Old 11-16-2012, 07:13 PM   #7501
Digital Dillon
Member#: 288727
Originally Posted by ajracerfan
I love gold, don't get me wrong, but I don't think it would go with my color. Paprika Red Pearl is pretty much metallic orange.
Gold would look dope or I love an aggressive fitting wheel painted OEM silver.
Digital Dillon is offline   Reply With Quote
Old 11-16-2012, 07:57 PM   #7502
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Originally Posted by Sellars21 View Post
35 bones for the entire kit, is it quality? Because the price does not suggest.
I have two pairs, low beams and fogs. Got them in March 2010. One of the ballasts for the fogs failed pretty early on. Got it replaced under warranty in October 2010. The warranty process took exactly 1 week and the only cost was the ~$5 it cost me to ship the dead ballast to them. Been fine ever since then.
JourdanWithaU is offline   Reply With Quote
Old 11-16-2012, 11:52 PM   #7503
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Still have to do the retrofit to have the right projector lens right?
krzywhtboi82 is offline   Reply With Quote
Old 11-17-2012, 02:02 AM   #7504
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Sorta. They're no different than any other P&P HID kit as far as installation goes.
However, it has been determined that the light cut off is the almost identical between halogen and HID bulbs. The problem starts to arise when you go for HIDs that are visually brighter than the halogens. HID bulbs come in a range of color temperatures and wattages and the visual output is different from one temperature/wattage to another.
Old 11-17-2012, 10:39 AM   #7505
Digital Dillon
Member#: 288727
I personally think the blue 8000k+ is blinding as ****! 3000k puts out the most lumens and the higher the temperature the less lumens is put out.
But, i'm not sure if it's the color or that everyone likes to put 8000/10000k bulbs in their reflective headlight housing.
Old 11-17-2012, 10:40 AM   #7506
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Isnt that the whole point goin hid? To get a brighter light. So if I were to do the 35w 6000k bulb would there be a noticeable diff. And would I have to do a retrofit
Edit
I don't give a crap about color. I want bright. So if I can do the hid with out a retrofit and not blind everyone or kill my projectors then sweet. If not then I'll wait to do a retrofit
Old 11-17-2012, 11:07 AM   #7507
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
The light output on HIDs isn't exactly linear, it's a bell curve with 4500k-5000k being the brightest. Anything else won't be as bright, going both towards purple and yellow.
I chose 8000k because, from what I could gather, the light output is very close to the same as the stock halogens. Meanwhile the halogens were 55w and the HIDs I got are 35w. So I am drawing less power for a light solution that should last longer. I decided to get HIDs in the first place because one of my halogens burnt out.
For the same light output, I consider the light scatter/cut-off to be acceptable. If I wanted to pump out as much light as possible, I would do a full retrofit.
Old 11-17-2012, 11:11 AM   #7508
Digital Dillon
Member#: 288727
Edit
You don't have to and people have said they've done to swap to HID's without a retrofit and do not get flashed by oncoming traffic. But, it's highly recommenced that you do a retrofit. Not only will the light not have any flood (light that could blind other drivers) it'll be concentrated in the areas it's needed most, making for a more functional headlight/HID assembly. And, of course it'll be brighter. Color aside, all HID's are about 3 times brighter than a standard halogen bulb.
Old 11-17-2012, 11:16 AM   #7509
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
They won't fit our stock mid pipe. I looked into it heavily before purchasing my rallisport headers.
If you want to use them, you'll need a older cat pipe from 06/07 2.5i's
They look like this to match up with the 90deg angle of your borlas
The 08+ are almost completely straight. If you haven't had the chance to look under your car this might look confusing. But the 08+ stock headers in the picture are mounted just past the second O2 bung, right next to the left set of exhaust inlet ports. Hard to see with all the heat shield. Sorry for the bad explanation, if I was on a computer I would just circle it.
Thanks for the help..I will most likely be taking the car and headers to an exhaust shop and having them make me a custom mid-pipe. More expensive but might be easier. If I go custom, will I have to do work for the 02 sensor?
Do you know what size the stock 06-07 mid-piping is? Only reason why I ask is because I have a catback that is 2.5 inch and not sure if it would even work together.
I saw you coated your headers..any purpose or for looks? I will most likely just paint mine to help prevent some rusting and for looks.
daigledangle8 is offline   Reply With Quote
Old 11-17-2012, 11:20 AM   #7510
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
So with out doing a retrofit at this time what would be the best watt and lumens to go with. I've got Sylvania zxe right now so if it ain't brighter than those then I wont do it.
Old 11-17-2012, 12:29 PM   #7511
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
Your o2 lead will have to be extended. It's a $15 part and then you'll have to solder two lines together and hear shrink the wire.
