10-08-2008, 07:37 PM | #51 |
Member#: 131319
International
Vehicle:2003 JDM STI World Rally Blue |
Hey guys, I bought the 05 manual shift boot but it does not have an opening at the top to go pass the "reverse lift" on the STI shifter. Anyone know how to get the 05 boot to work with the sti shifter?
10-25-2008, 07:16 PM | #52 |
Member#: 159024
Vehicle:04 Wrx JBP |
is that all the parts needed to do this swap?
10-26-2008, 12:07 AM | #53 | |
Member#: 143122
Vehicle:07 WRB STi in the werks |
you should just have to cut alittle off the top soo it will slip over it then maybe sew it back for a clean look |
10-26-2008, 12:17 AM | #54 | |
Member#: 192071
SCIC
Vehicle:2005 Wrx Wagon PSM |
is it possible to swap the actual a/c and heater knobs with the 05+ ones? |
12-28-2008, 09:18 PM | #55 |
Member#: 191557
TXIC
Vehicle:2004 WRX Wagon WRB not so minty fresh |
Anyone know if the Armrest extension for the '04 will work on the 05-06 console armrest?
I found most of everything needed for under $200 shipped. Rob |
12-29-2008, 12:11 PM | #56 |
Member#: 153595
Vehicle:2006 Impreza WRX STI SGM |
no it will not. I have an arm rest extension for the 05-07 console if you want it. It does not have the hinge that connects the extension to the console though. Other than that it is perfect.
12-30-2008, 11:22 AM | #57 |
Member#: 172917
Vehicle:2004 WRX WRB |
I see that you need the bezel from an 06 TR so the early style hvac fits, I might seem dumb for asking but what does TR mean?
12-30-2008, 02:59 PM | #58 |
Member#: 143122
dont quote me but i beleive it means "tuner ready"
12-30-2008, 04:17 PM | #59 |
Member#: 133439
Vehicle:2003 WRX Sonic Yellow - Stage Taxi |
12-30-2008, 07:45 PM | #60 |
Member#: 173829
SCIC
Vehicle:04 dom3 +meth pyah 09 triumph daytona 675 |
lol^^^
ok so according to what i have read from above... I cant use the e-brake from my 04, I have to either bend it or replace it with the 05+ one, correct? also, I will need the radio bracket thing so my radio will sit. what if I am using a double din.... would i still need that bracket? |
12-31-2008, 12:02 AM | #61 | |
Member#: 130354
Vehicle:2011 535xi |
As for the radio bracket, I'm pretty sure you'll need the 05+ bracket. If you use the stock 02-04 radio mounting brackets the radio will not be aligned properly and you won't be able to fit the tr bezel, because the radio will sit too high. I tried to use the 02-04 brackets with my oem double din and I encountered this problem. |
12-31-2008, 12:05 AM | #62 |
Member#: 143122
^^^correct you need the 05+ bracket
12-31-2008, 12:13 AM | #63 |
Member#: 198773
SCIC
Vehicle:1997 GC8 White |
oh im tackling this install on sunday... im picking up the full console. I guess i will be needing the radio bracket as well? any pics of it?
02-27-2009, 04:41 AM | #64 |
Member#: 151601
Vehicle:2002 WRX-Cobb Stage2 |
how much work is it to swap the 02-04 a/c and heater controls for the 05+ ones? What's exactly involved to do so?
03-04-2009, 09:35 PM | #65 |
Member#: 172917
I've got all the parts for this swap sitting in my room. I am only missing a couple of brackets (according to the seller) Pictured are the 2 brackets I have. This big one and the one on the bottom of the storage area of the console. What brackets do I still need so I can get the part numbers off that first post and order them? Thanks for the help.
07-02-2009, 01:35 AM | #66 |
Member#: 142267
Vehicle:2006 tacoma white |
this thread is beautiful! I'm going to call Mill and see what it cost for the whole kit!
07-02-2009, 06:42 AM | #67 |
Member#: 206350
E. Canada
Vehicle:2004 PSM WRX VF30 |
Does anyone have the part number for the radio bezel for manual controls ( 06 WRX TR )
07-21-2009, 03:00 AM | #68 |
Member#: 195504
Vehicle:2004 OEM+ WRX Wagon SRR |
Three questions for anyone who has done this. I have a full 05 STI center that I'm installing in my 04 wrx.
1) Is it okay to unplug my security box so I can remove my e-brake? 2) I have the 05+ climate control knobs. Is it a plug and play with my 04 harness or will I need to mess with that as well? 3) And does anyone have any pictures of where hey re-located their side mirror adjustment button? Thanks |
07-21-2009, 03:37 AM | #69 | |
Member#: 133765
Vehicle:06 sti black |
07-22-2009, 12:19 AM | #70 |
Member#: 195504
bump for last post help.
07-22-2009, 10:40 PM | #71 |
Member#: 133765
im doing this conversion on my 04 wrx this weekend. I found some one with wrecked 05 wrx tr and sold me the complete center console with brake and brackets and vent for 200 shipped. if you look under (car part out for sale) I always see the wrx tr in their thats the place to get these pieces
07-25-2009, 10:56 PM | #72 |
Member#: 133765
I did the swap it was quite easy an straight forward the only other bracket you need is the one that goes bellow the air bent it small little brackent but you can still do the swap if you dont have it your air vents will just slide in and out by hand
07-26-2009, 09:39 PM | #73 |
Member#: 82224
SCIC
07-27-2009, 10:41 AM | #74 | |
Member#: 169914
Vehicle:2017 WRX 2021 Onyx XT |
2) not plug and play, unless you have a master's in electrical engineering then its not worth attempting. 3) 05+ door cars, mine still hasn't been moved all the way over due to me being super lazy. If you want to see mine / need a hand with your install let me know. |
07-27-2009, 03:54 PM | #75 |
Member#: 201483
SCIC
Vehicle:2010 WRX WRBM |
Man I wanna do this now. If anyone has the full package hit me up.
Similar Threads | ||||
04 to 05+ center console swap | mgsm666 | Subaru Conversions | 2 | 11-19-2012 08:42 AM |
04 to 05 center console??? | reddrex | Interior & Exterior Modification | 18 | 11-16-2012 03:28 PM |
04 to 05 center console | mbaker | Interior & Exterior Modification | 2 | 05-06-2009 01:39 PM |
For those 02-04 who wants newer center console | fluxcapacitor | SCIC Private Classifieds | 13 | 01-31-2008 09:55 AM |
02-04 center console to 05+ center console swap? | Wrx1234 | Newbies & FAQs | 2 | 04-15-2007 04:25 AM |
