04-14-2002, 09:21 PM | #51 |
Member#: 8725
Vehicle:2013 Black Company Annalist |
So again, is anyone else with this problem running any kind of aftermarket pulley?
06-05-2002, 02:24 PM | #52 |
Member#: 16453
Last week, my 1986 Toyota Corolla power steering rack developed an unrepairable leak. Since, I have been driving it without power steering. It is really good for upper body muscle development and fitness.
06-12-2002, 12:58 PM | #53 |
Member#: 18642
Vehicle:2005 Impreza WRX STi |
My Turn !
Ok, I did my first oil change two weeks ago and noticed the power steering hard lines were leaking. Didn't surprise me 'cause I had read this post before even buying the car.
BTW, this is the break in period oil change. Car had 1300 miles and reservoir was below minimum level by two inches. Took it to the dealer this morning thinking they would just tighten it up. I simply could not get a wrench on the things 'cause the passenger side half shaft was in the way. Dealer says the rack itself is leaking ( not what I saw) and that a new one has been ordred and expected in in 4 days. I bought the car in May, so it's definitely not just a first batch problem. Gonzalo. |
10-19-2002, 04:00 PM | #54 |
Member#: 8062
Vehicle:2002 WRX Silver |
Found the thread on power steering lines leaking...
Mine finally leaked...already posted in the service forum. Maybe my question on alternate ps fluid should be posted there instead of here....off I go! Ted |
10-19-2002, 10:19 PM | #55 |
Member#: 456
Vehicle:2008 Forester XT Steel Gray Metallic |
My 2nd WRX (10/02 delivery) developed a slow leak two weeks ago (I tightened up the fitting but the o-ring was damaged so had to take to dealer).
So, I'm 2/2 on leaky WRX PS! I had snugged up the pipes under the engine x-member, but this was in the coupling up to the pump/res. Glenn |
11-10-2002, 04:28 PM | #56 |
Member#: 8002
Vehicle:2017 WRX /Abarth DGM /Nero |
I too had this problem about a month ago, lines came loose took it in and had them fix it. happened at about 13k
01-08-2003, 12:42 AM | #57 |
Member#: 18544
I shall see in 2 days (that's when i can stop by a dealer with the car), but so far i have no power anywhere under 2000rpm and i know that means trouble
i haven't checked the lines yet, but will do so 1st thing in the daylight Bart |
03-12-2003, 02:10 PM | #58 |
Hoodbridge!
Moderator Member#: 560
Vehicle:2006 STi, 16 Outback Crystal Gray, Silver |
I had the power steering fail tiday. Looks like the same problem. Loose fittings. I haven't crawled under the car yet, but there was a lot of smoke and after I sat for about 5 minutes, you could see it dripping out. Time to go see if I can fix it.
03-13-2003, 10:17 AM | #59 | |
Hoodbridge!
Glenn Wallace posted this:
Sure enough it was so loose I could turn it with my fingers. Tightened it down, along with the 14mm nut, and replaced the PS fluid, but I still seem to have a small leak. Is there some sort of gasket I need to replace here? Where are the 4 bolts and 2 nuts that Glenn's talking about? Thanks, Tim |
10-02-2003, 10:57 PM | #60 |
Member#: 35004
TXIC
Vehicle:88 __/ ] \_/ . -o-----o- ///M5 |
I had some fitting come loose on the power steering pressure line too. The jack plate was covered in fluid along with the passenger side control arm. It looks pretty tough to get to. I can see the leaky fitting from a half-dollar sized hole on the passenger side next to the jack plate. I caught the leak before my PS went out and I topped off the tank with some Cheap ATF dextron III. I dont think that taking off the Jack plate will make it easier to get to theis fitting, but I'll check it out tomarrow again.
11-01-2003, 12:10 AM | #61 |
Member#: 31770
Vehicle:02 WRX Spwgn BLACK |
Lost all my fluid from the rubber hose connection to the hard line just past the intake tonight, lots of smoke and fluid on the passenger side of the engine bay, will top up and take it to the dealer on Monday.
Floyd |
08-13-2004, 01:37 PM | #62 |
Member#: 25003
Vehicle:2004 Forester XT Platinum Silver |
My power steering failed yesterday. Lots of smoke. Scary. Anyway, drove it to the dealership and they tightened the lines, flushed the system and refilled it. They then charged me $114. I have 36.5k on the car (03 WRX wagon). With the # of posts here there should be a TSB out for this issue.....
