12-11-2008, 06:54 AM | #1 |
Member#: 188828
Vehicle:2001 Bugeye WRX Silver |
Difference Between Forester And Wrx Gearbox?
Is there a difference between a forester and wrx gearbox in relation to a 2001 bugeye wrx?
Will a forester box fit and work in a 02 wrx? Is there a difference in gear ratios? If so does anybody know? Thanks,
12-11-2008, 07:19 AM | #2 |
Member#: 113772
RMIC
Vehicle:2006 WRX Wagon vf39 WRB |
I know that foresters have a shorter final drive. I think they are 4.11 vs 3.9 in the WRX (3.7 for 06-07).
12-11-2008, 07:47 AM | #3 |
Big Ron
Super Moderator Member#: 18062
You are talking about cars we don't have. Visit the MRT Forums and talk to them.
12-11-2008, 11:43 AM | #4 |
Member#: 152117
SCIC
Vehicle:2012 Ford F150 ECO White |
12-11-2008, 11:46 AM | #5 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
12-11-2008, 02:13 PM | #6 |
Member#: 123347
NWIC
Vehicle:1993 POS burgandy legacy |
12-11-2008, 06:02 PM | #7 |
Member#: 161678
Vehicle:2002 wrx V5 RA swap Black |
I have one in my car....... the final drive is 4.44 in only some years of the 5 speed and alot of the autos. They do come in 4.11 also and is more common in the 5 speeds. The gearing is the same otherwise so there is still a big gap from 1st to 2nd but the 4.44 helps alot still. After i did mine i figured out the a 05 LGT trans and rear end would be a better option as the gears are cloaser and final drive is 4.11. But if you have a good deal on a forester trans its a decent option but you will need the rear end too of coarse. What year is the forester trans your looking at?
It bolts right up.... rear end fit right in no axle issues or anything. My wrx clutch and flywheel worked. It's basically the same trans with different FD and 1:1 center transfer gears instead of the stupid 1.1:1 transfer gears the wrx has. We put a wrx lsd in the front of the forester trans so it worked with my front axles but normally the forester does not have axle stubs so i believe you will need forester front axles unless you swap front diffs like we did. Hope this helps |
12-11-2008, 06:08 PM | #8 |
Member#: 161678
sorry i didn't notice the 2001 wrx part so not sure if anything i said is true for the 2001 wrx fitment
12-11-2008, 06:26 PM | #9 |
Member#: 188828
Its a 2001 bugeye wrx, in AUS they started in 2001.
And yes we have forester's and forester gt's available here in AUS. I raised this quesiton because i just had my clutch replaced with a exedy sports tuff heavy duty clutch, dunno if you guys have heard of that brand there, but when they pulled it apart they found that its a actual forester gearbox in the car. |
12-11-2008, 09:38 PM | #10 |
Member#: 161678
Well being that you are not in the US, all your trans could be geared defferntly then ours but if you have the trans code we can find what gearing you do indeed have.......
Difference Between Forester and WRX? | fastbluewrx07 | Impreza Forum | 4 | 09-07-2007 11:39 PM |
The difference between RS and WRX | BiCHaZzkrN | Newbies & FAQs | 32 | 04-09-2003 08:37 PM |
Perf. gauge pack, difference between forester and gc8 | mattjb | Normally Aspirated Powertrain | 3 | 03-21-2003 12:00 PM |
Difference between RS and WRX 02 shell | gr8wheels | Newbies & FAQs | 2 | 09-29-2002 11:38 PM |
