11-06-2010, 12:39 AM | #1 |
Vendor
Vendor Sales Rating: (0)
Member#: 262259
Vehicle:2010 Subaru STi Black |
* PerformancePartsPlus - Subaru Parts Galore!!! Pricing-to-low-list! *
PRICING IS TO LOW TO LIST! PM ME FOR PRICING! We are the Largest stocking distributer of AMR Performance Parts with the lowest discounted Prices. We stock a Variety of Performance Parts and top name brands at great costs. NEW TURBOS ON THE MARKET: THE NEW AMR CXR750 This is the LARGEST bolt on turbocharger on the market. This turbocharger is fully ported and flow 80lbs/min! AMR CXR750: Features and Specs AMR's CXR750 Bolt-On Turbo for the 08-10 STI is a monster of a bolt on turbo. The CXR750 comes with a ported, 8cm exhaust housing and a ported, custom-cast compressor housing that that is designed to fit in the engine bay better than any other turbo of this size (no more grinding or busting out a BFH to make something fit). The CXR750 comes equipped with a 80lb compressor wheel and a 3" compressor inlet. With the extreme porting on the compressor housing and thermal coated turbine housing, along with the large turbine wheel, the CXR750 has a flow rate of 80 lb/min. Slight lag is to be expected with this turbo, but when it spools expect to be pinned back in your seat. Hard. The CXR750 will produce 550-750whp when fully tuned with all supporting modifications. AMR backs their CXR750 with a 90-day limited warranty. All lines and gaskets are included making this an easy installation.
AMR T60R Bolt-On Turbo AMR T60R: Features and Specs The T60R was designed for those with power in mind. Its HUGE 60lb compressor wheel, HUGE machined compressor housing inlet, fully ported exhaust housing and fully ported compressor housing, gives the T60R to ability to move 850-870cfm! This turbocharger has been proven to achieve full boost around 3500-3800rpm (depending on supporting modifications), giving the vehicle a smooth but hard pulling power band. The AMR T60R can deliver 450whp-500whp at 27-29psi with the right support, doubling your factory HP! AMR T60 Features and Specs
AMR CXR500 AMR's CXR500 Bolt-On Turbo is an awesome turbo that is sure to put a smile on your face. The CXR500 comes with a ported, 8cm exhaust housing and a ported, custom-cast compressor housing that that is designed to fit in the engine bay better than any other turbo of this size (no more grinding or busting out a BFH to make something fit). AMR backs their 350-430whp capable CXR500 with a 1-year warranty! CXR500 Features and Specs: 47lb/min Compressor 8cm2 Exhaust Housing 2.4" Compressor Inlet Ported Compressor Housing Ported Exhaust Housing Oil & Water Cooled High-Temp Coated Exhaust Housing Wrinkle Red Compressor Housing Includes all oil and water lines & all gaskets NEWLY RELEASED PRODUCTS AMR Turbo Inlet Pipe AMR Turbo Inlet Pipe: Features and Specs AMR has designed the ultimate turbo inlet that is completely cast aluminum with zero welds. Everything on it from the brackets to the pipe itself is one piece making it one of the strongest inlets on the market. It includes both the 2.4" and 3" couplers, so it will work with both stock and aftermarket turbos. The pipe is full 3" and is powder coated wrinkle red for durability and style. Fitment is perfect and does not get any more precise. Everything pictured is included with the inlet and you will not need anything else to install this. If you are looking for the highest quality turbo inlet on the market, look no further! AMR TOP SELLING PRODUCTS AMR Top-Mount Intercooler AMR Top-Mount Intercooler: Features and Specs The AMR Top Mount Intercooler (TMIC) puts the stock intercooler to shame. The AMR TMIC is designed to cool down the air charge to the engine which in turn gives the vehicle better response, more torque and more power. The AMR TMIC has been tested at over 30+ psi. The intercooler is upgraded with a 3" outlet rather