04-22-2001, 07:50 PM | #1 |
Member#: 5413
Vehicle:#15 2-Subaru Rally Cars !!! Fiesta! |
Air to water intercooler???
Does anyone know where I can get an intercooler like this?
Air to Water
04-22-2001, 07:51 PM | #2 |
Ghost Mod
Moderator Member#: 1278
NWIC
Vehicle:2001 RS Aspen White |
Legacy turbo's use em...
Try PM'ing blaster88 or Stimpy. I think they have a contact who can get them. [This message has been edited by SkToBe (edited April 22, 2001).] |
04-22-2001, 08:07 PM | #3 |
Member#: 881
Vehicle:2004 WRX Grey |
04-23-2001, 05:05 AM | #4 |
Member#: 4084
we have them $100 plus shipping silver or black see ya steve 714 994-5222 in ca.
04-23-2001, 05:54 AM | #5 |
Member#: 1109
Vehicle:1999 Suzuki Samurai Blackish |
The ones from Outback are from the Legacy turbo, they are either black or silver with a "SUBARU TURBO INTERCOOLER" sticker on them. It looks way cool:
<IMG SRC="http://www.beergate.com/images/scoop.jpg" border=0> The inlet from the turbo is a round tube underneath, so it would be easy to hook up. You will have to get a pump and heat exchanger for it - I use a Whale GP99 inline pump that I got from WestMarine.com for $55 or so. I use a transmission cooler core mounted behind the grille to be the heat exchanger. |
04-24-2001, 05:45 PM | #6 |
Member#: 6070
South East
Vehicle:2015 STi Dark Gray Metallic |
Spearco makes A/W intercoolers to your spec. I may have one made for my SVX turbo. Its designed, I just need to finish the front bumper for a radiator. Why do you want one though? Air to air is much lighter, and the gains might not be that great due to the additional weight of a radiator. If you are adding an ice water reservoir for dragging then the A/W might be better. But for anything else, not worth the money for minimal gains, if any.
Having said that, I will be doing one on my SVX due to space constraints. Barely got the turbo in. |
04-24-2001, 11:05 PM | #7 |
Member#: 3968
will the air to water reduce substantially lose of boost pressure. Meaning is the inlet distance long enough on the impreza to cause boost pressure degradation.
Can water/alcohol injection solve the problem instead. |
How well do air to water intercoolers work w/ an air to air heat exchanger? | sumfoo1 | Water/Methanol Injection, Nitrous & Intercooler Cooling | 5 | 07-30-2007 09:31 PM |
where to get a aluminum radiator core. enough to cool my air to water intercooler | STEALTH-WRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 24 | 06-07-2003 09:14 AM |
air to water intercooler question | Jaxx | Normally Aspirated with bolt-on Forced Induction Powertrain | 3 | 01-22-2003 10:41 PM |
Air-to-water intercooler installed!! | davidm_sh | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 71 | 04-18-2002 01:34 AM |
air to water intercooler $300 range | jdchmiel | Normally Aspirated Powertrain | 19 | 02-10-2001 04:27 PM |
