01-19-2013, 10:29 PM | #76 |
Member#: 219100
Vehicle:2014 STI hatchback Satin White Pearl |
Washed the car today since the temps here in Philly were unseasonably warm. Still froze my ass off. Lol.
Anyway, I snapped some pics of the headlights (at night) for you guys. Also got a chance to level them after reading exactly how high I should make the cutoff. (Park on a flat and level surface. Measure from the center of the headlight to the ground. -> The headlight center is marked by a tiny bubble in the OEM headlight lens. Park 25' from a wall. Whatever your measurement from the ground to the center of the headlight was should be your cutoff height.) My headlight bubble measured 24" from the ground. So that's what I made the cutoff in the parking garage at Whole Foods. ^My cutoff is just below the green line on the wall. It's not the one above FYI. I'm a little frustrated. I can't seem to get the driver's side cutoff to line up EXACTLY with the passenger side cutoff. As you can see in the picture above, they're even in the middle but the driver's side is sliiiiightly higher on the right. And the passenger side is sliiiiighty higher on the left. Idk, maybe it's supposed to be like that? I don't think it's anything I can adjust without opening up the headlights. Maybe the projectors and the cutoffs were installed ever so slightly crooked? But perhaps I'm being too picky. After all this, now my foglights need to be adjusted. Lol. Updated engine bay shots coming soon.
01-19-2013, 11:26 PM | #77 | |
Member#: 181047
Vehicle:2015 CWP WRX 2015 SWP Forester XT |
Qwak, mine do the same thing. Must just be a retro fit thing. |
01-21-2013, 03:26 PM | #78 |
Member#: 219100
Did a little photoshoot today. We'll have to see how some of these came out. |
01-21-2013, 03:56 PM | #79 |
Member#: 275586
SCIC
Vehicle:2011 WRX Sedan 290whp 340wtq Cali 91oct |
Retro's look good! I believe your cutoff is still too high. From the ground to the middle of your projector you measured 24". The top step of your cutoff against the wall at 25 feet away should be 2 inches lower then your 24".
http://www.hidplanet.com/forums/show...HID-headlights |
01-21-2013, 10:43 PM | #80 |
Member#: 219100
^thanks cliff_11WRX. I'll adjust them this weekend. Thought they seemed kinda high when driving.
01-21-2013, 11:18 PM | #81 |
Member#: 219100
Well, I only got one photo edited so far. Just downloaded Photoshop Touch for iPad so I'm trying to learn it.
Photobucket image by QwaktastiK, on Flickr I'll post more throughout the week. Last edited by QwaktastiK; 01-22-2013 at 11:02 AM. |
01-22-2013, 03:03 AM | #82 |
Member#: 301431
AKIC
Vehicle:2005 Evolution VIII |
still these sexyest narrow body ever!
01-22-2013, 08:34 AM | #83 |
Member#: 219100
Alright. You guys are going to have to bear with me. I'm red green colorblind so I might have adjusted the saturation a little too much.
Photobucket It looks much better in the Photoshop app. Not sure if Photobucket is compressing it more than Flickr would. image by QwaktastiK, on Flickr And the Instagram version: image by QwaktastiK, on Flickr Last edited by QwaktastiK; 01-22-2013 at 04:32 PM. Reason: Comparing Photobucket to Flickr. |
01-22-2013, 11:58 AM | #84 |
Member#: 219100
01-24-2013, 11:38 AM | #85 | |
Member#: 219100
Here's a diagram someone made for reference: Option C is what I will be using. Last edited by QwaktastiK; 01-24-2013 at 11:57 AM. |
01-24-2013, 01:58 PM | #86 | |
Member#: 268328
BAIC
Vehicle:2011 2.5i prem pckg SSM |
01-24-2013, 05:21 PM | #87 | |
Member#: 219100
I'm sure if you contact TRS before you order your kit they can tell you what people usually go with. My halos are mounted at the front of the shroud. But yes, the outer portion, not centered. There was talk of getting larger halos and mounting them at the back of the shroud, but idk how many people went with that option. Thanks for the compliments man. Good luck with your car. |
01-30-2013, 12:04 PM | #88 |
Member#: 219100
01-31-2013, 02:12 PM | #89 |
Member#: 219100
02-05-2013, 10:02 PM | #90 |
Member#: 219100
For those with pets & a hatchback, this is the pet barrier I'm running:
http://www.discountramps.com/vehicle_pet_barriers.htm Fits perfectly in the 08+ hatches. |
02-09-2013, 12:55 PM | #91 |
Member#: 219100
02-25-2013, 10:47 PM | #92 |
Member#: 219100
02-27-2013, 12:40 PM | #93 |
Member#: 219100
Did 3 dyno pulls today before some upcoming changes.
