10-29-2011, 11:35 AM | #401 |
Member#: 268609
I think we tend to make the jump that street tires are like race tires, They are not.
Partick did get me thinking about why or how the Lambo's and 930's, etc... don't loose it on the on ramp? I found a good discussion here: http://www.autocross.us/forums/index.php?showtopic=4410 AutoXers don't have the luxury of warm tires or prepared surfaces. I'm not saying 12's are the way to go or even if they will fit, just that if the narrow tire/temp way of thinking were correct then why do the super cars run super wide street tires instead of super sticky 185's? PooK (love a good discussion!)
10-29-2011, 12:00 PM | #402 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
^^^my home auto-x website...of course I stopped auto-xing far too long ago. The tire debate can go on for a long time and can be argued from either side but you ultimately need to put numbers down. Your tire size and mandated offset, will also start effecting your scrub radius, which I think is a very important factor in a mid engine, non-power steering chassis. With that being said, I'm curious what the SAI is on those upright?
You'll probably find better and more relevant discussion with FSAE.com That first question 'as an engineer...' makes me giggle. |
10-29-2011, 09:21 PM | #403 |
Member#: 268609
The SAI is 7.5deg. Caster is VERY adjustable.
Here is some footage of the prototype running an autoX down south. Im told to cut him some slack it was the first time out with the car...and that you know its him running when you can hear the engine over the music...LOL! I Worked a bit on the brake lines and rear walls. |
10-29-2011, 09:55 PM | #404 |
Member#: 254184
South East
Vehicle:TR42 06 WRX w/5 spd Syn Green w/carbon fiber |
Looks great, go PooK! Stainless fasteners, right?
10-29-2011, 10:12 PM | #405 |
Member#: 268609
Yes sir, yellow chromate nuts/bolts, stainless washers, stainless rivets.
I can use all stainless in non stressed places if you want? PooK |
10-30-2011, 08:15 AM | #406 |
Member#: 254184
South East
Do whatever will prevent surface rust down the road (like a motorcycle build) as we discussed.
Also, get me a list of the stuff I need to purchase for you like brake bias, s.f. of carbon fiber wrap, etc and I'll get it all coming your way. Got something coming in the mail to you next week too. |
10-30-2011, 09:39 AM | #407 |
Member#: 268609
Will do!......is it a pony?....be sure to poke holes in the box.
PooK |
10-30-2011, 02:08 PM | #408 | ||
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
But yes, a sticky auto-x tire would allow you to get away with running a larger tire. Quote:
I think a better question might be why aren't cars like the Ariel Atom or Caterham 7 sold with 10" or 12" wide wheels with 315s? But anyway... Back to the construction pics!! Hope the pony comes through the mail OK. |
10-30-2011, 02:51 PM | #409 |
Member#: 254184
South East
I had considered the NT-01 but then thought I'd better dig aroung for a tire that wouldn't be as sensitive to temps.
I don't see any of the other owners of exocars posting up these large wheel/tire sizes, but then again none of them have 400hp at the wheels either. I know that is a totally different calculation though as our point here is vehicle weight vs tire size/width. I wish there was some sort of formula that I could plug in the variables of my car to determine my options but I can't find anything anywhere. I just posted a question on eng-tips.com under the automotive wheel/tire forum to see if I can gain some additional insight. Sure, I admit I want the wheels/tires to look really cool , but not at the expense of slipping around and being a fool |
10-30-2011, 05:12 PM | #410 |
Member#: 268609
10-30-2011, 05:56 PM | #411 |
Member#: 254184
South East
Better start thinkin of a name and puttin up a fence in the back yard.
10-30-2011, 07:06 PM | #412 |
Member#: 295750
Vehicle:2014 TR-82 EXO CAR Candy red frame/blk body |
How about "One-Trick"?
10-31-2011, 11:36 AM | #413 |
Member#: 101399
Vehicle:2001 Forester L |
Has any of the linkage for the shifter been fabbed yet? I'm curious to see how this will be tackled.
I'm also curious exactly how strong that front diff is. The other trans for these types of configs (audi a/porsche g) are SO $$! Would be awesome if it holds up to the rigors of this setup. |
10-31-2011, 12:18 PM | #414 |
Member#: 268609
Check out WWW.cableshift.com its just one of a few companies doing this now, the suby gear box converted to 2wd has already proven itself in everything from conversions to off road.
I'm going to look into building our own on Marty's car, Erik (the first TR-42S) built his own as well as his own block off plate to shorten the transaxle. The good news is the parts are out there if we need them. PooK |
10-31-2011, 10:00 PM | #415 |
Member#: 247561
Vehicle:2011 TR-42S Black |
Here is version 2 of my shifter setup. I haven't worked on the car in quite a while so I figured I could upload this video of my work from a couple of months ago.
