08-16-2003, 11:49 PM | #1 |
Member#: 152
Vehicle:2002 Impreza WRX WRB |
Gas really matters?
I wonder if gas really matters. If the gas has the same octane, why should brand name mean anything? Everyone keeps saying use 76. I just use Chevron. Anyone has thoughts about this?
08-16-2003, 11:57 PM | #2 |
Member#: 34162
Vehicle:2005 WRX wgn, 01 RS White, White |
I only use chevron.
I used to use arco type gas when I had my 84 Nissan Pickup. That truck would ping to hell everytime I stressed the engine (like going up a hill for instance) and when I switched to the same octane of chevron, it stopped. Good enough for me. |
08-17-2003, 12:10 AM | #3 |
Member#: 30185
Vehicle:2003 320 whp on a heatbreaker dyno |
On my commute car I used to use Arco or Beacon. I used Becon once on my motorcycle and it would backfire and drive real rough. Next tank of gas (76) it was fine. I did this 3 times before I connected the rough ride with the gas station. After only using 76, I never had this problem again.
I don't know about other brands, but Arco and Beacon don't seem to be as good as 76. I use Chevron in my van, but not in my WRX. |
08-17-2003, 12:15 AM | #4 |
Member#: 28685
Vehicle:2004 FXT 4EAT very STi'd |
I have used Chevron since I got my RS, but recently switched to 76 and saw a slight gain in mileage. The real advantage to getting "better" gas, however, is the quality of detergents and such that are added. On a personal note, I mainly prefer 76 over Chevron due to 76 no longer using MTBE as an additive- they use ethanol instead.
08-17-2003, 12:17 AM | #5 | |
Member#: 17684
Vehicle:1989 pathfinder rusted red |
08-17-2003, 12:20 AM | #6 |
Member#: 28685
08-17-2003, 12:21 AM | #7 |
Member#: 28685
No, that's deja vu Mike.
08-17-2003, 12:30 AM | #8 |
Member#: 23260
BAIC
Vehicle:Patr ick Willis for Rookie of the year |
I have in my 91 Integra I used beacon, I got some knock and switched to 76/shell/chevron and it was still there so I tried 89 octane at beacon and it worked. In my RS I alternate tanks 1 out of every three is either costco or safeway and I have had no problems.
08-17-2003, 12:31 AM | #9 | |
Member#: 17684
deja vu, eh andrew? edit whoa this is getting odd |
08-17-2003, 02:53 AM | #10 |
Member#: 13817
BAIC
Vehicle:1998 Impreza Outback Steel Blue Mica |
Yes! I was switching too much before (Arco and Shell). It caused too many problems for the ECU. The computer would compensate for all the different characteristics of the diiferent gases. It made my car run too rich and I wasn't getting a clean burn. I clogged my uppipe (stock) and wasn't boosting.
Now i use 76 only. |
08-17-2003, 05:58 AM | #11 |
Member#: 152
76 is a PIA to find though. It's not as widespread as Chevron (at least in the areas I go to). This is the reason I want to know if it makes a BIG difference. I've yet to get detonation problems and I get 30 mpg highway driving.
08-17-2003, 06:04 AM | #12 | |
Member#: 17684
http://www.76.com/ |
08-17-2003, 02:08 PM | #13 |
Member#: 26792
Vehicle:03 wrx sedan white |
i make it a point to PUMP 76 everytime. if i cannt get 76, ill pump just enough of whatever to get me to a 76 and fillup........
BTW: you think this shell claim that there gas get better gas mileage is true??? Last edited by zumnwrx; 08-17-2003 at 02:18 PM. |
08-17-2003, 03:05 PM | #14 |
Member#: 28685
Yeah, they probably got one freakin set of data showing their Impala got like .003 mpg more than the other guys'. Basically, to get the extra 50 yards or so that they show in the commercials, they had to drive the whole 450+ miles off the full tank of gas. Gee, I don't think driving style could account for that much, do you guys?
08-17-2003, 03:12 PM | #15 |
Member#: 23260
BAIC
While I doubt thier claim, I would bet that they did any gas milage tests using a computer in a lab somewhere, rather then sending some guy out to drive the car all out of gas.
08-17-2003, 04:03 PM | #16 |
Member#: 6750
i use 76 and costco, and to tell you the truth, when i switch from one to the other i can't really tell a difference, with 76 i actually get less miles/tank.
