08-13-2006, 02:08 AM | #1 |
Member#: 113083
Autometer Nexus gauge turns off when headlights turned on
I am hooking up a nexus boost gauge, and used the thread "Gauge Installation Electrical Wiring Tips and Pics Defi and Others" to help with the wiring. There are only 3 wires that need to be connected, a ground, a constant +12v source, and a switched 12v source that is on during engine start and crank but off when ignition switch is off. I have a 2005 sti and hooked up the constant to the blue w/ red stripe wire on the radio harness, then the switched 12v source to the green w/orange stripe on the A/C harness. Now I turn the key to the run position and the gauge works fine, I can start the car and it still reads fine, but if I turn on my headlights/parking lights the gauge immediately loses power and shuts off. If i then turn off the headlights it once again gets power. I am wondering what the problem could be, if anyone could let me know it would be of great help. Thanks
08-13-2006, 02:58 AM | #2 |
Member#: 113083
haha ok figured it out sorry.........im a little slow and i guess it was a bad ground.....though we did switch up some wires also. Works great now!
Where to Tap Fuel Pressure Line & Defis Turn off When I turn my headlights on | 04ImprezaWRX | Interior & Exterior Modification | 7 | 05-22-2009 08:31 AM |
Radio sometimes turns off when I turn off engine | dauss | Newbies & FAQs | 3 | 04-06-2007 12:07 AM |
JDM headlights will not turn off when car is on | druxboyz | Electrical & Lighting | 4 | 01-13-2006 08:39 PM |
Why do low beams turn off when you turn on high beams? | ragnarok | Electrical & Lighting | 13 | 06-03-2005 10:09 PM |
CD deck turns off when I turn volume down... | Siper2 | Car Audio, Video & Security | 0 | 07-16-2001 05:47 AM |