Stock mid pipe would be 2.25". BUT.... You'll need a 08+ cat back, it comes with a mid pipe that you won't be able to use because you need a 06-07 mid pipe. If you got a wider mid pipe it wouldn't line up with the back half of your 08+ cat back.
Your either buying parts you can't use if you get a full 08+ cat back if you want to use these headers.
Best bet if you really want to use these, your borla rep headers, 06-07 high flow cat pipe, 08+ AXLE back. And have your local muffler shop fabricate a custom 2.5 inch mid pipe straight through pipe. It would be completely one off and a unique awesome sound. Getting just the axle back will offset the price of having to buy high flow 06-07 cat pipe.
Sellars21 is offline   Reply With Quote
Old 11-17-2012, 12:34 PM   #7512
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
PM'ing you
Old 11-17-2012, 04:22 PM   #7513
Digital Dillon
Member#: 288727
4300k 35watt drop in HID kit. It'll put out approximately 3 times the amount of light.
Old 11-17-2012, 08:13 PM   #7514
TylerMarshall
Member#: 333984
09 Impreza 2.5i
charcoal gray
I need a new clutch for my 09 2.5i. Let me hear your knowledge!
TylerMarshall is offline   Reply With Quote
Old 11-17-2012, 08:57 PM   #7515
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
be more specific, what do you want to hear? Your burned your clutch didn't you?? revved too high i'm guessing
Navysesal is offline   Reply With Quote
Old 11-17-2012, 10:20 PM   #7516
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Ok my zxe are 35w 4200k so that means I won't see much of a diff then right
http://www.amazon.com/gp/aw/d/B005KDO9UY/ref=aw_d_detail?pd=1
Old 11-17-2012, 11:20 PM   #7517
Digital Dillon
Member#: 288727
Video Link: http://www.amazon.com/gp/aw/d/B005KDO9UY/ref=aw_d_detail?pd=1
The HID's will be MUCH brighter.
Old 11-17-2012, 11:37 PM   #7518
ahreno
Member#: 338185
Anyone ever try replacing the lower control arm, power steering with tie rods? Thinking about trying myself to save $700
ahreno is offline   Reply With Quote
Old 11-18-2012, 12:57 PM   #7519
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Alright guys, need opinions here.
SPT exhaust or Nameless performance?
A local guy is selling an SPT which is rare around here to find. I dig the looks, not sure how it sounds, but anything has to be better then our stock exhausts.
The Nameless looks excellent also with the small tube mufflers. Sounds great from the limited videos i've seen.
The SPT I can probably get for $250-$300, where as the Nameless is $430.
I was initially going to grab the Nameless but since the SPT popped up locally is that a good buy?
fancyfootwork15 is offline   Reply With Quote
Old 11-18-2012, 07:08 PM   #7520
09subi2.5i
Member#: 331636
09 impreza
paprika
is there anybody using the Rallisport UEL's with the stock catback? any volume increase in terms of sound?
09subi2.5i is offline   Reply With Quote
Old 11-18-2012, 07:21 PM   #7521
Sellars21
Member#: 304055
Couple of guys on the rallisport thread did it for a bit. They said it was barely audible over stock. Not louder just a little different, and not worth it without a decent cat back.
Old 11-18-2012, 07:32 PM   #7522
09subi2.5i
Member#: 331636
09 impreza
paprika
Damn buying both is just so expensive and i really would like that boxer rumble. Im not looking for anything insanely loud just something that has a nice boxer rumble to it.
Old 11-18-2012, 07:39 PM   #7523
ryangrz18
Member#: 316342
2009 2.5i
pearl white
just trying to get some answers so dont kill me lol. got 2009 2.5i sedan impreza stock height trying to put 225/40r18 18x8 with 35 offset rim tire package. is it gonna work without rollin n pullin flares? anything would help. read few threadsd where some guys are running without any mods to flares with no rub.
ryangrz18 is offline   Reply With Quote
Old 11-18-2012, 09:00 PM   #7524
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
I don't know where you got that info... daylight is about 4300K & that's most OEM HID output. Stock halogens produce about 3200K therefore they're yellowish.
Fendyman is offline   Reply With Quote
Old 11-18-2012, 10:13 PM   #7525
tupperware
Member#: 262990
2011 Impreza R 2.0
Charcoal Grey
First post, long time lurker here from Australia.
Got new wheels/tyres today, thought I'd share:
Tenzo-R Concept 9's 17"
Next mods are short shifter, lip/mudflaps and a lowering.
tupperware is offline   Reply With Quote
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 10 08-22-2017 12:30 AM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