08-17-2003, 06:42 PM | #17 |
Member#: 30447
Vehicle:2002 WRX PSM |
In the delta dash, there is the Ignition Advance Multiplier(IAM). This is on a Scale from 0-16 0=Bad 8=Neutral 16=Best, The IAM is used to decide how aggressive the Ignition maps are going to be(read more at ecutek.com) Fill up with 87 or get a bad batch of gas and this will be down around zero. Fill up with a bit of 100 octane and it will go up to 16. The last 3-4 fill ups I have pumped only 76 91 Octane, and the IAM has been 15 or 16 every time I have checked. I didn't pay quiet as close attention to the IAM before but, it had been around 9-11 most of the time when filling up with Chevron.
08-17-2003, 08:20 PM | #18 |
Member#: 29376
Vehicle:2002 WRX Sedan Red |
I always wonder about this topic too. Someone on this board posted something about that the brand of gasoline really does matter, as he likened it to eating 80% meat as opposed to 93% meat. While 80% meat is alright, your arteries will get clogged up faster than if you eat 93% meat. The additives in name brand gasoline really do help your engine run better and extends its life.
That's why I'm starting to shy away from Costco and no name gas stations, even though they probably are alright, but if you stick with name brand stations like Chervon and the like, you know exactly what you're getting. I think overall that Chevron is the best, but everyone has an opinion. Mike |
08-17-2003, 08:46 PM | #19 |
Member#: 30512
Vehicle:01 2.5rs black |
chevron is the best in my opinion... but 76 isnt bad.
08-17-2003, 09:39 PM | #20 |
Member#: 16854
Vehicle:2003 WRX Sedan White |
I have used Chevron, 76 and Shell. My car runs the most consistantly on 76 in both Winter and Summer. It ran okay on Chevron, but I had some timing pulled (about 5 IIRC). I haven't logged with Shell, that was more of a feeling (before I got delta dash).
08-17-2003, 10:22 PM | #21 |
Member#: 23845
South East
Vehicle:2015 FLAT SIX White |
Shells claim
says: "The new Shell formulation, which is offered in all three grades - regular, plus and premium - can add up to 125 miles per year for a customer driving 12,500 miles per year." 125miles / 12 (months) is 10.41.. say you get 2 to 3 tanks/month 10.42 / 2.5 = 4.16 you just gained 4 extra miles by useing shell gas.. you probably went out of your way this same distance to aways visit a shell gas station. I myself enjoy marathon 93. |
08-17-2003, 10:34 PM | #22 |
Member#: 24687
BAIC
I use 76
08-18-2003, 02:49 AM | #23 |
Member#: 25728
I personally pump shell because there is a shell station on every corner here in Vallejo.
I think the real important thing is to just keep pumping the same gas. If you've been using chevron since you got your car then keep using chevron. EDIT: if you're really bored this site has way too much info on gas (but if your lazy it just basically says that yes there is a difference) http://www.faqs.org/faqs/autos/gasoline-faq/part2/ Last edited by AdoboUaReXnRice; 08-18-2003 at 03:03 AM. |
08-18-2003, 03:46 AM | #24 |
Member#: 6489
Vehicle:01' GM6 Black |
I like Chevon over 76, simply b'cuz 76 is da stupid Nazicar official fuel sponsor. I like SHELL too cuz of the Formular-1 back root, but what can I say, "Chevon, simple better!" hehe... blah
08-18-2003, 12:41 PM | #25 |
Member#: 36154
Vehicle:2004 WRX Wagon White |
my dealership actually recommended Chevron.
I used to work at a chevron and I have read the crap that other companies put in their gas. I only use 76 and chevron...the few cents is worth it. If I am out in bum freaked egypt I will use texico. And this is with my civic and my old 88 ranger we're talking about here...imagine how anal I will be with my rex...I am about to put it's 3rd tank of gas in tonight.....all chevron at about $2.15 a gallon or more.....bah. heads up to chevron users....if you can budget it, get the gas card...you get 5 cents off every gallon....it adds up. |
Similar Threads | ||||
WOMEN- Does size really matter??? | wrxman555 | Off-Topic | 17 | 11-25-2004 01:49 AM |
Does the Wastegate spring really matter? | drdeuce | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 08-26-2004 07:35 PM |
CEL, does really matter?? | BANG4BOOST | Engine Management & Tuning | 5 | 02-23-2004 11:29 AM |
does octane really matter? | terpWRX | Mid Atlantic Impreza Club -- MAIC | 14 | 08-03-2003 02:18 AM |
Do 1/4 mile times really matter? | Malfrag | Off-Topic | 26 | 08-02-2002 12:48 PM |
