05-08-2007, 05:04 PM | #1 |
Member#: 147228
VIC
Vehicle:2004 bimmer 545i E60 |
help----remove my rotor
hey, guys, i am trying to move my rotor and have them machined,its been 2 days and now i am at my last step. do i have to remove the bolt in the circle to take out the rotor or just rotor is rusted with the arm?
thanks
05-08-2007, 05:16 PM | #2 |
Member#: 4718
VIC
Vehicle:I gotz a Subaru again |
the rotor should just pop off.
Don't take out that center bolt, it's not necessary. Do use a rubber mallet, and gently tap the rotor from the backside, rotating the assembly so you're not hitting it in the same spot over and over. It will come free, just be sure to not let it hit the ground when it comes loose. |
05-08-2007, 05:45 PM | #3 |
Member#: 12408
VIC
Vehicle:2020 Model 3 SR+ Gray |
Or do it the easy way: just drive bolts into those two threaded holes visible just inside the lugs.
05-08-2007, 06:04 PM | #4 |
Member#: 4718
VIC
I may be blind banman, but it doesn't look like he has the threaded holes.
05-08-2007, 06:17 PM | #5 |
Member#: 12408
VIC
05-08-2007, 06:33 PM | #6 |
Member#: 147228
VIC
hi, all ,thanks
i tried to tap it fromt the back, but the rotor is just firm as hell. how does that thread hole help to remove the rotor? |
05-08-2007, 06:38 PM | #7 | |
Member#: 12408
VIC
Just be sure it's a stout bolt. I first tried it with some Home Depot bolts, and I managed to bend the crap out of them. |
05-08-2007, 06:39 PM | #8 |
Member#: 6971
Vehicle:2008 WRX STi SSM |
put two bolts into those holes and find out Doh! ^^^ Party pooper
05-08-2007, 06:41 PM | #9 |
Member#: 147228
VIC
ok. would let you know ... starting on that now.
05-08-2007, 06:43 PM | #10 |
Member#: 4718
VIC
05-08-2007, 08:02 PM | #11 |
Member#: 147228
VIC
hahaha.job done. thanks so much guys. especially banman and supermarkus..ready to machine them tomorrow. fyi, there is one at fraser and 19th ave do the job really cheap, only 11.5 a peice. any recommendation on that?
05-08-2007, 08:36 PM | #12 |
Member#: 99206
W. Canada
Vehicle:2007 WRX STi wagon Ducati Hyperstrada, WR450 |
to tell you the truth.. just buy new rotors rather than re-surface them. I've done the whole re-surface thing before, and most times within a couple of months the "pulsing" in the steering wheel returns. You can usually find cheap OEM replacement rotors at Lordco/Napa etc.. usually for around the 25.00 a piece range.. and those are new rotors.. just a sujestion..
05-08-2007, 09:42 PM | #13 |
Member#: 82465
VIC
Vehicle:2014 Forester 2.0 XT MBP |
Hit the hub with some penetrating lube. Drive M8 bolts into the two holes. The caliper bolts fit, *but don't use them* -- if the rotor is really welded on, they could shear off. Don't ask me how I know this. Some taps on the back of the rotor with a hammer also might help. I've also had success with a small sledge and extremely violent tapping -- only do this if you have a short temper.
When you put the rotor back on, use a some high-temp anti seize on the mating surfaces. Hopefully, it will be easier to remove next time. |
05-09-2007, 12:47 AM | #14 |
Member#: 147228
VIC
thanks madcat, the job is done now.
Similar Threads | ||||
How do I remove the rotors on my 05 wrx? | 05Scooby | Brakes, Steering & Suspension | 4 | 03-01-2008 07:09 AM |
Help removing rear rotors. | chuckywang | Service & Maintenance | 7 | 11-20-2007 10:02 AM |
Need help removing rotors | jacket03WRX | Brakes, Steering & Suspension | 31 | 04-26-2006 12:03 PM |
Need Quick Help with removing rear rotor (it's stuck) | njpreppy | Brakes, Steering & Suspension | 5 | 07-22-2004 04:02 PM |
Help removing my door panels | Dre2932 | Interior & Exterior Modification | 12 | 10-01-2002 03:00 AM |
