Brakes & Suspension Forum sponsored by The Tire Rack |
01-04-2007, 02:53 PM | #1 | |
Member#: 72031
NWIC
Vehicle:2017 SS 1LE |
Will X shocks fit with Y springs on my Z model?
FYI
1. 04+ means 04 and up 2. suspensions between 02+ and the 04 STi are interchangeable. for example, you can run KYBs with 03 springs and 03 tophats on your 05 WRX. 3. any strut made for an 02-03 WRX can be used with 04+ WRX springs and 04+ WRX tophats, but you will need strut spacers from TiC. http://www.turninconcepts.com/produc...roducts_id=234 4. any strut made for an 02-03 WRX can be used with 04 STi springs and 04 STi tophats, but you will need strut spacers from TiC. 5. any strut made for an 04+ WRX cannot be used with 02-03 springs and 02-03 tophats. 6. 02-03 springs require 02-03 tophats 7. 04+ springs require 04+ tophats Struts Strut: KYB AGX Springs: All springs will fit. However, 02-03 springs must use 02-03 top hats. 04+ springs must use 04 and up top hats AND a washer from TiC. Models: This strut assembled properly with springs and tophats will fit, 02+ WRX, and 04 STi. This strut assembled properly will not fit 05+ STis due to the front knuckle redesign. My understanding is that the rears will fit 05+ up STis. Strut: Tokico D-Spec This strut fits the same as the KYB AGX. Strut: Koni Insert Notes: Koni only makes inserts for use, so in order to use them you will need struts from an 02+ WRX. STi struts will not work because they are inverted. You take the 02+ WRX struts and hack them up. *insert link here for directions) Springs: All springs will fit. However, 02-03 springs must use 02-03 specific Konis and 02-03 tophats. 04+ springs must use 04+ Konis and 04+ tophats. Models: This strut assembled properly with springs and tophats will fit, 02+ WRX, and 04 STi. This strut assembled properly will not fit 05+ STis due to the front knuckle redesign. My understanding is that the rears will fit 05+ up STis. Strut: Ohlin Fixed Perch 04+ WRX and 04 STi Notes: These babies cost $$$! Springs: Only 04+ springs will fit because 04+ tophats must be used. Models: This strut assembled properly with springs and tophats will fit, 02+ WRX, and 04 STi. This strut assembled properly will not fit 05+ STis due to the front knuckle redesign. My understanding is that the rears will fit 05+ up STis. Strut: Ohlin Fixed Perch 05+ STi Notes: These are pricey and rare. If you want them contact http://racecompengineering.com/ or www.gtworx.com. Arguably the best fixed struts for the Impreza. Springs: Only 04+ springs will fit because 04+ tophats must be used. Models: This strut assembled properly with springs and tophats will fit 05+ STis. This strut assembled properly will not fit 02+ WRX, and 04 STi due to the front knuckle design. Suspension TakeOffs V7 is equivalent to the 02-03 WRX model years in the US. V8 is equivalent to the 04-05 WRX, and 04 STi model years in the US. V9 is equivalent to the 05+ STi model years in the US. When talking about full takeoff suspensions, V7 and V8 are interchangeable. So, a V8 suspension will fit on your 2002 WRX just like a V7 suspension will fit on your 2005 WRX. If you want to fit a 2005+ STi (V9) suspension on your WRX... Quote:
For the fronts... The fronts have two bolt up configurations. Configuration 1 - 02 to 07 WRX and 04 STi Configuration 2 - 05 to 07 STi Struts have two configurations. Configuration X - 02 to 07 WRX and 04 STi Configuration Y - 05 to 07 STi Springs have one configuration. Top Hats have one configuration. There are four possible configurations... 1X - works with no modification 2Y - works with no modification 1Y - works with modification / spacers 2X - never works (unless you like welding) For the rears... The rears have one bolt up configuration. Struts have two configurations. Configuration X - 02 to 03 WRX Configuration Y - 04 to 07 WRX or STi Springs have two configurations. Configuration A - 02 to 03 WRX Configuration B - 04 to 07 WRX or STi Top Hats have two configurations. Configuration 1 - 02 to 03 WRX Configuration 2 - 04 to 07 WRX or STi There are eight possible configurations... XA1 - works without modification XA2 - doesn't work XB1 - doesn't work XB2 - works with spacers YA1 - works without modification (need to double check) YA2 - doesn't work YB1 - doesn't work YB2 - works without modification Last edited by nate.the.great; 05-14-2009 at 06:13 PM. |
01-04-2007, 02:59 PM | #2 |
Member#: 97303
MAIC
Vehicle:2015 WRX |
Nice post. Now add Ohlins Fixed Perch struts to the mix!!!!!
01-04-2007, 03:01 PM | #3 |
Member#: 72031
NWIC
01-04-2007, 03:05 PM | #4 |
Member#: 97303
MAIC
Vehicle:2015 WRX |
You can use the 04 spec on an 02-03 but you will need to upgrade to Version 8 top hats.
-Dan |
01-04-2007, 03:38 PM | #5 |
Member#: 62422
SCIC
Vehicle:2006 Lotus Elise- 1.8L of Fury!! |
Lots of great, easy to understand information here. Unabomber's Manifesto should link to this.