09-27-2004, 11:46 AM | #63 |
Member#: 19732
Vehicle:2002 WRX Wagon Blackish |
Just happened to me, too, at 52K miles. Fortunately it happened in a parking lot full of people with jacks and tools! One person even knew about this problem, so he told me I probably had a loose PSF line nut. I was able to tighten the high-pressure hose nut, full it up, and limp it home.
It's still leaking fluid, though, so I guess I'll get it up on ramps and try to clean it up and tighten it better. If that doesn't work, is there a more permanent fix? I'm not willing to keep tightening that stupid bolt every 3 weeks. |
09-28-2004, 03:37 PM | #64 | |
Member#: 4431
Vehicle:MY07 STi and '06 WRX Urban Grey & WRC Blue |
Turned out both of mine had it - wagon had loose lines as well
My problem now is the bushes on the rack itself - rack has 2mm wide clean patches on each side where the rack is shifting Quote:
09-28-2004, 06:58 PM | #65 | |
Member#: 456
Glenn |
09-30-2004, 10:05 AM | #66 |
Member#: 35004
TXIC
Yes, I simply tighted mine (high pressure line) It did work for a day, Then it failed miserably. Im talking fluid literally pouring on to the ground once the motor started. Intense smokeing since all the fluid just leaked on to the downpipe (probably dangerous). I had no choice other than let the pump run dry. I took it to the dealer and this was covered on my warranty. Indeed...the o-ring was fouled.
10-14-2004, 03:57 AM | #67 |
RIP
Member#: 38867
Vehicle:11 Mazda |
Yep. Leaks at the hard line to rubber hose connection on my '04 STi... Taking it to dealer tomorrow.
Adam |
01-25-2005, 10:45 PM | #68 |
Member#: 13967
SCIC
Vehicle:Bye Bye STI!!! |
Anybody have a picture of what I need to look for?
01-26-2005, 12:28 AM | #69 |
RIP
Member#: 38867
Vehicle:11 Mazda |
It's in the vicinity of the front right axle... To the left of the downpipe... IIRC.
I'll snap a few pics tommorrow for you. Im a pot head so send me a PM to remind me, Adam |
01-26-2005, 01:57 AM | #70 |
Member#: 19732
It's been months, but the lines have held and my PS Fluid levels are steady. I guess tightening it does the trick as long as you are careful and don't damage anything when you tighten it back up.
Good luck, everyone! |
01-26-2005, 10:26 AM | #71 |
Member#: 61007
Vehicle:03 wrx blue |
my cars in the shop right now cause my powersteering pump broke and my resovior(however you spell it)
01-26-2005, 04:10 PM | #72 | |
Member#: 4431
That's basically what happened to Subie Gal. Lines let loose and started an engine bay fire - still having electrical issues as a result |
11-30-2008, 01:28 PM | #73 |
Member#: 170432
SCIC
Vehicle:3076 Apollo Rotation |
Hey, reviving an old thread, did anybody ever find a new fitting or did you guys just try to tighten?
I made a very costly mistake when I overtightened the fitting and it stripped the hole... Any help will be greatly appreciated |
11-30-2008, 06:07 PM | #74 |
Member#: 19732
I just tightened the fitting, didn't change any parts. It's still holding, 5 years, 80,000 miles, 3 autocross championships, and 20 track days later.
12-03-2008, 12:09 PM | #75 |
Cowabunga!
Super Moderator Member#: 185
South East
Vehicle:2014 Impreza Sport Ice Silver Metalic |
Agreed.
Dealer took care of it at that time and it was fine. |
Similar Threads | ||||
is this power steering line or transmission fluid line? thanks | racerxl99 | Transmission (AT/MT) & Driveline | 2 | 04-05-2006 07:53 AM |
WTB: Oil return line, and power steering lines....HELP! | RS_to_WRX_swap | North West Impreza Club Forum -- NWIC | 6 | 09-01-2005 01:55 AM |
steering rack coming loose. anyone else? | racerwrx | Service & Maintenance | 3 | 10-12-2003 06:17 PM |
('93-'01) SS Power Steering lines? | Ethan | Impreza Forum | 4 | 09-11-2001 02:26 AM |
