08-12-2003, 02:24 PM | #1 |
Member#: 15799
MAIC
2002 WRX Engine Oil low by 2.75 Quarts
I'm an Idiot.
Got my oil changed by mechanic 2 months ago. Didn't check oil level. Coming to a stop at the bottom of a hill this AM, oil light blinks on and off. I turn the engine off immediately 'til light turns and then pull off the road. check oil, it's off the bottom of the scale!!! so I let it cool, then start her up. no Oil light. I drive 2 miles to auto parts store (no oil light) and have to put 2.75 quarts of oil in her. I think this is how I roached my turbo which made buzzsaw sound when not freshly warm and stopped boosting past .095 MPa (should go to .12) Would that kill the turbo? Do you think I damaged my engine? I'm a idiot. |
08-12-2003, 07:59 PM | #2 |
Member#: 34672
Vehicle:2003 wrx WR Blue Pearl |
"Would that kill the turbo?"
Yes. "Do you think I damaged my engine?" Yes. |
08-12-2003, 08:21 PM | #3 |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
Re: 2002 WRX Engine Oil low by 2.75 Quarts
1. Didn't check oil level.
Not real smart - always check once a week or so (you have a turbo which spins at a gazillion rpm and uses an oil film as a bearing - bad things happen when the oil isn't there) 2. Coming to a stop at the bottom of a hill this AM, oil light blinks on and off. The oil light is for pressure, not level, so it coming on isn't necessarily all that bad - it's a warning light, not a "hey, you just killed your engine" light (which is a good thing!) 3. I think this is how I roached my turbo which made buzzsaw sound when not freshly warm and stopped boosting past .095 MPa (should go to .12) if you are running the stock turbo + boost control, 0.095MPa is pretty normal depending on the conditions. The buzzsaw sound can't be a good thing, though... 4. Would that kill the turbo? Well - it certainly could kill the turbo, and it's very possible you damaged the bearing/bushing, but the fact that it still makes boost is a good sign - it's not dead yet! 5. Do you think I damaged my engine? No - probably not - the turbo may have been damaged a bit, but it's more sensitive than the rest of the engine to changes in oil pressure - unfortunately, only time will tell... drive for a while and see how it behaves This is one of the reasons I maintain my cars myself, and always keep an eye on things like coolant and oil/trans fluid levels, tire pressure, etc. |
Similar Threads | ||||
2002 WRX silver Loaded! low miles and price | dennischi | Private Vehicle 'For Sale' Classifieds | 7 | 02-25-2005 05:57 PM |
2002 USDM WRX Engine Complete Low miles | Hopper | Private 'For Sale' Classifieds | 1 | 07-23-2004 01:57 AM |
2002 wrx engine swap with 2.5RS? | huey | Normally Aspirated Powertrain | 8 | 01-30-2001 12:23 AM |
2002 WRX engine in 2.5 rs ? | Greg555 | Normally Aspirated Powertrain | 3 | 01-10-2001 02:51 PM |
