09-11-2011, 09:26 PM | #1 |
Member#: 225785
Vehicle:2010 WRX Prem Hatch SWP |
Cobb Stage 2 Map With Perrin Intake?
Just seeing if anyone is running a Cobb Stage 2 map with a Perrin cold air. I have been running the cobb stage 1 map for a while now with the Perrin intake and the car runs great with no issues. Just seeing if it will act the same way when i install my tbe next week. I will eventually get a protune but for now i hope to be ok with just using the regular stage 2 map. Any input will help. Thanks.
09-11-2011, 10:07 PM | #2 |
Member#: 245218
South East
Vehicle:2013 STI Limited |
Does Cobb make a Stage 2 Map for your car that specifies it can use a Perrin intake? The answer to this question is the answer to the one you're asking...
09-11-2011, 10:12 PM | #3 |
Member#: 225785
Ha no I fully understand what cobbs map notes mean however it is common knowledge that Perrins intake does not effect air/fuel ratios at all compared to the stock intake. I am running the stage 1 map with the Perrin intake now which is fine I just want to see if anyone else out there is doing the same with a stage 2 map.
09-12-2011, 07:42 AM | #4 |
Member#: 268928
Vehicle:2020 WRX/STI Black |
It says on perrins website that thier intake wont cause an issue in stock form but if you have a stage 1 tune or higher that it will require a speical tune. This is a quote from their site
"FOR CLIENTS WITH RE-CALIBRATED ECU'S (REFLASH OR SIMILAR) , THIS INTAKE WILL REQUIRE CUSTOM PROGRAMMING DUE TO SLIGHT CHANGES IN AFR. PLEASE CONTACT OUR TECH DEPT FOR ADDL. DETAILS." if you bought your intake off perrin they will email you the updated mapping to go with your intake and such. |
09-12-2011, 10:02 AM | #5 |
Member#: 225785
^^^^ Oh man you are right. i didnt realize that when i went stg 1. i have been running it this way for months i hope i didnt f things up...
09-12-2011, 12:10 PM | #6 |
Member#: 268928
Did you throw any codes? and like it says its a slight change in ARF's so you might have ran a little lean but it cant be as bad as stock map haha
09-12-2011, 01:03 PM | #7 |
Member#: 225785
No. No codes at all. I'm not that worried about it. It couldn't be as lean as the stock tune.
09-12-2011, 06:44 PM | #8 |
Member#: 245218
South East
Cold air intakes affect more than just Air Fuel Ratio. Another very important factor is that they can cause the boost to over shoot its target. There is a reason you should have the car tuned for a specific intake and not run an OTS map.
Granted you have been lucky so far with Stage 1 map, and even this could be pure luck as you have no idea what your AFR is do you? But go stage 2, the air fuel ratio and boost error is ever greater. You have no wideband I presume? So now you will be over shooting your boost target, probably running lean, and not even realize it. You will be the next person posting in the Technical section that you have had catastrophic engine failure and don't know why. I'm not judging, do what you want, its your car. But out of curiosity, why would you do something so careless and not even know if the car is running ok? Are you just hoping it wont break? |
09-13-2011, 12:04 AM | #9 |
Member#: 225785
Thank you for your input sir. I bought the correct map today.
12-25-2013, 02:06 PM | #10 |
Member#: 366337
SCIC
Vehicle:2009 Impreza WRX SWP Stage 1 |
Hey Vince,
I just got an accessport and am looking to install it but want to do it correctly. I have a perrin CAI on my 2009 wrx and would like to know what map you ended up using and how to get my hands on it. From reading through these forums I don't want to use the OTS cobb maps that only support Cobb intake or AEM intake. Thanks for the response. |
12-25-2013, 03:20 PM | #11 | |
Member#: 335445
Vehicle:2012 WRX - BLK STIG Stg. 2 - 287whp/317wtq. |
12-25-2013, 03:32 PM | #12 |
Member#: 370806
Vehicle:2019 WRX/STI DGM 23 Nissan Frontier Pro 4x |
12-29-2013, 01:20 PM | #13 |
Member#: 364511
SCIC
Vehicle:1999 Forester S AW |
I had to buy a stage 1 map from perrin for the CAI $50
01-02-2014, 04:52 PM | #14 |
Member#: 366337
SCIC
I got a map from them as well and installed it. I'm stoked! I used to have a weird boost surge around 4500 RPMs and the tune completely fixed it. Power band is so nice and smooth now.
Similar Threads | ||||
Cobb Stage 2 map with these parts? | WRBlueberry | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 04-29-2010 07:07 AM |
09 WRX. Perrin stage 2 vs Cobb stage 2 map. | Liquidr1 | AccessPort | 10 | 02-22-2010 09:05 PM |
have boost problem with cobb stage 2 map or PDX maps | alvinli217 | AccessPort | 23 | 12-04-2008 02:59 PM |
Cobb stage 2 map with crucial dp | EPskate | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 08-31-2005 12:38 PM |
Anyone with 1/4 time with new 1.2 Cobb stage 2 map? | WRXVII | Engine Management & Tuning | 17 | 09-20-2004 01:50 AM |
