11-05-2001, 05:46 AM | #1 |
Member#: 9197
just changed my oil
well i did my first oil change for this car--earlier i was planning on swithching to synthetic so before this i was letting jiffy lube do my oil (i have 7000 miles). well i was doing a search and had posted a thread about reg. dino oil vs. syn. and came to the conclusion that as long as i change it on a regular basis (like before it starts turning a brownish color), i'll be fine. plus i'm a little cheap. oh yeah and my honda tech friend said that under servere conditions, syn. won't protect your engine as much. i don't know.
oh yeah-the dumb store i went to only had castrol so i was stuck with that--no mobile one. btw--subies are pretty easy cars to change your oil--your car could almost be slammed and you can still change it with out jacking up your car. all you have to do is stick your arm under and change it. |
11-05-2001, 01:38 PM | #2 |
Member#: 8465
Vehicle:'00 2.5RS Coupe, AW '93 GMC Typhoon AWD |
I always do my own oil changes. Now with the fumoto oil drain valve, oil changes become more fun and less messy. Heck, I usually change my oil every 1000 miles. You actually let Jiffy Lube do your oil changes in the past? Bad bad bad!
Castrol GTX is a pretty good oil. I'm using Castrol GTX 10w-30 now, and no more piston slap at cold start up for me. -- Richard http://www.whitetyphoon.com/impreza/ |
02-21-2006, 05:31 PM | #3 | |
Member#: 60324
Vehicle:1998 RS |
wow, i thought the people changing at 3K were paranoid |
11-05-2001, 07:37 PM | #4 |
Member#: 9197
yeah i don't believe i did that. i'm also looking into the fumutomo oil plugs since everyone seems to be talking about them.
11-05-2001, 07:40 PM | #5 |
Member#: 11615
Vehicle:2002 wrx wagon |
did you also let jiffy lube do an engine flushing every 5000 miles, or how about a new air filter, you should also get your coolant flushed. I hate jiffy lube.
11-05-2001, 08:51 PM | #6 | |
Member#: 11791
Vehicle:2002 WRX Black |
Re: just changed my oil
You should never, ever listen to your Honda tech friend again. JAS |
11-06-2001, 04:48 AM | #7 | |
Member#: 9197
Re: Re: just changed my oil
11-06-2001, 04:49 AM | #8 | |
Member#: 9197
thanks -rosco |
11-06-2001, 09:16 AM | #9 |
Member#: 7624
Vehicle:BD5; family sedan that just wooped your ass |
Changeing the oil every thousand miles is just stupid. And that Fumoto oil valve is trouble. It will leave little bits of stuff in the oil pan. All you have to do is change the oil every 3000-3500 miles. Weather its syn or dino. I am not convinced of the need for synthetic oil. I will stick with a good quality dino myself. Your Honda buddy is not WRONG.
Castrol oil is a name. It is a rollling contract that is picked up buy the highest bidder. It has been produced by several different companies to date. So your buying Castrol GTX and getting Valvoline. |
11-06-2001, 12:49 PM | #10 | |
Member#: 11791
JAS |
11-06-2001, 12:52 PM | #11 |
Member#: 7624
What defines severe conditions?
11-06-2001, 01:24 PM | #12 | ||
Member#: 8465
You tend to lose your credibility when you can't spell. -- Richard http://www.whitetyphoon.com/impreza/ |
11-06-2001, 01:32 PM | #13 | |
Member#: 11791
Also, dino oils tended to lose more of their volume due to evaporation and burn-off. Since different additives don't burn off at the same rate, this caused the chemistry of dino oils to be significantly different @ 3K miles then when fresh. Synthetics changed too, but again at a reduced rate. Having said that, I still plan to go 3K in the WRX, and just use synthetics. Order some back issues of MCN if you want to read all three parts. It's a fascinating study, and backed with much better information than "Changeing the oil every thousand miles is just stupid." JAS |
11-06-2001, 01:43 PM | #14 |
Member#: 8465
11-06-2001, 02:20 PM | #15 |
Member#: 7624
Sorry I didn't know I was being graded. I'm at work and sometimes get in a hurry so yes I have a few typos. Keep the oil changed every 3000 miles. Thats all you have to do. Go head change the oil every 1000 hell, why not every 500 miles? Its funny how easily people get pissed off when they hear another persons opinion.
11-06-2001, 02:28 PM | #16 | |
Member#: 11615
11-06-2001, 04:29 PM | #17 |
Member#: 8465
HIHO, sorry for being so harsh. I change my oil based on elapsed time (3 months), not elapsed mileage, since I do short trips daily to and from work. Short trips can be hard on oil. In three months, I usually put in 800 "severe" miles, which is a lot less than 3000 miles. This is why I like to change my oil early.
11-06-2001, 06:53 PM | #18 |
Member#: 11560
Vehicle:1972 Datsun 510 Orange |
oils, hmmmm....?
