07-07-2005, 06:16 PM | #1 |
Member#: 81225
Vehicle:2002 wrx wagon WRB |
NY: WTB stock wagon strut and knuckle assembly
Hello,
I need a front right stock strut for a 02/03 WRX wagon and the knuckle assembly that the bottom of the strut bolts to. Apparently I was sold a car with crash damage that I did not discover until I had it aligned. Both my strut and the knuckle assembly are bent. I would prefer a strut with low miles. In case you don’t know the knuckle assembly is the cast assembly that the bottom of the strut and the brake caliper bolt to. It has a bearing in the center of it. Someone with a crashed wagon may be able to spare this piece if it wasn’t damage in the crash. Let me know what you have and how much you want for it. Thanks. Mike
07-07-2005, 09:32 PM | #2 |
Member#: 83497
Vehicle:2002 WRX Wagon World Rally Blue |
I Have A set of 4 from my 2002 wagon That I wanted to try and sell together. But for, $100 (shipped) I'd split em up. They only have 33,000 mi and are in good shape.
07-08-2005, 11:09 AM | #3 |
Member Sales Rating: (55)
Member#: 1581
Vehicle:MY00 RS/STi7 MY01 RS Both Silverthorne |
I have one from an RS with 15k on it. Wagons and RS's should be the same. PM me if you're interested. Includes knuckle, hub, bearing, backing plate, etc.
Pic here: http://gallery13273.fotopic.net/c34974_85.html |
07-08-2005, 04:06 PM | #4 |
Member#: 81225
garface,
Is it from a 02/03 RS? If so I will check with my mechanic to see if they are interchangeable. Also, you can pm me with how much you want for it. Thanks. Mike |
07-08-2005, 04:19 PM | #5 |
Member#: 1581
It's from an 01 GC RS. A GD RS would be less likely to fit as the GC shares the same suspension setup as the WRX wagon.
07-13-2005, 09:00 AM | #12 |
Member#: 1581
I think my GC one will work if you're that desperate. Is there any way for you to find out? How far are you from NYC? If not too far, you can bring yours down and compare it to this one.
07-13-2005, 10:48 AM | #13 |
Member#: 81225
Garface,
My mechanic is checking the part numbers for me to see if your part will work. He hasn't got back to me yet. I will let you know when I hear from him. Thanks. Mike |
07-13-2005, 11:06 AM | #14 |
Member#: 1581
Ok, let me know. But I can almost gaurantee the numbers are different even if the parts are the same, so sometimes that doesn't help.
FS: 2006 stock sti strut and shock assembly | jrunz02 | Suspension/Brakes/Handling | 0 | 10-10-2008 06:34 PM |
WTB Stock Wagon struts with housings in good shape... | joe-6STi | TXIC Private Classifieds | 1 | 02-28-2008 01:53 AM |
WTB Stock WRX shifter and pedal assembly | sicksubie | NESIC Private Classifieds | 3 | 12-26-2006 10:59 AM |
Difference between stock wagon struts and sedan struts? | affinity1 | Brakes, Steering & Suspension | 16 | 04-27-2006 02:34 PM |
FS: Stock WRX struts and spring assemblies | jnmarshall | Private 'For Sale' Classifieds | 0 | 10-29-2003 06:16 PM |
