Brakes & Suspension Forum sponsored by The Tire Rack |
04-25-2002, 04:00 PM | #1 |
Member#: 11221
Vehicle:2002 2.5 RS Black as Midnight!!! |
RS > WRX Suspension swap?
Shoudl I do it (swap my RS suspension to a used WRX suspension)? Could I only swap out the springs (im assuming the spring rates are different)?
Whats the actual differences between the RS and WRX suspension?
04-25-2002, 04:17 PM | #2 |
Member#: 6821
Vehicle:2006 Scion TC Mica |
The springs make a diff, but if you spend any money on labor, just buy a set of stiffer lowering springs like Eibach. They are better than the stock WRX. The struts are the same. The strut tops are different.
04-25-2002, 08:04 PM | #3 |
Member#: 11221
I dont wanna lower my car, plus Im cheap, what can I say.
If I can get a set of springs for like 50$ off the club here and install them and get a better suspension...im all for it. Instead of spending like 300+ for a lowered suspension that I really dont like (i dont like lowered WRX's....plus I take my RS off road sometimes) |
04-25-2002, 09:51 PM | #4 |
Member#: 15552
Vehicle:'87 Hutch TRICKSTAR babyblue on pinkTuff II's |
WRX Suspension
DDman,
Sorry to intrude on your thread, but if you're interested, I have some low mileage WRX stock suspension pieces for sale: Stock Struts $175 for 4....Used only 1500 miles Stock Springs $75...Used only 1500 miles Stock Front Swaybar $75... Used only 500 miles I am willing to discount if you purchase 2 or more items. Please EMAIL me if you're interested....NO PM's PLEASE, I rarely check my PM box. Regards, Curtis L. [email protected] |
04-26-2002, 09:12 AM | #5 |
Member#: 14722
Vehicle:2008 Impreza WRX STi Dark Grey |
DDMAN,
I'm planning to do the same with my 2002 RS. And I found out that the RS and WRX Sedan use the same springs and same struts (same p/n). Only the sway-bar differs. I know the rear sway-bar can be switched, but I don't know about the front one. I was going to open a topic on switching the front sway-bar... Has anybody done it yet ? |
04-26-2002, 01:51 PM | #6 |
Member#: 6821
Check that
I know the strut part numbers are the same between RS and WRX in '02 but I didn't think the springs were the same. Any RS owner should get at least a 20mm rear bar immediately.
Eibach springs really only lower the car to the amount considered normal in other cars. The heavier spring is an improvement. There may be a heavier aftermarket spring that only lowers 1/2". Get new tires and wheels, it makes a huge difference. |
04-26-2002, 03:51 PM | #7 |
Member#: 11221
Ya...
I already have the 20mm sway bar, and Just wasnt sure how much of a difference the WRX springs would make. Thanks all! |
04-27-2002, 01:48 AM | #8 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
Find an AUTOMATIC WRX springs, they are even stiffer than the manuals (just a little, and dont shoot the messanger cause it was SOA who gave us the actual spring rates awhile back)
RS -> WRX Brake swap beware! | DDMan | Brakes, Steering & Suspension | 25 | 03-17-2010 12:01 PM |
Suspension options for '02 WRX suspension-swapped BD | mattwalters | Brakes, Steering & Suspension | 10 | 12-06-2007 12:32 PM |
FS Local: RS -> WRX brake swap parts. | DDMan | Bay Area Impreza Club Forum -- BAIC | 5 | 07-23-2003 04:19 PM |
RS -> WRX swaybar swap | DDMan | Brakes, Steering & Suspension | 5 | 01-28-2002 04:13 PM |
RS -> WRX airbag swap.... | DoorKnob | Bay Area Impreza Club Forum -- BAIC | 0 | 10-28-2001 12:30 AM |
