12-09-2008, 02:01 PM | #1 |
Vendor Sales Rating: (47)
Member#: 173316
VIC
Vehicle:'18 STi Type RA White |
Beat the exchange rate at Dales Alignment and Brake
Here is what we have remaining in stock for Whiteline and Racecomp Engineering. The product was purchased at $1.05/US and everyone knows where the dollar is hovering now.
Here is what we have: Whiteline swaybars, upper strutbars, anti-lift kits, bushings and endlinks: Front swaybars: BSF10-$180 BSF30xz-$260 BSF33XZ x2-$220 BSF36xz x2-$220 BSF39XZ-$260 Rear Swaybar: BSR36Z-$220 BSR36XZ-$250 BSR37XZ x2-$250 BSR49XZ-$260 Swaybar endlinks: KLC32-$145/set KLC39 x3-$145/set KLC044 x3-$175/set KLC 047 x3-$150/set KLC066 '08-09 GRB-$170/set Strutbars/4 pt brace: KSB599 x2-$200 KSB511 x2-$200 KSB723 '08-09 GRB-$245 Frt upper strut brace KSB568 '08-09 GRB-$245 4 pt brace Anti-lift kits and bushings: KCA362 x2-$280 sport series KCA334 x2 '08-09 GRB-$80 Rack bushings for all applications Racecomp Engineering RCE Tarmac Zero Built by KW Suspension in Germany to our specs, these use the same high quality stainless steel corrosion resistant construction as our RCE T2s. The difference here is the Tarmac Zeroes have preset damping that maximizes both performance and ride quality. This allows the end user to just put them on and drive without worrying about playing with too many adjustments. It also keeps them more affordable. Ride height is still adjustable of course. Linear spring rates: 400 lbs/in front 340 lbs/in rear $1950 RCE Kool Brake Ducts-These are for the Track Guys-Comes with aircraft style ducting and hardware for mounting $459-1 kit remaining Vorshlag Frt/rr Camberplates- Camber adj. for the front and rear of your car. Excellent for cars that need that extra bit of neg. camber(Cars with R-compound tires and low off-set wheels). No more camberbolts that slip. $549/set RCE Springs Yellows-Extensive research, design, and testing was performed to develop a completely new spring unlike anything currently available. With springs rates increased approximately 25% stiffer then the popular JDM Pink Springs, the springs are perfect for those with wider tires worried about rubbing, as well those looking for a little more rear spring rate to promote a more neutral handling characteristic. Much care was taken not to exceed the limits of the stock struts. The mildly progressive design and spring rates properly matched with the dampers ensure that ride quality is not diminished over stock. The car is lowered 20mm in the rear and 23mm in the front for an even look. Blacks-Regular Guy-Using similar spring rates as the extremely popular and successful RCE Yellow Springs, but having a much more subtle/mild drop in comparison, these are perfect for STi owners not looking for a ride height much lower then stock, and yet are still looking for increased spring rates. Spring rates are still 10% stiffer then JDM Pinks with an emphasis on the rear rate, so you will still be outpacing just about everything on the track and auto-x course. Wagon-Using similar spring rates as the extremely popular and successful RCE Yellow Springs, but having a wagon specific ride height, these are perfect for wagon owners not looking to compromise either ride height or spring rates $349/set RCE Swaybars-05+STi only Front bar-$290ea. Rear bar-$200ea.
__________________
[CENTER] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [B][I][COLOR="Red"] "We do pricing a little differently. Every price you see includes the shipping cost to our office(Surrey, BC), duties and exchange rate . This creates a built in cost savings, no hidden fees, and less hassles. The best part is we still have a price match guarantee!"[/COLOR][/I] [/B] [COLOR=black]Service Center: 604-530-9160 Toll Free 1 (855) 214-2670[/COLOR] [COLOR=black]Email- [/COLOR] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] Last edited by dalesmotorsport; 12-09-2008 at 06:53 PM. |
Similar Threads | ||||
Dales Alignment and Brake also sells tires | dalesmotorsport | VIC Vendor Classifieds | 0 | 04-11-2010 06:06 PM |
Deal of the day thread-Dales Alignment and Brake | dalesmotorsport | Canada Region Vendor Classifieds | 4 | 02-28-2010 12:52 PM |
Beat the exchange rate at Dales Alignment(Canadian customers) | dalesmotorsport | Suspension/Brakes/Handling | 1 | 12-11-2008 01:49 AM |
Beat the exchange rate at Dales Alignment/Dales Motorsport | dalesmotorsport | Canada Region Vendor Classifieds | 0 | 12-09-2008 10:37 PM |
Dales Alignment and Brake are Racecomp Engineering Canadian distributor | dalesmotorsport | Canada Region Vendor Classifieds | 0 | 03-08-2008 09:44 AM |
