10-10-2003, 03:22 PM | #1 |
Member#: 43006
Vehicle:04 wrx, sti aspen white |
Emergency my car is dead!!!
I was installing a boost gauge and I tapped into my turbo timer constant on accident now my car does not have any ignition response at all. Help!!!
10-10-2003, 03:33 PM | #2 |
Trust no one
Moderator Member#: 11170
Tri-State
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Check the main fuses in the underhood fuse box, you may have blown one of those.
10-10-2003, 04:13 PM | #3 |
Member#: 43006
Thanks thats it 50 amp
10-11-2003, 01:20 AM | #4 |
Member#: 37161
Vehicle:05 FXT BLK |
what will a blown fuse look like? cuz I car won't start also after I left my HID on for a few minutes without the engine running. I don't know if I have drained out the battery in just a few minutes or I have blown a fuse?
If I need to replace battery, which one is good? Optima? and where to get it? what part/model #? Thanks a thousand guys. |
10-11-2003, 07:48 AM | #5 |
Trust no one
Tri-State
What are your no-start symptoms? If it won't crank, do the lights dim? Does it just click when you turn the key to start?
If all you did was leave the lights on and didn't mess with any wires chances are your battery is just dead or at least too weak to start the car. You can check it with a voltmeter, resting voltage with the car off and no accessories on should be about 12.5. During starting while the engine is cranking it should not drop much below 10V. If you do need a battery the Optima is certainly a good way to go. Unless you have a high-power sound system and run it often with the engine off, your best bet for a drop-in direct replacement is a Group 35 Red-Top. Here is a link to a site that has them for an excellent price. Note the Group 35 model shown is truly a direct swap and doesn't require a longer starter cable as does the 35/75 Red-Top. http://sites.eoi.com/folder14788/ind...568&product=11 |
10-11-2003, 08:12 AM | #6 |
Member#: 37161
the lights go dim, and it just clicks when I turn the keys, (rapid click), so i guess my battery was drained, cuz I had similar symptoms wih another car...
Similar Threads | ||||
Emergency... my car is cosuming to much gas | manuelmatias | Subaru Conversions | 7 | 08-04-2007 10:00 AM |
Emergency... my car is cosuming to much gas | manuelmatias | Service & Maintenance | 2 | 08-02-2007 06:16 PM |
Emergency... my car is cosuming to much gas | manuelmatias | Engine Management & Tuning | 1 | 08-02-2007 01:07 PM |
my car is dead | wrx_in_efx | Texas Impreza Club Forum -- TXIC | 8 | 11-16-2001 10:45 AM |
My car is dead! help | jjimpreza | North West Impreza Club Forum -- NWIC | 10 | 11-07-2001 10:10 PM |