Mobil One vs. Castrol... No difference. If It means anything the the companies with the highest specific outputs... New BMW M5/M3/M Roadster/Z8 all use Castrol, Hondas, RSX/S2000/NSX, etc. are big on Castrol too. Porsche uses Mobile One, SO WHAT! It really doesn't matter... I personally like synthetics better because I can be lazy with my oil changes. The extra additives in the synthetics gives me more time between oil changes. But sticking with 3000 mile intervals is a good idea, especially with a turbo vehicle. If it means anything BMW/Audi oil service intervals is 15,000 miles (thats right fifteen thousand, not hundred) and even more... Porsche intervals are at 30,000 miles (for all their vehicles, thats right, including the mighty 911 TURBO)!!! But stick with 3000, I try to, but 4-5000 is the norm for me. If you do like your BOOST (I know I do!), I guess every 1000 miles is fine. If you got the money, hey why not oil is like water to humans the more the better! Oh and for you anal specific people... I meant highest Naturally Aspirated vehicle outputs...
11-07-2001, 06:00 PM | #19 |
Member#: 7536
Vehicle:2005 WRX STi |
For those of you changing your own oil on the WRX - any luck from keeping the oil from squirking out when you unscrew your oil filter? I'm seeing oil, not dripping, running out, but squirking out due to what seems to be some type of residual pressure left in there. After 2 oil changes, seems like I've mastered the skill in minimizing oil spill on the garage floor, but I can't eliminate it. Any tricks from anyone? I'm glad the oil filter if facing downward. I can't imagine if the squirking happens on cars like Acura.
As for removal of the oil drain plug, I usually put the catch pan farther away from the drain hole because the oil kind of shoots out as well. Also, when the oil is draining, I go and jack up the driver side of the car as high as possible, that aids in getting more oil out of the oil pan on the WRX. Try that, with the car on level ground and the oil has seemed to be all dripped out, go and jack up the driver side, more oil pours out. |
11-07-2001, 06:46 PM | #20 |
Member#: 9197
what i did was to loosed slowly the oil filter first, not take off, and then preceeded to take off the oil nut; followed by the filter.
btw, is it true your supposed to change your oil nut every time you change your oil? |
11-07-2001, 06:49 PM | #21 |
Member#: 9197
also try or try not to open your oil cap on top--this may or may not reduce the pressure in there. if you didn't get that, what i mean is to open the hood, open the oil cap, then proceed to change your oil from the bottom. if that doesn't work and your still speuing ? oil, then try not opening the oil cap first and see if you still get the squirts.
11-07-2001, 06:57 PM | #22 |
Member#: 9026
"it true your supposed to change your oil nut every time you change your oil?"
You're supposed to change the crush washer that's on the oil plug every time you change your oil, not the actual plug. |
11-07-2001, 09:37 PM | #23 |
Member#: 11560
pressure problems...?
Always remove/loosen the oil filler cap to remove pressure before an oil change. Let the car sit for a couple mins. (very important!!!) after loosening to let the oil cool down an settle (for those who like to drive the car to get the oil piping hot before changing it... good way to get out more of the old/dirty oil!). Proceed to drain your oil, than slowly remove the oil filter, just loosen it first and let it sit for a min. than slowly twist it of completely, GOOD LUCK!
11-07-2001, 09:44 PM | #24 |
Member#: 7536
You know, I might or might not have opened up the oil cap (don't remember) when I loosen the oil filter, but I have drained out the oil already from the oil pan before going to the oil filter. I would think by draining out the oil pan, all pressure would have been released. I always drain out the oil first, usually have the oil cap loosen take out already, before proceeding to changing the oil filter.
11-09-2001, 03:27 PM | #25 |
Member#: 11593
Vehicle:2002 WRX Wagon Midnight Black |
Sorta like chugging a beer, huh?
Poke a hole on the bottom of the can, put mouth over hole, pop the can and you are in business. Anyway, I haven't changed oil on my car before. I'd like to learn because it sounds so easy. Is anyone willing to give me step by step instructions on how to change my oil on the WRX? By the way, I ordered the fumoto oil valve. It's not that expensive and if it might make things easier, heck...why not. I've heard about 80% supporting the fumoto and 20% saying it has big flaws. Any thoughts? |
Similar Threads | ||||
Just changed my oil :D (Dino to synth) | JetGirlArt | Texas Impreza Club Forum -- TXIC | 40 | 06-23-2009 06:14 PM |
so I just changed my oil..... | KnightWRX | Service & Maintenance | 8 | 08-20-2007 02:09 AM |
Just Changed My Oil... | Silver04WRX | North West Impreza Club Forum -- NWIC | 32 | 08-10-2004 10:21 PM |
just changed my oil and found... | defduane | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 09-03-2002 01:29 PM |
I just changed my oil and something very strange happend! | sstyle | Service & Maintenance | 13 | 03-14-2002 06:03 PM |