10-31-2011, 10:40 PM | #416 |
Member#: 254184
South East
16" wheels?
Danny - just curious, would a 16" wheel clear the brakes or does it need to be 17"
Hand a long talk with the main guy at CCW Wheels in FL today about tire sizes, temps and weight of the car. He noted that the Arial Atom 500 V8 only has staggered tire sizes of 205/50-15 and 245/45-16 with a weight under 1500lbs. My guess is that I'll come in at under 1800lbs. He felt a shorter tire would certainly help with traction by enabling the tire to heat up and maintain temps. As others here have suggested, he said there was no way he'd put anything larger than maybe a 275 as a stretch with more comfort at a smaller 255. He felt an 18" 315 would be impossible to heat up even on long highway runs, even if it was a Hoosier A6. He also said I'd need to consider the visuals to make sure a 16" wouldn't take away from the car and that I could stay at 17" if necessary. So I was thinking (outloud) this option - JLine 2 piece forged 5L2 wheels in 16x8 and 17x9.5 (all matte black) with Toyo Proxes R888 tires in 245/45-16 and 275/40-17 |
10-31-2011, 10:57 PM | #417 |
Member#: 297285
hey i like your choice for wheels. i finally got a reply from possum bourne regarding 6 speed lock out for 2wd for chassis #5. your pony looks the size of my huskies. i am interested to see your final wheel and tire size. hey pook , how is your son doing?
11-01-2011, 06:18 AM | #418 |
Member#: 268609
Much better this morn! Now he's just ticked he had to miss trick or treat
Marty, the 16s will be close on the brakes, I'll be into the shop Wednesday with a hub and your wheels, I'll bring a 16 from Bill's trike with me. The Solstice came with 18s.....but maybe? Erik, fantastic work on the shifter! I noticed on v2.0 you turned the bell crank vertical, does it seem to work better that way? PooK |
11-01-2011, 06:49 AM | #419 |
Member#: 268609
Another thing on your bell crank method Erik, most are still routing the left/right cable in from 90deg, this cleans that up! By re drilling the bell crank can you control the throw ratio?
Kind of a short shift done easy!? PooK Last edited by MatrixPooK; 11-01-2011 at 07:37 AM. |
11-01-2011, 01:18 PM | #420 |
Member#: 247561
I will probably give it another go after I get the car up and running. But yes if I change the bell crank I can shorten up the side to side of the shifter. I really like how it came out, very compact.
11-04-2011, 02:34 PM | #421 |
Member#: 268609
OK Ill try to put this is some order and show "LOOKS" as well
First pic: 17x9 with 42mm running 255/40 NOTE: forgot the rotor so the "LOOK" is 5mm off not my measurements. NOTE: the rack wont let the car get to ride height so it looks tall. Same tire with 30mm less or about 12mm 17x8 with 48mm running 235/45 Same wheel/tire less 30mm or approx 18mm 8's and 9's with Proper offset a 16...LOL! lets not go there |
11-04-2011, 02:40 PM | #422 |
Member#: 268609
couple more:
16x7 with 205/40 vs 17x8 with 235/45....WOW! Few different view points. |
11-04-2011, 03:59 PM | #423 |
Member#: 254184
South East
Progress!!!!!!!
Nice!
After our chat today it looks like I may have my alternate set of wheels/tires choosen! Gonna have to sell some blood but nothing beats a custom made set of forged 3-piece wheels from a well known and reputable company. If everything goes right they should arrive at Danny's shop in a few weeks, just in time to be used to properly size the handmade fenders. Last edited by hipowernut; 11-08-2011 at 07:49 PM. |
11-06-2011, 12:00 AM | #424 |
Member#: 295750
So do tell. What did you dedcide? 235/45's in front & 255/40's in back?
11-06-2011, 07:04 AM | #425 |
Member#: 254184
South East
Those are the sizes pictured. The new set of wheels coming wil be -
Front = 17x8.5 with 245/40-17 Rear = 17x9.5 with 275/40-17 |
FS: 2003 EVO 8 Track/Street car. | bhhamblin | RMIC Private Classifieds | 11 | 02-20-2010 12:37 PM |
Better Track/Street Car E36 M3 or WRX? | dpspeed | Motorsports | 71 | 05-20-2008 11:04 PM |
WTT: M3 Track/Street Car | redefinedWRX | Private Vehicle 'For Sale' Classifieds | 17 | 11-28-2007 04:54 PM |
Anyone have a 06 wrx? not TR | Dszerox | Mid Atlantic Impreza Club -- MAIC | 14 | 05-02-2007 09:57 AM |
I want to trade my 06 STI Black Trunk for an 06 WRX or TR trunk in the socal area | skubydew16 | Private 'Wanted' Classifieds | 0 | 07-25-2006 09:37 PM |