01-04-2007, 06:59 PM | #6 |
Big Ron
Super Moderator Member#: 18062
MAIC
Heck yeah! Thanks for the PM TRooper. I tried to do this ages ago and got no support. Now, I WISH this list had the popular JDM springs/struts on it like:
Ver 8 will fit what Ver 7 will fit what Spec C will fit what Those are the most commonly used JDM suspensions I've seen but there isn't a list to my knowledge of what will fit what or what you have to do that is "ghetto" to make them fit. I'll like this into one of my FAQs later. |
01-04-2007, 09:44 PM | #7 |
Member#: 38772
MAIC
Vehicle:2 Cars, No Bling |
You should add the wagon/sedan differences as well.
01-04-2007, 11:03 PM | #8 |
Member#: 17418
RMIC
Vehicle:2002 WRX 1968 Camaro SS/RS |
i'm glad this has been brought up. the "washer" mod only pertains to the rear tophat, correct? the front tophats are the same? i have an 02 and want to use 04+ springs (crucial).
01-05-2007, 07:17 AM | #9 | |
Member#: 38772
MAIC
You'll need new rear tophats and the washer mod (bad) or the Scooby921 spacer (good - from Turn in Concepts). |
01-05-2007, 10:41 AM | #10 |
Member#: 121883
E. Canada
Awesome write up !
Add: Only 05+ STI struts fit the 05+ STI's because of (5x114.3 config), won't fit any 02-07 WRX's (sedan/wagons) |
01-05-2007, 10:45 AM | #11 |
Member#: 72031
NWIC
01-05-2007, 10:51 AM | #12 |
Member#: 121883
E. Canada
Sir. I believe you're correct ! I 'think' the rears fit but the front was the problem..
01-05-2007, 10:52 AM | #13 |
Member#: 72031
NWIC
01-05-2007, 11:09 AM | #14 | |
Member#: 54202
MAIC
Vehicle:ASK ABOUT NEW RCE SWAY BARS FOR STI |
- Andrew |
01-05-2007, 12:03 PM | #15 | |
Member#: 15276
International
Vehicle:2007 Legacy spec B Gray |
01-05-2007, 01:03 PM | #16 |
Member#: 35816
MWSOC
Vehicle:1982 XS650 In a thousand pieces |
01-05-2007, 01:44 PM | #17 | |
Member#: 54202
MAIC
V8 Spec C fitment will be the same as regular V8. Spec C is just another trim level I guess. V9 JDM STi will be the same as 05+ USDM STi. - Andrew |
01-05-2007, 01:56 PM | #18 |
Member#: 88501
BAIC
Vehicle:2011 WRX Hatch Dark Grey |
Hey... what about the differences between wagon and sedan stuff?
Like... springs; especially for people who don't want the rake to change because the wrong spring set was used. |
01-05-2007, 02:31 PM | #19 |
Member#: 39905
NWIC
everyone always forgets about us GC peoples
11-21-2013, 05:20 PM | #20 |
Member#: 358256
TXIC
Vehicle:2005 Legacy GT Silver |
01-05-2007, 06:03 PM | #21 |
Member#: 72031
NWIC
i'm working on the GC and wagon stuff. i love you guys, but i know more about GD because i own one!
01-06-2007, 10:13 AM | #22 |
Big Ron
MAIC
Please keep working, I love you for this!
01-24-2007, 08:27 PM | #23 |
Member#: 36838
MAIC
Vehicle:2001 B50 RSTi Sedan 2011 DGM WRX hatch |
subscribing for GC stuff.
I see several 02-03 and 04 coilover setups I would like to jump on asap. I will re-drill my rear strut mounts if necessary.... Thanks! -- Dave |
01-24-2007, 08:48 PM | #24 |
Member#: 24038
South East
I've heard that you CAN (from about 3 people) use 04 struts with 02/03 springs and tophats. Are you 100% sure you can't?
01-24-2007, 09:23 PM | #25 | |
Member#: 36838
MAIC
Yes, I can use stock 02-03 setups, as long as I use a rear GC tophat. My issue is (and I'm pasting this from the other tophat thread...) that I have a really nice set of Apexi N1 Type V coilovers on my RSTi (GC Chassis) in 8k/6k variety and I found two sets in 7k/4k variety for sale, but they are for 02-03 cars... I wanna see what it takes to make those tophats fit the GC. If two of the bolts are the same distance as the GC bolt holes, then I only need to elongate one hole and the strut will still be centered properly... If all 3 are different, then I have to buy a different top hat. Depending on the price of the aftermarket tophats that fit, I may choose a different option, ie koni inserts. Thanks, -- Dave |
Similar Threads | ||||
Will this exhaust fit with my downpipe? | jcl | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 01-06-2010 08:21 AM |
Will these shocks fit? | skybox | Newbies & FAQs | 0 | 12-29-2007 06:55 AM |
will this downpipe fit with my exhaust | Sedatives17 | Newbies & FAQs | 4 | 09-23-2006 02:15 PM |
Will Fluidyne radiator fit with A/C on 02' WRX??? | Farnsrocket | Newbies & FAQs | 5 | 05-17-2005 12:00 PM |
Will espelir catback fit with my HKS downpipe? | ImportVenom | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 07-29-2004 12:08 AM |
