06-21-2002, 12:12 PM | #1 |
Member#: 8943
TXIC
Vehicle:2006 MINI + Corvette Both Blue |
Which Race Gas for the WRX?
I have different people telling me 96 or 102 or 110 unleaded race gas as the optimum to use in a 2.0L turbo car. But none of them are specifically familiar with the WRX and how it responds to race gas. I'm setting up an alternate Unichip module that will be tuned for race gas. There are several places in the D/FW area that I can get whatever flavor of race gas I desire, then I can take it with me to the track if they don't already sell that version or a close equivalent. And then I've had some people tell me the blend and the density will be even more important than the octane rating of the race gas. Does anybody here have experience using race gas in the WRX where the WRX was properly tuned for that race gas and it's all working out as desired?
GoodFinder
06-21-2002, 12:28 PM | #2 | |
Member#: 1133
Vehicle:09 GTR, 02 996 C4S 95 993 C4, 71 911, 04 STI |
06-21-2002, 01:08 PM | #3 |
Member#: 1057
Vehicle:2004 WRX STi Very Yellow |
You could theorize, poll various individuals, and take whatever they say as gospel. Or, you could experiment with each variety of fuel that's readily available and see what actually works best for your setup the way you drive. It may be more work, but you'll be a Unichip tuning God by the end of it all, and you'll know for sure instead of just assuming.
$0.02 -Doug |
06-21-2002, 07:03 PM | #4 | |
Member#: 18589
SCIC
Vehicle:2002 WRX, Formerly it was blue |
I know it has been said many times and in many different ways, but what would it be if I didn't try and say,
Now for my own two centavos, I personally mix 2 gallons of TRICK 101 racing fuel, with a tank full of Chevron 91 octane. Now I live in California, so 91 is the max, and we have both summer and winter fuel mixes. On the 91 only, I definitely have a number of stumbles at a number of different RPM's based on the temperature. When I run the mix, the engine runs smoothly upto the rev limiter, with no stumbles. You have to figure that in the rest of the world this car is rated for 95 octance. They obviously have de-tuned the car to handle the 91 minimum requirement. So I would also figure that running 95 would be the best, and peaking at around 98 octane. I don't think there is much benefit past 100 octane, but then no one has shown dyno results from 95 to 100 octane. The higher octane would only help prevent predetonation in very high heat conditions. |
06-21-2002, 07:49 PM | #5 |
Member#: 8943
TXIC
Yes, of course I did a search before posting this thread.
I'm looking for real feedback from people who have used race gas in their WRX at the track. All the threads I found were either conjecture or talking about octane additives or boosters and such. We're going to tune an alternate Unichip module that I'll "hot swap" at the track when I'm running real race gas. Three sites that I found specific information include the following links: Chevron Phillips Sunoco VP Racing For the current race gas tuning sessions we're going to do next week, we'll be using the Chevron Phillips B35 100 octane race gas. If anybody has any real experience running race gas in the WRX, it would be great to hear any feedback, comments, suggestions, observations you can share! Thanks, GoodFinder |
06-21-2002, 09:11 PM | #6 | |
Member#: 3807
SCIC
Vehicle:2002 WRX Sedan Silver, tinted |
Re: Which Race Gas for the WRX?
What type of track are tuning for? 1/4 miler, road course, auto-cross, all of the above? |
06-21-2002, 10:49 PM | #7 |
Member#: 8943
TXIC
(1) Road course - This is my favorite, and where my WRX and I spend most of our spirited driving time. I'd project this is currently 85% of track time.
(2) 1/4 mile drag strip - Just went for the first time a couple of weeks ago. It was interesting and fun to do, and I'd like to do it at least enough so that I'm respectable. Perhaps this will become 10% of track time. (3) Autocross - I've only done it as components to professional driving schools. My impression is that I'm somewhere between "not very good" to "mediocre" or "OK" at best, in autocross. I should probably do more of these, but I guess I've gotten "spoiled" with the variety and amount of road course time I've been doing. Maybe this will get up to something like 5% of track time. GoodFinder |
06-22-2002, 01:27 AM | #8 |
Member#: 1375
Vehicle:2003 WRX Rally Car Silver |
Not sure why I'm posting as I don't have a WRX. I've been running VP Red 105 octane in our Honda rally car for four years. It works well for us. VP makes C-16 112 octane(I think) for high compression turbo applicatons as well.
My VP dealer(insert disclaimer here) is a drag racer and tells me that guys consistently get better bhp on the dyno with VP than Sunoco. Elf is way expensive and hard to get. You can either mix the VP 50/50 with the highest pump octane you can find or run it uncut. Bottom line-try a tank of each and see what you think. Cheers! John |
06-22-2002, 02:24 AM | #9 |
Member#: 18589
SCIC
I didn't think that you could run a leaded gasoline in a newer car, as it would build up too many deposits and ruin the engine and destroy the cats, but if this is a track only car, then forget the cats, and as far as the engine, then only you can answer the question what octane.
If memory servers me well, all gasolines above 105 octane (R+M/2) have to be leaded, as that is the only way to increase energy and octane rating. Chemicals such as toulene and xylene can up the octane ante, but cannot be run 100% as they are typically not volitale enough to run in a standard engine, and do not vaporize well at normal temperatures. So if anyone is recommending above 105, I don't think that is reasonible, unless again you have built the engine for the track, and street legal is not a concern. |
06-22-2002, 09:23 AM | #10 |
Member#: 1375
http://www.vpracingfuels.com/
VP has a "Motorsport 103," street legal gas they sell. From VP's site, "VP RED A great standard grade of racing fuel. Used in any high compression race engine up to 13:1, off-road racing, marine engines, motocross, karts and personal watercraft. " "C16 Used in: Turbocharged engines, blown engines and nitrous applications. NHRA Comp Eliminator spec fuel. Recommended by the top nitrous oxide companies. • Color: Blue • Lead: 6 Grams per gallon • Motor Octane: 117 • Specific gravity: .730 at 60° F" Definitely do a search yourself and try the different gas to see what you like. Whatever series you race in may have specific requirements regarding the type of fuel(leaded or unleaded). Also: http://www.racegas.com/Racegas/default.asp They have a 104 octane GT plus unleaded. Please research the unleaded/leaded fuel debate. I know that I was mis-informed when I started shopping for race fuel. Cheers! John |
06-23-2002, 01:14 PM | #11 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
remember leaded gas will kill your O2 sensors
110 Octane Race Gas at the pump in Greenville SC! | Porter | South East Region Forum | 15 | 04-21-2013 09:14 AM |
Who is making 93 gas from 91 and race gas for daily driving??? | BBBsti LTD | Southern California Impreza Club Forum -- SCIC | 4 | 05-12-2007 02:33 AM |
Race gas in the the BWI area | shaneswrx | Mid Atlantic Impreza Club -- MAIC | 3 | 08-13-2004 04:22 PM |
Which Race Gas to buy | roybfr | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 05-20-2003 09:16 AM |
Which is the best performance/quiet exhaust for the WRX? | SubaruWrx-TKO | Newbies & FAQs | 2 | 08-12-2002 02:12 AM |
