Brakes & Suspension Forum sponsored by The Tire Rack |
11-13-2012, 02:59 PM | #51 |
Member#: 267863
SCIC
Vehicle:1998 Outback |
11-23-2012, 03:37 PM | #52 |
Member#: 196920
South East
Vehicle:03 Wrx WRB |
Bump??
12-06-2012, 03:02 PM | #53 | |
Member#: 222879
Tri-State
Vehicle:2015 STI ISM |
If i am going to go through the process of upgrading my brakes then the real question is why not? Calipers are about 500 new or about 700 for Porsche 6 pot radials used Pads 130 new Z06 350mm Rotors about 200 new for standard construction or another brand for the Porsche fitment Custom stainless lines 60 @ hydraulic shop Rotor pattern re-drill 100 for non STI Steel brackets 6 hours or so worth of work if they arent radial mounts and less if they are radials. Hub centric rings for the rotors x2 $30 To me this is just better than spending all that money for Sti Brembos or buying some cheap kit that wont hold to any kind of abuse. |
12-11-2012, 06:04 PM | #54 |
Member#: 267863
SCIC
just bumping this to see if theres any news.
12-17-2012, 11:25 PM | #55 |
Member#: 196920
South East
Any news WRXBrakes?
12-18-2012, 10:59 AM | #56 |
Member#: 125739
South East
Vehicle:2007 1500HD Need Brakes? 919.420.0021 |
Got delayed a bit sorry.
Designer is on it now so we should be making a prototype for fitment within a week or so. |
12-18-2012, 04:39 PM | #57 |
Member#: 267863
SCIC
^awesome. i guess now i can get on rebuilding my calipers
12-19-2012, 06:42 PM | #58 |
Member#: 196920
South East
Bossin. Are front and rear brackets being made up?
12-19-2012, 07:27 PM | #59 |
Member#: 125739
South East
12-19-2012, 08:30 PM | #60 |
Member#: 220619
MAIC
Vehicle:04 wrx wagon silver |
sooooooo much better than what i had. the one i bought used some janky looking hardware and a random number of washers as spacers. this looks rock solid.
12-21-2012, 02:22 PM | #61 |
Member#: 125739
South East
I can have these ready in a few weeks.
I need about 5 players to start the game. ?? |
12-21-2012, 02:58 PM | #62 |
Member#: 267863
SCIC
Im in. What are we looking at pricewise?
12-21-2012, 03:14 PM | #63 |
Member#: 125739
South East
$140/pair for the first buyers - minimum 5.
That gets the second prototype made so we can triple check and adds new good hardware. Retail after that -$160/pair I think unless volume is much higher than I thought. I do have access to everything else needed. Rebuilt cardones calipers, and of course pads/rotors etc. |
12-21-2012, 03:24 PM | #64 |
Member#: 125739
South East
Probably have to stop the pricing in here and take it to the group buy section or vendor announcement.
12-21-2012, 04:59 PM | #65 |
Member#: 127745
NWIC
Vehicle:06 WRX 30r 6 speed 99L EJ255 6 Speed |
Curious...anyone use these? Wha is the front rear balance like? How much are the calipers and pads? What size wheels are needed? Standard or custom brake lines?
12-21-2012, 05:26 PM | #66 |
Member#: 71875
Nice. Think I might go this way instead of the Subaru 4-pots once I wear out my current stuff. Think they'll fit under a 16" RS wheel?
If they piston sizes are the same as the Subaru caliper the bias should be pretty close to WRX 2-pots. |
12-21-2012, 05:46 PM | #67 |
Member#: 125739
South East
The rotors are LGT rotors - so 316mm by 30 mm. Much more heat mass.
The effective radius grows by about 7.5 % so front brake torque will increase. Run it with the H6 Set up in the rear. Probably needs 17's though. |
12-21-2012, 08:27 PM | #68 |
Member#: 267863
SCIC
Pricing is good with me. Couple questions. What year lgt rotors should I be looking for? Would the h6 upgrade be better then the 2pots in the rear? I have a full set of z32 calipers and was planning to run them all around.
12-21-2012, 08:45 PM | #69 |
Member#: 196920
South East
Im in for a pair
12-22-2012, 04:06 AM | #70 |
Member#: 71875
12-26-2012, 12:53 PM | #71 |
Member#: 125739
South East
12-26-2012, 12:54 PM | #72 | |
Member#: 125739
South East
The rear Z32 calipers do bolt on but there is current;y not a convenient rotor solution or bracket solution that I know of. |
12-26-2012, 04:09 PM | #73 |
Member#: 220619
MAIC
Correct me if I'm wrong but the lgt uses 16 inch wheels no? So assuming you use a 16 with enough spoke clearance like the rs wheels they should fit. When I had this setup I was able to put my oem 04 wheels on but the caliper interfered with the spokes.
12-31-2012, 04:12 PM | #74 |
Member#: 82762
South East
Vehicle:2016 Crosstrek Black |
FINALLY! Im in for a pair! I want meow! cant wait!
01-03-2013, 11:02 AM | #75 |
Member#: 82762
South East
any update
Similar Threads | ||||
WTT WRX front rotors/brackets for RS rotors/brackets + WTB WRX rear caliper brackets | Jard | MAIC Private Classifieds | 9 | 11-24-2009 09:38 AM |
WTB: 02+ WRX Front Caliper Brackets, H6 Rear Caliper Brackets | JDMFLCL | Private 'Wanted' Classifieds | 4 | 10-30-2009 01:19 PM |
WTB: Front WRX caliper bracket and rear Legacy caliper bracket | 92XJET | MAIC Private Classifieds | 0 | 11-20-2007 10:37 PM |
WTT: I want YOUR Rs rotors and caliper bracket for MY Wrx caliper bracket and rotors | scobaru | MWSOC Private Classifieds | 6 | 12-10-2006 08:02 AM |
WTB: WRX Caliper Brackets + H6 Caliper Brackets | Krelkor | Private 'Wanted' Classifieds | 11 | 07-12-2004 03:28 PM |