than the 2.5" that comes standard on others. The larger outlet allows more room for air to travel out of the core into the engine. With upgraded turbochargers the upper coolant line usually hits the intercoolers, AMR has modified an inverted lip on the end tank to compensate for that. They also beefed up the material used on the flanges, making them practically unbendable. All flanges are made from 6061 aluminum. AMR 2" Equal Length Race Header AMR 2" Equal Length Race Header: Features and Specs The AMR Race Header is made out of 304 U.S.A. stainless. Each tube is mandrel bent to ensure smooth flow. It is equipped with our custom CNC 1/2 thick flanges to ensure no warping. Each tube is equally tuned. Just like all AMR Products, they are made in-house! In-house testing has shown on a 2008 Subaru STi, with proper tuning, we have seen an increase of 40-50wtq and 20-30whp over standard exhaust housings/headers. This header is hand tig welded, not robotically welded like many overseas manufactures. This item comes with a 1 year warranty against cracking, fitment and warping! AMR also sells an Un-Equal Length 2" Race Header. AMR 2010 STi Turbo Back Exhaust System 2010 AMR STi Turbo Back Exhaust System: Features and Specs The AMR Turbo Back Exhaust for the 2008-2010 Subaru STI is one of the best systems out there! It is constructed from the highest quality U.S. stainless steel tubing and constructed here in the U.S. ensuring outstanding quality and durability. This unique turboback exhaust system from AMR features a 3" cattless downpipe and midpipe. The system splits after the center pipe into two 3" sections (unlike others which split into 2.5" piping) which leads to the canisters. The AMR turbo back finishes at the rear bumper with quad tips and is rated over 1,000 horsepower! There is an optional 1800 degree thermal coating which can be applied to only the downpipe & center pipe or the complete turbo back system from dowpipe up to and including the quad tips. The thermal coating keeps heat inside the pipe which speeds up exhaust velocity, reduces radient heat, and protects the material.
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [SIZE=2][B] ALL PARTS ARE: IN STOCK AND READY TO ROCK! We stock a wide range of brands! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "We are the largest stocking distributor of AMR Performance parts with the lowest discounted prices".[/B][/SIZE] [SIZE="2"][B]Paypal: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B][/SIZE] Last edited by PerformancePartsPlus; 11-23-2010 at 01:42 PM. |
11-07-2010, 05:21 PM | #2 |
Vendor
Member#: 262259
PRICING FOR PARTS IS TO LOW TO LIST! PM ME! Subaru STI 2008-2010 Parts Perrin Front Mount Intercooler The Perrin Front Mount Intercooler (FMIC) kits for the 08-10 Subaru STI are massive upgrades. Designed for 500hp to 800hp applications, Perrin's enormous bar and plate intercooler core will not disappoint. Cast aluminum end tanks and a high-flow core ensure even airflow and an optimized intake charge. Perrin's STI FMIC kits mount to their powder coated boxed steel replacement bumper beam with 1/2" thick mounting plates, so there is no cutting of the stock structural components required. While exceptionally sturdy, this beam is designed for off-road use only. Perrin uses an OEM type of triangular BOV flange for a stock-style STI blow off valve and is positioned to reuse the stock recirculation tube.
AMR Front mount Intercooler AMR's Front Mount Intercoolers are designed to be the premium kits on the market. Perfect fitment with no cutting or removing of stock parts is to be expected. Fog lights? No problem. AMR's beefy core will safely and efficiently handle 300-700+ horsepower with no problem and the Mandrel bent aluminum pipes fit perfectly in the STI engine bay. Everything for installation is included; big power has never been this easy.
