06-04-2003, 03:44 PM | #1 |
Member#: 15543
Vehicle:555 Having a Subaru shop means too many cars |
Transmission temp gauge idea, Switch to use coolant temp gauge so no dash space taken
That subject box is too small!
I dont like the "modified" look, with gauges popping out all over the place. I just thought of this. With a two position switch you could use the coolant temperature gauge to view transmission temp. Think of it, your coolant will rest right at about 190 degrees, and you are used to exactly where it points. With a temp sender wired to the secondary position of the switch a quick flip would show transmission temp. What do you guys think? The ultimate stealth gauge.
06-04-2003, 04:00 PM | #2 |
Member#: 8808
NESIC
Vehicle:2011 WRX DGM 5D |
neat idea... you'd just need the right voltage range sender, or make your own circuit. That's a really cool idea, actually.
/Andrew |
06-04-2003, 04:10 PM | #3 |
Member#: 15543
Well, the stock coolant sender would be the correct electrical specs and the temperature range is also the same. Some type of housing would be needed.
06-05-2003, 10:23 AM | #4 |
Member#: 6124
Vehicle:2000 NFR AP1 S2000 '07 Honda FIT sport (5MT) |
Problem lies in the lack of granularity..
120 means a lot to me.. so does 160... on the stock gauge... 120-140-200 all show up the same... dead center Jorge (RiftsWRX) www.ProjectWRX.com |
06-05-2003, 12:26 PM | #5 |
Member#: 8808
NESIC
That's only because the ECU does an awful lot of filtering. The gauge itself is just a regular voltmeter.
/Andrew |
06-05-2003, 01:22 PM | #6 | |
Member#: 6124
Let us know! Jorge (RiftsWRX) www.ProjectWRX.com |
06-05-2003, 03:54 PM | #7 |
Member#: 8808
NESIC
Now, if only I still had an AT to hook it up to...
I'll take a peek in the wiring manual and let you know what I see. /Andrew |
Where to place coolant temp sensor? | yebokmj | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 04-28-2006 10:45 AM |
I have $30 best buy dollars and no idea what to use them for | linux>windows | Off-Topic | 17 | 10-19-2005 02:53 PM |
What 4 gauge amp kit to use? | sneeky | Car Audio, Video & Security | 3 | 04-04-2005 05:04 PM |
if I wanted to use an EGT gauge to--> | Matt K | New England Impreza Club Forum -- NESIC | 3 | 03-11-2004 10:52 PM |
What gauge speaker wire to use? | SC WRX | Car Audio, Video & Security | 11 | 12-27-2002 10:38 PM |
