Brakes & Suspension Forum sponsored by The Tire Rack |
12-28-2005, 10:31 PM | #1 |
Member#: 81931
TXIC
Vehicle:2008 STI (Stage 1) WR Blue Mica w/ Gold BBS |
Resutls of 20mm sway bar install on WRX wagon
Have to say, that for the price, I'm very happy with this addition. Bar install was fairly straightfoward, but I had to shave the new bushings a little to get them to fit. They were about an an 1/8 of inch too tall to fit in the brackets. Anyone else run into this? I cut them down just a hair, then compressed them to get the brackets around them. Wish I'd known that ahead of time.
I'm also thinking of getting some stiffer bushings in the future. Any recommendations?
12-28-2005, 11:19 PM | #2 |
Street's closed, pizza boy
Member#: 17301
Vehicle:2018 Focus RS 2006 Evo #17 STU |
Recommendations:
-get a bigger front bar, too -make sure you know what lift throttle oversteer is, and how not to cause it What endlinks are you using? john |
12-28-2005, 11:30 PM | #3 |
Member#: 64351
NESIC
Vehicle:2005 Legacy GT |
Yea I got a 20 mm bar w/ bushings for 40 bucks, probably best mod for the money I have done so far.
12-28-2005, 11:33 PM | #4 |
Member#: 50274
Vehicle:2004 WRX Wagon invisible |
$60, stock endlinks. It completely changes the car from an understeering pig to alot more nimble, something with a lot of potential. Looking at kartboy endlinks, but haven't done it yet.
12-29-2005, 12:06 AM | #5 |
Member#: 81217
Mine is coming in the mail tomorrow! WOOT!
It is sitting at the UPS in Syracuse right now, if they were open I'd probably drive up there to get it hopefully I don't run into the bushing problem as well, I don't think I will but will let you know if I do |
12-29-2005, 12:43 AM | #6 |
Member#: 26607
Vehicle:2002 wrx wagon |
I didn't have problems with bushings not fitting good.
I agree when I swapped out my 17mm rear sway bar for a 20mm in my wagon, it changed how the wagon felt. Very predictable and easy to rotate. |
12-29-2005, 12:40 PM | #7 |
Member#: 34596
Vehicle:'05 WRX Wagon PSM '03 WRX Sedan PSM (Hers) |
That's strange, I didn't have any problems with the bushings at all. Did you get the proper new style bushings with it ('04+), or did you try to use the old style ('02-'03)?
-Bryce |
12-29-2005, 03:45 PM | #8 | |
Member#: 81931
TXIC
As for the end links, right now, I've got the stock ones. I plan to stick with them until I go to something bigger than 20mm. |
12-29-2005, 03:46 PM | #9 | |
Member#: 81931
TXIC
12-29-2005, 06:03 PM | #10 |
Member#: 89165
Vehicle:Poop Stuck Survivor -=C=- & subari87 FOREVER! |
Have you tried looking at Auto Zone or someplace like that? The AutoZone here has a TON of those red suspension bushings (Energy brand?) I was in there the other day and noticed them. I was surprised how many different ones they had.
I don't mean to hijack, but I've been thinking of getting the 20mm rear bar for my 02 wagon. However, the other night I was playing with my new SS, and had the opportunity to really push my car on damp roads. Even with letting up the throttle during mid-corner, I had no rotation. Getting on the gas hard, I had no push. My car is stock except for springs (B+G, and I love them!). I feel the car handles in a very nuetral manner. Should I skip the 20mm rear bar? Actually, I was originally thinking of a Hotchkis set, but do not have the $$ for that now. I'm going to AutoZone on my way home, and I'll scope out the bushings. |
12-29-2005, 07:19 PM | #11 |
Member#: 81931
TXIC
Given the small price of the 20mm bar, I think you should try it. If it doesn't work like you want, sell it. There seem to be plenty of people wanting one.
Good idea on the bushings. I have heard of that brand before. Let me know what you find out. |
12-29-2005, 07:54 PM | #12 |
Member#: 82313
NWIC
Vehicle:2003 REX WAG Platinum |
So I hear all these things about getting a bigger/stiffer rear sway. But I never see that you all are getting a front too? I guess I was thinking that you upgraded both at the same time. School me on this one pls.
Jaco |
12-29-2005, 08:10 PM | #13 |
Member#: 7958
Vehicle:09 GH B+ |
You can order 04+ style bushings for the 20mm bar- they are the same bushings that come on the STi- Jamie sells them on her site or you can pick them up from your dealer.
You can upgrade both bars at once if you like, but the oe front bar is 20mm, the rear 17mm- it makes sense to bump the rear one up first- see what you think and go from there. |
12-29-2005, 08:19 PM | #14 | |
Member#: 89858
Vehicle:2005 WRX Sedan Crystal Gray Metallic |
12-29-2005, 08:22 PM | #15 | |
Member#: 81217
This also holds true with the 2002+ wagons that come with a 17mm bar. The 02+ WRX already comes with a 19mm or 20mm rear bar depending on what month it was purchased. Therefore the front and rear bar ratio is almost the same or is the same. A lot of these drivers upgrade to a bigger rear bar as well to induce more oversteer. I guess the Impreza is notorious for understeer when pushed to its limits and that's one of the biggest factors in the rear bar upgrade. -MaC |
12-29-2005, 08:25 PM | #16 | |
Member#: 81217
12-29-2005, 09:42 PM | #17 |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
I would get the right bushings if you think you have the old style - I'd be concerned about them coming out of the clamp since the new ones have a groove for the clamp whereas the old ones did not (the old clamp is concave and covers them, while the new one is flat)
12-29-2005, 09:51 PM | #18 | |
Member#: 82313
NWIC
12-29-2005, 09:57 PM | #19 | |
Member#: 89165
Here you go yakkosmurf: Energy Suspension is the company. Here is a link to the Subaru item number page: http://www.energysuspension.com/pages/subaru.html Our AutoZone carried the rear sway bar bushings down to 22mm. Energy Suspension, as noted on the page in the link above, does make 20mm rear sway bar bushings that will work with the WRX. The bushing sets I looked at came with the metal straps (the steel piece that holds the bushing in place) and bolts. The 22mm set was selling for $15.99. I'm sure an AutoZone could order the 20mm bushings for around the same price. And AutoZone won't charge you shipping on special orders (at least ours never charged me shipping). I hope that info helps. |
12-30-2005, 09:00 AM | #20 |
Member#: 81931
TXIC
That helps a lot. Thanks. I'm going to go by there this weekend and see what my local store offers.
20mm sway bar mounts on wagon? | dome | Brakes, Steering & Suspension | 2 | 11-09-2004 02:34 PM |
Front Sway Bar installation on WRX | rankink | Brakes, Steering & Suspension | 8 | 03-09-2004 05:03 PM |
I need some help... Front Sway bar install on WRX Wagon | Whelp | Bay Area Impreza Club Forum -- BAIC | 10 | 07-25-2002 06:00 PM |
Front sway bar install on a 2002 wrx wagon | ROBSTA | Brakes, Steering & Suspension | 6 | 05-05-2002 09:54 AM |
