Brakes & Suspension Forum sponsored by The Tire Rack |
12-22-2008, 08:17 PM | #1 |
Member#: 193591
RMIC
Vehicle:04 WRX VF34 water/meth, spt intake |
is it ok to run sti front springs with my 04 wrx rear stock springs?
I was wondering if it would be ok to run Sti front springs and just keep my rear 04 wrx springs. I shouldnt have any problems right. I also have group N front tophats to put with them I dont have the rear group N tophats though.
12-22-2008, 08:59 PM | #2 |
Member#: 38772
Vehicle:2 Cars, No Bling |
OK? Sure. When driven hard, the car will understeer.
12-22-2008, 09:02 PM | #3 |
Member#: 85905
Vehicle:2004 WRX |
12-22-2008, 09:07 PM | #4 |
Member#: 193591
RMIC
so just get sti front and rear springs and i should be ok right. does it matter what year sti they come from to fit my 04 wrx.
12-22-2008, 09:11 PM | #5 |
Member#: 38772
What's the point? What are you trying to do?
12-22-2008, 09:16 PM | #6 |
Member#: 193591
RMIC
lower a little and stiffen the springs a little and I figured instead of getting lowering springs that will work your stock struts to hell.
SO ANY YEAR STI SPRING SHOULD DROP RIGHT ONTO MY 04 WRX STOCK STRUTS WITH GROUP N FRONT TOPHATS AND STOCK 04 WRX REAR TOPHATS. |
12-22-2008, 09:32 PM | #7 |
Member#: 38772
Yes, any 04 - 07 STi springs will bolt right in. They're about at the limit of the damping of the stock struts, but will work just fine.
12-23-2008, 01:53 AM | #8 |
Member#: 85905
Vehicle:2004 WRX |
Yep 04-07 STi take offs are a pretty common upgrade and can be found for cheap.
12-23-2008, 12:19 PM | #9 |
Member#: 193591
RMIC
Nice thanks guys for the info.
Is it ok to run tires that are not stock size? | dgsblb2 | Tire & Wheel | 4 | 02-27-2009 08:07 PM |
Is it ok to run headers with all else stock? | forced03 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 11 | 01-16-2007 04:58 PM |
Is it ok to run 245's in the rear and 235's in the front?? | blackie | Tire & Wheel | 16 | 03-02-2005 07:52 AM |
Is it ok to run pinks springs alone without Group N tops? | wayne_rx | Brakes, Steering & Suspension | 17 | 02-21-2005 03:28 PM |
is it ok to run sedan springs on wagon? (pinks) | daphunkie12 | Brakes, Steering & Suspension | 4 | 01-22-2005 04:14 PM |
