Welcome to the North American Subaru Impreza Owners Club Wednesday April 16, 2014
Old 12-27-2002, 06:44 AM   #1
thebusiness999
Member#: 3767
2008 BMW 135i !!!
Jet Black
Default Can a Subaru dealer reflash the stock ECU?
The subject says it all...I lost my FBC settings and am now forced to run boost based on the wastegate spring. It seems like this has happened to some people who switched from MBC or EBC back to factory boost control.
I'm taking it to the dealer on Monday and was wondering if they'd be able to reflash the stock ECU and get my car boosting as it should again. Any idea how much it costs?
Paul
thebusiness999 is offline   Reply With Quote
Old 12-27-2002, 10:34 AM   #2
cmaj7
Member#: 12677
2002 Subaru WRX
WR Blue
Default Yep
My brother had a problem with his 02 WRX Wagon. The problem was the ECU and a reflash fixed it.
Also, there has been at least one recall for which the fix was a reflash! Call your local "mod friendly" Subaru dealer!
cmaj7 is offline   Reply With Quote
Old 12-27-2002, 11:13 AM   #3
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
A reflsah shouldn't fix that sort of problem, as there is no way you can change what's in the ECU with anything you do.
I also don't beleive the dealers have the facility to reflash an ecu, if they did, why would Prodrive be using Ecutek to do the next gen PPP upgrades?
I think what the dealer did was to RESET the ecu. There is a change that the ECU is running in safemode, which will remove all boost conrol except the actuator.
Try disconnecting the battery for half an hour, as that's an easy way to reset the ECU.
Paul
Pavlo is offline   Reply With Quote
Old 12-27-2002, 03:07 PM   #4
thebusiness999
Member#: 3767
2008 BMW 135i !!!
Jet Black
I think my ECU has been reset at least twice in the process of putting my new engine in it, and I've still been unable to make full boost.
The battery is disconnected right now...we'll see what happens.
Old 12-27-2002, 05:10 PM   #5
Pavlo
Member#: 23015
95-> GC8
The oter thing of course is that there is something that makes the ECU think you have a problem.
If the ECU detects things like abnormal MAF sensr reading, incorrect idle control, constant detonation (unlikely) then if will continue in safe mode.
It varies over the years, but I think the ECU will come out of safe mode after 10km of safe normal activity. Obviously if the thing causing the fault is remaining then you'll be going into safemode all the time.
I don't know how to get the error codes up on the new cars, (there are some connectors under the dash anyone can use on the older cars) but that may tell you what's up. The thing is, the sorts of errors that can cause safemode, don't always trigger a constant CEL (check engine light on dashboard), so you may have a problem but not know.
Did you disturb any of the wiring, connectors or plumbing?
paul
Old 12-28-2002, 12:07 AM   #6
cmaj7
Member#: 12677
2002 Subaru WRX
WR Blue
Paul
The dealer has the ability to re-flash the ECU with code provided by Subaru, this is completely different from using an application such as ECUTEK's which allows you to create and customize maps.
The dealer did not simply reset the ECU, they reflashed it.
Here is another thread where this has been discussed
http://forums.nasioc.com/forums/show...call+flash+ecu
Old 12-28-2002, 12:38 AM   #7
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
it's most likely the plumbing and not the ecu. Check to make sure there is a restrictor in the line that goes from the turbo niplple, before the "T". If you don't, there is your problem.
Alex...
amelnikov is offline   Reply With Quote
Old 12-28-2002, 12:43 AM   #8
Full_Clip
Member#: 22218
Basically everyone is saying the same correct info. Plumbing is probably screwed, stock ECU running in safemode. Take it to the dealer if you don't have too many mods.
Full_Clip drove his Accord 1500 mi without the vacuum line plugged in.
Full_Clip is offline   Reply With Quote
Old 12-28-2002, 06:10 AM   #9
thebusiness999
Member#: 3767
2008 BMW 135i !!!
Jet Black
I compared my plumbing to some untouched WRXs and it's identical to theirs...the only difference between my car and theirs is that from this past summer up until a month ago, my car was using an AVC-R for boost control, with the stock solenoid just sitting idle under the little plastic cover in the engine bay.
I do have that little brass restrictor and it's in the hose coming off the compressor side of the turbo...
I have an appointment scheduled with the dealer for Monday morning...if I can't fix this by then, maybe they'll figure it out.
Any other ideas?
Can the dealer reflash a modified ECU? chimchimm5 General Community 12 02-08-2008 02:29 PM
removing utec do i need to get the stock ecu reflashed to stock phobos sti UTEC 12 09-07-2007 12:02 AM
Can a Subaru dealer tell if an ECU has been EcuTek flashed? benw Commercial ECU Reflashes 6 01-15-2007 04:16 PM
Subaru wants to reflash my stock ecu for free... why? brewdude Factory 2.0L Turbo Powertrain 15 10-21-2004 10:52 PM
Can I get away using the stock ecu...... pwrphrk Factory 2.0L Turbo Powertrain 4 08-02-2002 12:36 AM