Engine Internals Manley Performance Pistons Manley forged and dished pistons for the 08-10 STI EJ257 are machined of high strength 2618 material. Each design is lightweight yet robust enough to deliver long service life. Round wire locks, tool steel wrist pins and piston rings are included with every set at no additional charge. A proprietary multi-step top ring groove machining process assures optimum control of the groove's size, geometry, flatness and finish. Precise pinhole machining results in an exact compression distance as well as precise lock ring groove spacing, size and concentricity. Manley pistons are available in standard size as well as a wide variety of oversize/overbore options to accommodate any high performance engine build. All Manley pistons include a full set of four (4) pistons, piston rings and hardware. Subaru STI 2008-2010
Manley Performance Connecting Rods Manley has been in business since 1966 producing aftermarket and OEM engine internals, supplying such cars as the SVT Mustang Cobra and Ford GT. Manley's premier connecting rod series is the Turbo Tuff line which was designed to be the best money can buy. Manley Performance is synonymous with winning and their products power some of the fastest cars around. Manley H Beam rods are weight matched within +/- 1.5 grams of each other and both ends of the rod are rounded perfectly. These are the perfect rods for street applications pushing up to 600 wheel horsepower. Manley Turbo Tuff I Beam Rods are made using forged 4340 aircraft quality vacuum degassed material. Manley Turbo Tuff rods are machined in house, in the USA, to ensure the highest quality product. Each rod is shot-peened and magnafluxed after machining. The bores are round with no taper and these rods use APR 2000 cap screws for ultimate strength. Subaru STI 2008-2010
Manley Performance Crankshaft Manley Turbo Tuff Billet 4340 Subaru crankshafts are the perfect crank to complete a stout bottom end build. Each crankshaft is put through a multi-step heat treatment process and nitrided (hardened) for maximum strength. The crankshaft is then stress relieved, shot peened, and magnafluxed (stress tested). The center, crank pin and counterweights are gun drilled for reduced weight. Each Turbo Tuff crankshaft features knife-edged counterweights for proper balance and lowest rotational mass.
Mishimoto Radiator The Mishimoto 08-10 STI performance aluminum radiator is designed to maximize cooling efficiency by up to 30%, boost engine functions, and most importantly protect your car from overheating. The Mishimoto aluminum radiator features a lightweight dual core, 100% brazed aluminum, and polished end tanks, enhancing the overall performance of your engine. Every Mishimoto aluminum radiator is a direct OEM fit making installation effortless with no cutting or modification required. All Mishimoto radiators come with a high pressure 1.3 bar Mishimoto radiator cap and a limited lifetime warranty including accident protection. Mishimoto makes excellent radiators for both the daily driver or dedicated track car. Need even better cooling? Mishimoto's X-Line racing radiator has 3 rows for a core that is 25% larger than the standard version. The triple core design of the X-Line radiator allows more coolant to flow through the core for maximum cooling capacity. Each application is designed as a direct OEM replacement, with no customization required for installation.
Subaru STI 2008-2010 Mishimoto Fan Shroud The Mishimoto fan shroud for the 08-10 STI is a significant upgrade over the stock unit. The aluminum fan shroud is significantly lighter than standard OEM shrouds. A Mishimoto fan shroud will effectively drive out heat from the engine bay and deliver more air to the Mishimoto performance radiator. This fan shroud from Mishimoto will secure the fan blades, which otherwise could potentially damage other essential components in your engine. The Mishimoto fan shroud includes the aluminum shroud with two 10" electric fans pre-assembled and all necessary mounting hardware. This kit fits cars equipped with the Mishimoto brand aluminum radiator only. AEM Water/Alcohol/Meth Injection kit with 1 Gallon Tank
PLEASE PM ME FOR PRICING. MORE TO COME.... [/center]
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [SIZE=2][B] ALL PARTS ARE: IN STOCK AND READY TO ROCK! We stock a wide range of brands! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "We are the largest stocking distributor of AMR Performance parts with the lowest discounted prices".[/B][/SIZE] [SIZE="2"][B]Paypal: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B][/SIZE] Last edited by PerformancePartsPlus; 11-23-2010 at 01:41 PM. |
