09-08-2004, 11:07 PM | #1 |
Member#: 52583
Vehicle:2002 WRX sedan ej207 PSM |
egt probe in the collector?
I have done some searches on where to mount the probe to an egt gauge and it seems like no one mounts it in the manifold collector. I know that cylinder #4 seems to run the hottest and a lot of you guys mount the probe on the casting button of the driver manifold but what if you have a problem with one of the other cylinders that arent tapped? I think I am going to mount my probe in the collector unless someone can give me a reason not to.
Also, what do you guys think the temp difference will be if I mount it in the collector since my probe will be a little farther down stream? Thanks.
09-09-2004, 12:42 AM | #2 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
Unless you install 4 you should pick one(or 2, really) and be done with it.....That is why the casting button on the drivers side is picked so often....'cuz it's in a good place and it's easy.
How to wire the Team RIP egt probe into the Greddy egt harness | impactblue | Electrical & Lighting | 3 | 03-12-2007 08:54 PM |
For those with their EGT probe in the uppipe | scoobyimprza | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 04-20-2004 01:17 AM |
who has there egt probe in the DP? | blackie | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 02-09-2004 07:23 PM |
Any way around the EGT probe in the U/P? | Need4Boost | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 08-23-2003 05:40 AM |
finally got my EGT probe in | RidinLow | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 23 | 09-07-2001 03:37 PM |
