08-23-2003, 09:10 AM | #1 |
Member#: 10426
Vehicle:2002 WRX Midnight Pearl Black |
spark plug questions...
where are the spark plugs located? how do i get to them? and what are the most recommended performance plugs? TIA
08-23-2003, 09:53 AM | #2 |
Member#: 19843
MWSOC
Vehicle:2000 2.5 RS Sedan 2016 Base 5MT VRP |
http://www.scoobymods.com/forums/sho...?threadid=1596
(if there is such a thing as a 'performance' plug... I put denso coppers in) |
08-23-2003, 09:24 PM | #3 |
Member#: 9193
Vehicle:2002 WRX Silver |
is the torque sequence a must since I dont have torque ranch?
Also, where can I get denso plugs? a serial # on the denso plug would be nice too Thanks |
08-25-2003, 06:36 PM | #4 |
Member#: 6739
I'd go with NGK over Denso. NGK plugs are used as OEM on the WRX, work well, and are cheap. That's a hard combination to beat.
I would go with the stock heat range in copper if you haven't modified the car that much or one range colder if you have. http://www.ngksparkplugs.com |
08-26-2003, 07:18 AM | #5 |
Member#: 1415
RMIC
Vehicle:2015 F150 3.5EB 2014 Jeep GC |
Get a little package of anti-seize compound for those plugs since the heads are aluminum. That way the threads won't gall. Plus it makes spinning them in much much easier.
If you don't have a torque wrench, you just kind of have to feel it out. Aluminum threads can strip with much less effort than iron threads. So be careful. I usually seat the spark plug then give it another 1/4 turn or less. Oh and I like the NGK V-power plugs with stock heat range. |
08-27-2003, 10:58 AM | #6 |
Member#: 30727
South East
NGK V-powers are the best plug to ever use in a Subaru. Anything else is a waste of money. End of story.
I don't use a torque wrench. I jsut know about how tight they should be. If you are straining yourself to tighten them, then you're tightening them too much... |
Similar Threads | ||||
Idiotic Spark Plug Questions | Yotsuya | Mid West Subaru Owners Club Forum -- MWSOC | 14 | 01-30-2002 03:13 PM |
spark plug question | Bruiser | Texas Impreza Club Forum -- TXIC | 14 | 12-13-2001 05:31 PM |
Spark Plug Question | Tarmac Terror | Normally Aspirated with bolt-on Forced Induction Powertrain | 3 | 10-06-2001 03:59 AM |
Spark plug question/problem | sbsnyder | Normally Aspirated Powertrain | 1 | 04-28-2001 04:47 PM |
Spark plug question | dbrown | Normally Aspirated Powertrain | 4 | 12-30-2000 10:08 AM |
