn actually alter the closed loop/open loop setup correcting the lean condition. The only "weak" thing i've found is the stereo. What a piece of junk. That said, I don't turn it on much anyway. My exhaust is my stereo!
10-05-2012, 10:08 AM | #12 |
Member#: 53856
Vehicle:2012 Speed3 Red Mica |
10-05-2012, 10:09 AM | #13 | |
Member#: 249659
Vehicle:2012 WRX Limited SWP |
But I'm stage 2 on my '12 WRX and people are telling me to be easy on the tranny. Not having any problems yet after 3k miles. |
10-05-2012, 10:15 AM | #14 | |
Member#: 303906
Vehicle:2011 WRX Sedan Spark Silver Metalic |
10-05-2012, 11:17 AM | #15 | |
Member#: 70151
10-05-2012, 12:35 PM | #16 |
Member#: 94283
Vehicle:'19 Ascent |
10-05-2012, 12:46 PM | #17 |
Member#: 249659
Obviously Trying to stick to the topic though. I'm sure the OP would rather read something related to what he's asking than to read one of your smarta** remarks.
10-05-2012, 12:55 PM | #18 |
Member#: 296602
I actually was expecting at least 75% of this topic to have smarta** remarks, I have been around on this site long enough to expect that. Though, I have received some half-decent answers.
10-05-2012, 01:43 PM | #19 | |
Member#: 272675
Vehicle:2011 WRX 2002 Corvette Z06 |
10-05-2012, 02:09 PM | #20 |
Member#: 296602
^ Just wondering if you have anything to back that statement, curious for my own interest.
10-05-2012, 02:41 PM | #21 | |||||
Member#: 332887
Like I said, some mods are only noticeable when driving before and after installing them. Quote:
They are stronger, I'll give you that. But some of the dingdongs on here will misinterpret that, put 500 to the wheels, and then wonder why their "invincible tranny" broke. |
10-05-2012, 03:03 PM | #22 |
Member#: 249659
Good thing my father owns a tranny shop.
10-05-2012, 04:31 PM | #23 |
Member#: 316517
Vehicle:2012 WRB WRX Hatch TP Stage III & ELH |
List of parts I've installed/upgraded on my 2012 WRX so far...
1. Pitchstop 2. Motor Mounts 3. Steering Rack Bushings 4. Transmission Mount 5. Gearbox Bushings 6. Shift Lever 7. Shifter Bushings 8. Rear Differential Bushing Inserts 9. Rear Subframe Bushing Inserts 10. Front & Rear solid Swaybars Those were the "weak" points I felt I need to address before putting down more power. The car is certainly a lot more responsive and a little harsh times if you get it wrong, but when you're getting on it and ripping through the gears, it's glorious. No more vague, sloppy funny business going on under the car... I'm going for a Stage I tune and a catback next month from Eric. Next spring, after tax return, extra paycheck, etc I'll be trying to go for his "Stage III" tune, which is Stage II plus an EBCS, TMIC, fuel pump, etc. As you start turning up the boost, you run into all sorts of potential weak/leak points, like the stock TMIC, the stock BPV, etc. I figure if I'm going to be going to Stage II and looking at 19psi, I might as well go a tad further and upgrade those "stage III" parts that 'might' fail under Stage II boost anyway. |
10-05-2012, 04:38 PM | #24 | |
Member#: 206851
Vehicle:56 Belair Pro Street |
10-05-2012, 10:44 PM | #25 |
Member#: 283815
TXIC
Vehicle:2003 psm wrx wagon Built Fuji Tough |
They sure as hell better be when these guys are pulling 350wtq at a simple stage 2. That's a hard number to get to in a bugeye without a *****load of mods (compared to stage 2)