11-09-2010, 03:29 PM | #3 |
Vendor
Member#: 262259
AMR Cold Air Intake The AMR Big MAF Cold Air Intake System has a diameter of 74mm making it one of the biggest on the market. Taking advantage of the unique body style of the 08-10 models, we have designed a cold air system giving the vehicle fresh air rather then under the hood absorbing excessive heat from the engine. The AMR BMI AccessPort Map is specifically designed for use with the AMR Big MAF Cold Air Intake to squeeze out every last pony from this upgrade. The Cobb AccessPORT map or a custom tune is required to run this intake system. The Cobb reflash is available separately. Perrin Cold Air Intake Increase horsepower and style under the hood of your 08-10 STI. Perrin's engineering research team has discovered that proper MAF sensor alignment and plumbing size are crucial to maintain proper air fuel ratios and prevent nasty check engine lights that can plague the competition. With this intake system alone you will see consistent gains in horsepower and throttle response. Each Perrin Performance cold air intake kit for the 08-10 STI includes powder coated aluminum and silicone tubing, a Perrin foam air filter, MAF sensor housing, mounting hardware and instructions. This intake will not work with a front mount intercooler. Perrin Lightweight Pulley Perrin's lightened crank pulley for the 08-10 Subaru STI is engineered to reduce rotating mass, increasing horsepower and torque. Made from 6061T6 aluminum and weighing 1.2lbs, Perrin crank pulley is more then 4lbs lighter then the stock crank pulley. Perrin's pulley is not underdriven and will not affect the life of your engine. The pulley is simply a redesigned, lighter version of the stock crank pulley. Aftermarket underdrive pulleys are prone to charging and drivability problems, the Perrin pulley avoids these potential problems by exactly copying the OEM piece. The reduction at the crank shaft is effectively the same as removing 100 pounds of weight from your vehicle. Perrin's crank pulley will not wear out engine bearings or the oil pump, and will not add any additional vibration or noise. Installation is straight forward and can be done without jacking the vehicle or removing anything other than the belt cover, belts and stock crank pulley. Bump!!! Huge Sale.. Pm For Prices
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [SIZE=2][B] ALL PARTS ARE: IN STOCK AND READY TO ROCK! We stock a wide range of brands! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "We are the largest stocking distributor of AMR Performance parts with the lowest discounted prices".[/B][/SIZE] [SIZE="2"][B]Paypal: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B][/SIZE] Last edited by PerformancePartsPlus; 11-09-2010 at 05:33 PM. |
11-11-2010, 10:48 AM | #4 |
Vendor
Member#: 262259
ALL PM's ANSWERED!!!
ALL ORDER'S SHIPPED!!! Tracking is in your PM's!!!
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [SIZE=2][B] ALL PARTS ARE: IN STOCK AND READY TO ROCK! We stock a wide range of brands! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "We are the largest stocking distributor of AMR Performance parts with the lowest discounted prices".[/B][/SIZE] [SIZE="2"][B]Paypal: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B][/SIZE] |
11-11-2010, 02:54 PM | #5 |
Vendor
Member#: 262259
UNLIKE OTHER PARTS SELLERS AND COMPANIES.....
WE HAVE ALL ITEMS IN STOCK AND READY TO SHIP!!!!!
__________________
11-11-2010, 05:42 PM | #6 |
Vendor
Member#: 262259
TO THE TOP!!!!
__________________
11-12-2010, 11:30 AM | #7 |
Vendor
Member#: 262259
CHECK OUT Performance Parts Plus Early Black Friday Special - Price too low to advertise -AMR Inlet, AMR BMI & AMR Air Fliter - Free Shipping Click Here!
__________________
11-12-2010, 07:15 PM | #8 |
Vendor
Member#: 262259
BUMP IT UP!! PMS RETURNED..
SOME MORE ORDERS SHIPPED... KEEP IT COMING.. CHECK MY OTHER THREADS FOR MORE PARTS AND DEALS!!!
__________________
11-13-2010, 11:18 AM | #9 |
Vendor
Member#: 262259
BUMP!!!
LAST CALL ON THESE KILLER PRICES!! CHECK OUT Performance Parts Plus Early Black Friday Special - Price too low to advertise -AMR Inlet, AMR BMI & AMR Air Fliter - Free Shipping Click Here!
__________________
11-15-2010, 03:28 PM | #10 |
Vendor
Member#: 262259
ITEMS SHIPPED!!!!
Check your PM BOX for tracking!
__________________
11-16-2010, 09:52 AM | #11 |
Vendor
Member#: 262259
Good Morning Nasioc!!
More Items have been shipped. Tracking info is in your PM box. Check my threads for more Sales!!!
