Brakes & Suspension Forum sponsored by The Tire Rack |
03-03-2014, 02:54 PM | #1 |
Member#: 354850
Tri-State
Vehicle:2013 WRX Sedan |
2013 WRX swaybar question
Ive been looking to get a set of swaybars.
However, since im a newbie at this, i dont know what size to get. Being that i live in NYC and the car is more of like a weekend car, can anyone recommend me a size for front and rear. Ive heard of brands like Eibach, Whiteline and Super Pro. I did read the article on this and might go with a 22front 24rear. But just wanted to see what everyone else has and how do they like it. Thanks |
03-05-2014, 12:08 PM | #2 |
Member#: 318736
MWSOC
Vehicle:2013 WRX Hatch CBS (BLCK) |
go 22R first with endlinks and see how you like them.
03-05-2014, 01:07 PM | #3 |
Member#: 247304
South East
Vehicle:2011 STI WR Blue |
03-05-2014, 03:00 PM | #4 |
Member#: 36838
MAIC
Vehicle:2001 B50 RSTi Sedan 2011 DGM WRX hatch |
Isn't the front already a 21... I'd probably go with larger in the front... I'm at 24mm in each of my GCs and the turn-in response is great.
03-05-2014, 03:08 PM | #5 |
Member#: 247304
South East
24mm on GD/GC front is a modest size (some people run 27 or even 29mm), but on a GR 24mm is on the aggressive side.
03-05-2014, 09:12 PM | #6 |
Member#: 36838
MAIC
You think so? Did they completely change the front suspension geometry on the GR? Looks pretty similar to years previous, at least from what I've seen under my cars so far.
03-05-2014, 09:18 PM | #7 | |
Member#: 247304
South East
1) 22mm front & rear 02-07 This combo doesn't apply to the 08+ cars since ******** doesn't make a 20mm front bar for these cars. This is a very mild combo, but it is still a great improvement over stock. This is perfect for someone who drives on bumpy roads and doesn't want to deal with much increased harshness. 2) 22mm front / 20mm rear 08+ or 24mm front / 22mm rear 02-07 This combination is going to work well on street driven cars. It is conservative enough that it will be comfortable on almost any surface, but it still adds enough stiffness that handling will be greatly improved. The fact that the front bar is slightly larger than the rear bar will keep the car's natural tendency to understeer more than equal sized bars would. This is a good combo for someone who wants stiffer swaybars, but is worried about added harshness or going too extreme. 3) 22mm front / 24mm rear 02-07 Here is another combo that only applies to 02-07 cars. It may seem like an odd combination, but it is a combination that has been proven in street tire autocross. I'd only recommend a combination like this for cars that are using stiff coilovers. The rear bar will help make the car rotate while the soft front bar will work in conjunction with stiffer springs to provide the best overall grip possible. This is an ideal setup for the intricate low speed turns in autocross. 4) 22mm front & rear 08+ or 24mm front & rear 02-07 This is my personal choice for the street and street tire autocross. The equal sized rear bar gives the car a more neutral feel. It really does a lot to counteract the car's tendency to understeer. I use this combination on my daily driver and with adjustable swaybars it can be set up to perform well on the street, track and autocross course. 5) 24mm front / 20mm rear 08+ or 27mm front / 22mm rear 02-07 The large front bar will provide a great turn in feel with this combo while the small rear bar will keep the car from oversteering much. If you want to keep all four wheels on the ground and have a solid turn in feel this may be a combo to consider. To me this isn't a very neutral feeling combo. When I drove a car with this combination it understeered quite a bit. 6) 24mm front / 22mm rear 08+ or 27mm front / 24mm rear 02-07 This is another popular combination... Probably just as popular as combination #4. The stiffer front bar will give the car an improved turn in feel over combination #4. I find that this combination doesn't feel as neutral on street tires as combination #4. To me it feels like it gives you a flatter, better turn in feel at the expense of over all grip. If you are on a smooth track with grippy tires this is a different story. This combo is perfect for someone who does track days or time attacks. It is also the preference of many for daily driving. It does give more noticeably better handling than combo #4 for daily driving. It just doesn't suite my personal driving style as well as #4 does. National autocross champions have also confirmed that a bar this large in street tire autocross tends to make the car understeer. The fastest street tire autocross STis in the country for the past few years have used very soft front bars in combination with very stiff coilovers. 7) 24mm front & rear 08+ or 27mm front & rear 02-07 This combo is extreme. This rear bar will likely lift the rear inside tire when you go around corners fast. It is really only suited for cars racing on a smooth surface. If you have a dedicated racecar on race tires this might be the perfect combination for you. I don't typically recommend it for daily drivers though. |
03-05-2014, 08:16 PM | #8 |
Member#: 354850
Tri-State
Yeah ill do the rear first. ill go for 24mm from Eibach with endlinks and et from them.
03-05-2014, 08:32 PM | #9 |
Member#: 305107
Tri-State
Vehicle:2016 GT 5.OHH DIB |
24/22 thats what i run
03-05-2014, 09:36 PM | #10 |
Member#: 36838
MAIC
Neat, thanks!
I personally run 24/17 on my RS and RSTi. I don't have any understeer to report, likely due to having good front LSDs in both. I had a 20mm on the rear of the RSTi for a while, but it broke the swaybar mounts off my adjustable lateral links at an autoX, so I ran the next few years with no rear sway at all. No rear sway had amazing cornering grip, but was prone to skip a little depending on surface. I could stay WOT through most turns w/o the rear end stepping out. I finally swapped to new lateral links this year (Whiteline) and put the 17mm back on for now and that's enough that I can step the rear out whenever I need to for additional rotation. -- Dave |
03-08-2014, 03:35 PM | #11 |
Member#: 186709
SCIC
Vehicle:2009 WRX Silver |
I drive my car daily and track it on the weekends and i run Whiteline 24F/22R, front on soft setting and and daily i run medium and on the track i use hard. I like the set up, very neutral feeling. I migh switch the rear to a 24. A cheaper way is always picking up an sti rear sway. But whatever you do, i recommend replacing the endlinks
03-08-2014, 04:06 PM | #12 | |
Member#: 247304
South East
