09-12-2002, 01:36 PM | #1 |
Member#: 4850
Vehicle:1998 EJ22.5RS-T more mods coming soon!! |
Is this the correct Catch Can I would use?
Im still haveing some small oil burning problems even after my larger return line was installed so Im gonna try thre catch can route. Is this the correct one I would use or do you have a different suggestion?
http://www.jegs.com/cgi-bin/ncommerc...87&prmenbr=361 Thanks for the help Kyle 98RS-T Owners UNITE!
09-12-2002, 02:31 PM | #2 |
Member#: 1994
Vehicle:2018 STI WRB |
I just got a generic one and Zip tied it to the ABS module. You can see it next to the air filter in this pic.
09-12-2002, 04:27 PM | #3 |
Member#: 1676
NESIC
Vehicle:98RS w/ EJ257/Dom 2014 Tesla Model S P85 |
I used a $3 fuel filter. Works great
09-12-2002, 09:18 PM | #4 |
Member#: 4850
where can you get generic ones from and how do you hook it up anyway? Thanks for the help
Kyle |
09-13-2002, 10:27 AM | #5 |
Member#: 1676
NESIC
I Tee'd my crankcase vent hoses together and used a $3 Purolator fuel filter from Pep boys. It doesn't really matter which one you use. Just find one that seems big enough and has an inlet close enough to the size of your crankcase vent line that you don't have to use too many reducers to fit it in. Then just leave one side of the filter open to the air. Basically, you could leave the crankcase vent lines open to the air except you don't want debris being sucked in or oil being spewed around at random. It's not rocket science or nothin'
09-13-2002, 01:26 PM | #6 |
Sooby Guru
Member#: 1914
SWIC
Vehicle:2000 2.5RS w/ EJ22T swap and N20. gone. : ( |
I like using a catchcan to know if my engine is broke. My last engine shattered a ring and it seemed fine except for the fact that my catch can was filling with oil very fast. Now, I check the can a couple times a week. No oil in there means engine is still good. . You can see mine here:
Eric Edit: Does pic work now? Last edited by Eric SS; 09-13-2002 at 11:49 PM. |
09-13-2002, 02:49 PM | #7 |
Member#: 4850
Darshu,
Heres a dumb question which hoses are the ones I woud tee together. I think I know which ones your talking about (crankcase) bvut I want to make sure I got the right ones...can you lead me to the correct ones? Thanks Eric.... your pic didnt work do you mind trying to post again I want to see some pics before I do this myself to make sure I dont mess anything up! Kyle |
09-13-2002, 03:49 PM | #8 |
Member#: 1994
Kyle
There are three hoses. One coming out of either head (can't miss 'em) and the last is connected to the PCV (PVC?). To get to that one, you'll probably have to remove your intercooler. It's a Y looking thing, one end connects to the block, one end the intake manifold, and the third right now may be connected to your intake, that one would go to your catch can |
09-13-2002, 05:01 PM | #9 |
Member#: 447
Vehicle:1999 RSTI WRB |
hope this helps... what i did was take the pcv valve hose
shown here (pics are big) |
09-13-2002, 05:02 PM | #10 |
Member#: 447
and T both the crankcase ones here
and here |
09-13-2002, 05:04 PM | #11 |
Member#: 447
and all the hoses went to the oil catch with filter on top...
i'm pretty sure you will need to get new hoses... i got fuel 1/2 hoses... like 6 feet just in case... |
09-13-2002, 05:17 PM | #12 |
Member#: 1994
also, you can get the nylon Ts at Home Depot. I think the actual size is 5/8th for the hose. I can't remember for sure. 1/2 will probably work.
Is this the correct vaccumn routing? | Illsti | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 8 | 07-18-2008 11:31 PM |
Is this the correct way to plumb an AVC-R and a TiAL 44mm EWG (Picts included) | dexterous | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 25 | 05-06-2008 10:19 PM |
is this the correct Sti 280ps Ecu codes?? | maverkakis | Engine Management & Tuning | 6 | 06-27-2003 05:28 AM |
Is this the correct size for replacement spark plugs | Scoobie Newbie | Newbies & FAQs | 5 | 03-06-2003 05:27 PM |
Is this the correct forum for the Fargo area? | david2z4 | Mid West Subaru Owners Club Forum -- MWSOC | 5 | 11-16-2000 06:40 AM |
