06-14-2016, 06:48 PM | #76 |
Member#: 246306
Ok lets bolt it together and go make some noise!
06-15-2016, 08:27 AM | #77 |
Member#: 440137
Vehicle:2011 WRX STI Blue |
Don't comment much on here but actually had to log in to just saw WOW. That is one sick block man well done
06-15-2016, 10:13 AM | #78 |
Member#: 41762
International
Vehicle:04 STi in ur Floriduh |
Amazing!
06-15-2016, 10:29 AM | #79 |
Member#: 13530
NWIC
Vehicle:EA63 , EA81T, EJ20G, EJ205 |
Priiiiiice!
06-15-2016, 10:35 AM | #80 |
Member#: 425346
South East
Vehicle:2003 WRX Caucasian |
06-15-2016, 11:03 AM | #81 | |
Member#: 328635
NWIC
Vehicle:2004 STi GTX3076R Rally Blue |
But in this case it doesn't hurt to ask, I personally probably should just leave this thread and not look back financially. However I also own a Subaru so who knows I could rationalize most anything. Lol |
06-15-2016, 12:01 PM | #82 | |
Member#: 13530
NWIC
06-20-2016, 11:17 PM | #83 |
Member#: 292653
Is there billet CNCd head to go on? Or are OEM style being used? Are there any things that can be imprived on with making a solid billet CNCd head? Or would that just be excessive work and effort with no real benefit over a standard part?
06-21-2016, 03:57 AM | #84 |
Member#: 246306
Billet heads being designed as I write this.....
This first test engine will be with stock heads, the billet heads will follow in around 60 days time |
06-21-2016, 08:44 AM | #85 |
Member#: 425346
South East
06-21-2016, 09:47 AM | #86 |
Member#: 397836
Vehicle:2015 WRX STi Lightening Red |
Truly a amazing piece of work you have done.
I don't know if I missed it somewhere, but what series of aluminum are you using, i.e. 2000, 6000, or 7000. Is it heat treated or annealed. Lastly, what kind of pricing is the general public expected to see? Thanks!! |
06-21-2016, 10:34 AM | #87 |
Member#: 149674
SCIC
Vehicle:2006 LimitLess STI SGM |
I do believe that the heads should incorporate plate block offs for those who do not run single or dual AVCS, but for those who do run them have adapter AVCS blocks that attach to the heads.
Personally I would not include the emissions pump port. "If you are doing this kind of build it is highly unlikely that you would run that." Also if the exhaust ports were straight instead of dogleg'ed that would be perfect. "For me at least". Again I believe that if your doing this kind of build your not using shelf parts and would do a custom exhaust anyways. Also have the option for diffrent head stud sizes. "This is just a thought, but what about bearings for the cam journals???" These are just some of my ideas I do kinda think it should be modeled after the "Spec-c EJ207 heads". Just my thoughts. |
06-21-2016, 10:43 AM | #88 |
Member#: 13530
NWIC
06-21-2016, 06:27 PM | #89 |
Member#: 246306
Starting to fit the ETS 6870 T4 kit.....
06-22-2016, 11:14 PM | #90 |
Member#: 246306
Next time you guys see this it will be running.....
06-23-2016, 04:33 AM | #91 |
Member#: 134272
HIIC
Vehicle:2007 Sti, UGM Rotated EFR 6758 |
This thread is really the only reason I check Nasioc before just about anything else right now, and it continues to deliver.
06-29-2016, 10:15 PM | #92 |
Member#: 246306
Just made some small changes to the WREJBB cases so that for every production engine from us you can straight-up drop in a 83mm crank without needing to modify the cases in any way. Makes for much easier big capacity engine builds
07-04-2016, 04:01 AM | #93 |
Member#: 246306
Happy 4th of July guys!
07-04-2016, 09:45 AM | #94 |
Member#: 145585
Vehicle:2002 S202 10.8@128 Yellow |
Wow!!!
07-06-2016, 03:08 AM | #95 |
Member#: 246306
Heads on, now to get the timing drive done, manifolds on, and back in the car (blower for laughs!)
07-06-2016, 03:45 PM | #96 |
Member#: 328635
NWIC
^^^ A little fab work and it should mount right up . . .
07-07-2016, 11:58 PM | #97 |
Member#: 246306
It goes in the car this weekend!
07-08-2016, 07:51 AM | #98 |
Member#: 348423
SWIC
Vehicle:08 FXT swapped DGM |
that looks so delicious
07-08-2016, 11:09 AM | #99 |
Member#: 304967
W. Canada
Vehicle:2006 frankenSTi OBP |
07-11-2016, 09:09 PM | #100 |
Member#: 363268
Vehicle:2015 WRX STi WRB |
are you guys putting helicoils in all the threads?