Event: Dyno pull Location: R/T Tuning, Lansdale, PA Ambient Temp: 50*F Elevation: 361' Weather: Cloudy, Wet, 14mph WNW Winds Humidity: 78% Tires: Bridgestone Blizzak WS60 215/50/17 Wheels: XXR 527 17x8.25 +25 Car: 2009 Subaru WRX Premium 5dr Tuner: COBB OTS Stage 2+ 93oct Map Dyno Info: Mustang AWD Dyno Transmission: Stock 5MT Gear: 3rd Peak HP at RPM: 296 @ ~6,000 Peak Torque at RPM: 349 @ ~3,650 Baseline hp/tq for a stock WRX on same dyno: unknown Target Boost: ~18.2psi tapering to ~13.5psi by the 7000 RPM redline, +/- 1psi. Target AFR: unknown - will look up Fuel: 93oct Engine Mods: COBB AccessPort (Stage 2+ 93oct low wastegate duty map), COBB SF Intake & Airbox Combo, Process West TMIC, Forge Recirculating BPV, SPT Turbo Heat Shield, TurboXS High Flow Catted Downpipe, TurboXS Catback Exhaust Driveline Mods: Kartboy Short Shifter, Kartboy Shifter Bushings, TiC Shift Linkage Bushings & Pivot Bushings Suspension Mods: GTWORX/Bilstein Impreza Cup Sport Kit, RCE Black (Regular Guy) Springs, RCE Camber Plates (front), RCE 25mm Hollow adj. Front Sway Bar, RCE 25mm Hollow adj. Rear Sway Bar, Kartboy Front and Rear Endlinks, Whiteline Rear Camber Adjuster Kit, Whiteline Rear Trailing Arm Bushings, Whiteline Front Inner Control Arm Bushings, Whiteline Anti-Lift Kit, Whiteline Steering Rack Bushings, Whiteline Front Differential Positive Power Kit, GTSPEC Strut Bar Last edited by QwaktastiK; 02-27-2013 at 02:14 PM. |
02-27-2013, 05:07 PM | #94 |
Member#: 326317
SCIC
Vehicle:2011 WRX hatch SSM |
Love the info provided, very complete with the details & that is a very nice baseline for any more power haha! So were your dyno pulls not affected by your Blizzaks? I would think it wouldn't because the car is sitting on the rollers no matter what tire and the tires can't change data that is being pulled, but I am not knowledgeable on the subject so my curiousity is getting the best of me haha...
02-27-2013, 05:28 PM | #95 |
Member#: 181047
Great numbers! They seem high for an ots Cobb map though. Although really those numbers don't matter. The gain from the baseline numbers do!
02-27-2013, 07:44 PM | #96 |
Member#: 219100
Thanks guys. Yah, I wish I had a stock baseline dyno plot. But this will hafta do.
Changes start this Monday. It should take a full month. Gotta work on my patience. Lol |
02-27-2013, 08:04 PM | #97 |
Member#: 345444
Vehicle:2013 Impreza 5-door White |
beautiful car, but, damn, what kind of sunglasses are those!
02-27-2013, 09:11 PM | #98 |
Member#: 181047
I think you misunderstood... you're dyno pull will be the "baseline" that you will use to see how much of a gain you made when you finish your mods and get tuned.
02-27-2013, 10:04 PM | #99 |
Member#: 219100
Awesome ones.
...Carrera Brand. Lol Yup. That's why I wanted to get this done today. I'm so excited for what's to come but pleasantly surprised at today's numbers. |
03-05-2013, 04:42 PM | #100 |
Member#: 219100
Decided to go back to stage 1+. I didn't want all that power. Plus now I get better mpg's! Yay!!
J/k. TurboXS Downpipe is off and on its way to Swaintech along with brand new Agency Power UEL Headers & Uppipe. Turn around time is 3 weeks. Let the waiting game begin. |
