03-13-2013, 11:01 AM | #1 |
Vendor Sales Rating: (127)
Member#: 125739
South East
Vehicle:2007 1500HD Need Brakes? 919.420.0021 |
Rear Brembo and FHI 2-pot Version 1.1 and 2.0 KNS Brackets IN STOCK!
Version 1.1 and 2.0 KNS Brackets IN STOCK! These fine tuned brackets will allow you to put rear 04-07 STi Brembo, and 06-07 Red FHI 2-pot calipers on your Impreza, Forester or Legacy!
__________________
[B][COLOR="Black"][U]Phone:[/U][/B] 919.420.0021[B] | [U]E-Mail:[/U] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/COLOR][/B] |
03-25-2013, 10:53 AM | #6 |
Member#: 125739
South East
1.1 allows Brembo and 2-pot FHI calipers to bolt on to Impreza up to 2008, Foresters up to 2009, Legacys up to 2010.
2.0 allows Brembo and 2-pot FHI calipers to bolt on to 08+ Impreza, 09+ Foresters, 10+ Legacy. -Nick
__________________
04-02-2013, 12:26 PM | #8 |
Member#: 125739
South East
PM coming.
-Nick
__________________
04-02-2013, 12:50 PM | #9 |
Member Sales Rating: (5)
Member#: 175624
MWSOC
Vehicle:0304 WRX WRX SY WRB |
Would either of these work with the H6 rear rotor? I have the FHI 4 pots in the front and H6 rotors/brackets with the stock 04 sliders in the rear. I would like to run the 2 pots as well, but I really like the bias shift of the H6 rotors.
04-12-2013, 08:07 AM | #10 |
Member#: 125739
South East
The 2 piston rears are the same diameter as the H6 rotors thus bias shift = same.
__________________
04-02-2013, 01:01 PM | #11 |
Member#: 125739
South East
You will need to run the 06-07 rear rotor from the WRX with version 1.1, 06-07 rotors have the same outside diameter as the H6 rotors. But, the H6 rotors are solid and the 06-07 rotors are vented, so therefore they are not interchangeable.
-Nick
__________________
04-16-2013, 12:00 PM | #14 |
Member Sales Rating: (102)
Member#: 33869
Vehicle:2002 wrx rally blue |
Question for the 1.1 adapter, how can it fit for both 2 pot and brembo at the same time when they have different size rotor(290mm vs 316mm)? I understand DBA has adapter rotor(STI size) for the smaller drum, but how's the pad going to sit with the rotors? Thx
04-16-2013, 12:14 PM | #15 | |
Member#: 125739
South East
Same way you can bolt Brembo's directly on an 06 w/ out a bracket - just the larger rotors.
__________________
04-16-2013, 12:38 PM | #16 |
Member#: 33869
And both pads will sit flush with the rotor due to caliper design? I mean FHI pad will sit flush with 290mm rotor and brembo pad will sit flush with the 316mm rotor but the mounting points are still the same? Thx
04-19-2013, 04:19 PM | #17 |
Member#: 125739
South East
__________________
04-20-2013, 10:03 AM | #18 |
Member Sales Rating: (26)
Member#: 242113
South East
Vehicle:2004 STi, 2008 STi 2002 WRX |
The mounting points are the same, but the internal depth of the calipers differ. With the "mounting ears" being longer on the Brembos. Which allows the larger rotor to fit.
05-24-2013, 08:44 AM | #19 | |
Member Sales Rating: (1)
Member#: 4496
Vehicle:2009 Forester red |
i am a little confused with the model years listed for the forester... we have a 3rd gen 2009 model, which is the one that was just replaced by the new 2014. 2008 was the last model year for the 2nd gen bodystyle... which one should i be getting? |
04-19-2013, 04:09 PM | #21 |
Member#: 125739
South East
__________________
05-24-2013, 12:29 PM | #22 |
Member#: 125739
South East
Aigh! We need to fix that.
The third gen would use bracket version 2. -Ken
__________________
05-26-2013, 06:47 PM | #25 |
Member#: 125739
South East
Aside from color and the lettering.
yes
__________________
