04-25-2004, 09:37 PM | #1 |
Member#: 28546
BAIC
Vehicle:00 BMW M Coupe Silver |
STi stereo install question...
For those of you that got your STi without the stereo and added one later - did you have to buy any trim pieces to be able to accomodate the stereo? Did you have to cut what was there?
What did you do?
04-25-2004, 10:02 PM | #2 |
Member#: 32636
Vehicle:2004 Impreza STi Silver/Silver |
It slides right in without any trimming or cutting typically.
offset |
04-26-2004, 10:28 AM | #3 |
Member#: 53921
NWIC
Vehicle:2019 F150 EB - Grey 2020 Outback - White |
No trimming No cutting... just slide it and bolt in.
04-26-2004, 10:29 AM | #4 |
Member#: 28546
BAIC
Thanks guys!!!
04-26-2004, 10:57 AM | #5 |
Member#: 18713
Vehicle:06 CRV 04 STi |
you might want some spacers for the speakers, depending on what you run.
04-26-2004, 09:29 PM | #6 |
Member#: 8023
Vehicle:2019 Crosstrek white |
And when you install remember to hook up the power antenna wire on the head unit harness to the corrsponding white wire pin on the car harness. This powers the rear window antenna.
04-26-2004, 09:53 PM | #7 | |
Member#: 32636
offset |
04-26-2004, 10:30 PM | #8 |
Member#: 28546
BAIC
2003 for now... will be an 04/05 STi soon, so I'm getting all my facts together now...
04-27-2004, 12:48 AM | #9 |
Member#: 1737
NWIC
Vehicle:2016 BMW X1 msport mikereidphotography.com |
my old alpine 7909 went into my STi no probs...except from chuckles from the installers
m |
04-27-2004, 11:29 AM | #10 |
Member#: 50970
Vehicle:2004 WRX STi Pearl Blue |
Does the trim around the dims need to be removed or will it slide in with the trim installed?
04-28-2004, 09:39 AM | #11 |
Member#: 21543
Vehicle:2018 1LE White |
Yes you have to remove the factory trim and take out the 6 bolts holding the radio bracket in place.
the radio slot is a double DIN which means every DIN (german industry standard) sized head unit will bolt into the factory bracket with 4 bolts, youll just have to remove the aftermarket HU's faceplate trim bezel. I installed type-s components in my doors from alpine. I was able to use the provided mounting plates, just modified them slightly with a dremel tool and drilled some new holes. I did the entire door install in about an hour. In the rears i used alpine type-s 4" coaxials, no mounting brackets needed, i just turned them till all 4 holes lined up with metal and marked and drilled. the entire install was very painless. I went with a 4 channel alpine amp mounted under the passenger seat to run the front doors and 1 8" sub in the trunk. |
sti stereo install and question | mountie31 | Car Audio, Video & Security | 8 | 11-03-2003 12:29 PM |
Stereo install questions | Ruff | Car Audio, Video & Security | 5 | 07-10-2003 03:51 PM |
novice stereo install questions in WRX | PeeHoLe | Car Audio, Video & Security | 2 | 04-28-2002 10:23 PM |
Some '96-99 Legacy specific stereo install questions | Patrick Olsen | Car Audio, Video & Security | 3 | 07-17-2001 11:54 AM |
Some '96-99 specific stereo install questions | Patrick Olsen | Legacy Forum | 4 | 07-15-2001 11:19 PM |