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [SIZE=2][B] ALL PARTS ARE: IN STOCK AND READY TO ROCK! We stock a wide range of brands! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "We are the largest stocking distributor of AMR Performance parts with the lowest discounted prices".[/B][/SIZE] [SIZE="2"][B]Paypal: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B][/SIZE] Last edited by PerformancePartsPlus; 11-16-2010 at 10:24 AM. |
11-16-2010, 02:52 PM | #12 |
Vendor
Member#: 262259
PM's have been answered!
Tracking numbers have been emailed/PM'd! Items are shipping out!
__________________
11-16-2010, 05:09 PM | #13 |
Vendor
Member#: 262259
LOWEST PRICES AROUND!!! IN STOCK - READY TO SHIP!!!
__________________
11-17-2010, 09:33 AM | #14 |
Vendor
Member#: 262259
Morning BUMP!!!
More Items in stock and ready to ship All items purchased have been boxed and shipped out... Check your pm box for tracking information!!! PM ME FOR THE LOWEST PRICING AROUND ON PERFORMANCE PARTS YOU NEED!!
__________________
11-17-2010, 11:48 AM | #15 |
Vendor
Member#: 262259
PACKING AND SHIPPING OUT!!!
PM's REPLIED!!! PRODUCTS ON THE WAY TO THEIR NEW HOME!!!
__________________
11-18-2010, 09:20 AM | #16 |
Vendor
Member#: 262259
GOOD MORNING NASIOC!
ITEMS ARE BOXED AND READY TO SHIP! HELP FIND THEM A NEW HOME!
__________________
11-18-2010, 02:00 PM | #17 |
Vendor
Member#: 262259
YOUR LOWEST PRICE PERFORMANCE SPOT - TO THE TOP!!!
__________________
11-18-2010, 04:42 PM | #18 |
Vendor
Member#: 262259
ANOTHER GOOD DAY!
PM'S ANSWERED! PRODUCTS SHIPPED!
__________________
11-19-2010, 09:14 AM | #19 |
Vendor
Member#: 262259
PARTS ARE BOXED AND READY! LET US FEED YOUR NEED!
__________________
11-19-2010, 11:22 AM | #20 |
Vendor
Member#: 262259
TO THE TOP!
__________________
11-22-2010, 09:24 AM | #21 |
Vendor
Member#: 262259
THANKSGIVING IS AROUND THE CORNER!
HAVE YOUR ITEMS PURCHASED AND SHIPPED TODAY! PM'S RECEIVED, RESPONSED AND ORDERS CONFIRMED!
__________________
11-23-2010, 09:18 AM | #22 |
Vendor
Member#: 262259
IN STOCK & ON THE SHELF!
PM's answered. Items shipped. Check your email for tracking.
__________________
11-23-2010, 12:39 PM | #23 |
Vendor
Member#: 262259
BUMP!
__________________
11-24-2010, 10:50 AM | #24 |
Vendor
Member#: 262259
LIKE ALWAYS:
1) MORNING BUMP 2) PM's REPLIED 3) TRACKING INFORMATION IN PM's 4) ITEMS ALL SHIPPED 5) AWAITING NEW ORDERS AND CUSTOMERS TO PLEASE!
__________________
11-30-2010, 10:17 AM | #25 |
Vendor
Member#: 262259
TO THE TOP!
__________________
BACK TO BLACK Specials-Parts wont last-Prices to LOW! Turbos/Intercoolers/Inlets | PerformancePartsPlus | Vendor 'General Sale' Forum | 10 | 12-29-2010 03:04 PM |
Subaru Parts galore (mainly stock GC, some aftermarket also) | BenBortner | Private 'For Sale' Classifieds | 15 | 10-01-2004 02:25 PM |
Subaru Parts galore (mainly GC) | BenBortner | North West Impreza Club Forum -- NWIC | 11 | 10-01-2004 02:19 PM |
Misc. Subaru Parts For Sale At Low Prices!! | Revolutions Motorsports | Vendor 'For Sale' Classifieds | 93 | 11-17-2003 02:42 PM |
