10-10-2012, 10:47 AM | #1 |
Member#: 305152
Vehicle:2014 GRB WRB STI 2000 Corvette C5 |
Stage 2 Build
This may not be the right place, if so please direct me. I have a 2012 WRX, with AP V3, and Invidia Q300 stage 1. I want to have a stage 2 setup. What would be the best/most reliable stage 2 setup to have? Please list what you have done.
10-10-2012, 11:26 AM | #2 |
Member#: 282204
Vehicle:2011 5 Door STi Plasma Blue Pearl |
stage 2
For stage 2 you need a aftermarket downpipe. Either Catted or not.
Then I'd suggest bulletproofing your top mount and getting a good professional tune (a protune since using your accessport). Then you are set. |
10-10-2012, 11:35 AM | #3 |
Member#: 305152
I will be getting an Invidia catless dp next week. As far as ECBS and BC is that necessary? I will be doing a Forge BPV. What do I need for the top mount to be bullet proof?
10-10-2012, 03:01 PM | #4 |
Member#: 305152
Bump for help...
10-10-2012, 03:07 PM | #5 |
Member#: 253442
Do not get a bpv or a bov. Down pipe. Then tune. Done. Your stage 2
The less "garbage" your throw on (bov bpv etc.) the less there is to go wrong. |
10-10-2012, 03:09 PM | #6 |
Member#: 253442
Cobb OTS maps are kinda weak sauce. Fork out the money for a protune.
10-10-2012, 03:16 PM | #7 |
Member#: 305152
But wouldn't I need a BPV to make it run more solid? what about cracking the tmi?
10-10-2012, 03:36 PM | #8 |
Member#: 231192
South East
Vehicle:2003 WRX PROs Tuned 270/251 |
This is going to cost a lot, are you sure you can afford it? I mean catless downpipes are like $300.
10-10-2012, 03:40 PM | #9 |
Member#: 193253
Vehicle:08 wrx 322/352 wrb |
p&l short ram intake
grimmspeed ebcs Downpipe of whatever brand you'd like up-pipe you dont need a diff bov (i am running 322awhp-352awtq on stock bov) walbro 255 ( dont need it too much for just st2) IPR top mount is cheap but good if youd like headers equal length= more torque this should be more then enough to get you a little bit past stage 2 hope it helps |
10-10-2012, 03:41 PM | #10 | |
Member#: 253442
You do not need one. No ifs, buts, when's, or why's, |
10-10-2012, 03:42 PM | #11 |
Member#: 305152
Yup I can afford it. I don't remember you being my financial consultant. Run along little one.
10-10-2012, 03:47 PM | #12 |
Member#: 231192
South East
Are you sure? Last time I checked you were begging for jobs and looking for money.
10-10-2012, 03:48 PM | #13 |
Member#: 231192
South East
Plus you couldn't afford my cost to be your financial consultant.
10-10-2012, 03:51 PM | #14 |
Member#: 305152
Yup, we all have financial struggles at one point. Its called responsibilities. Now that those responsibilities are met I can play. Why don't you kick rocks and mind your business kid.
10-10-2012, 04:04 PM | #15 |
Member#: 305152
So St205WRX, I was thinking how does this sound.... Dp, DW65 fuel pump, Cobb SF intake forge BPV. GS ECBS and PW or Spearco, and obviously a protune.
10-10-2012, 04:05 PM | #16 |
Member#: 318755
South East
Vehicle:2012 Phatbotti Tuned |
10-10-2012, 04:08 PM | #17 |
Member#: 193253
I would get a lager diameter intake with a bigger inlet.. you'll love it i give you my word. As far as the bpv... like i said i am running a stock one and putting down nice numbers. everything else sounds good. now just start saving for a new clutch
10-10-2012, 04:08 PM | #18 |
Member#: 305152
Sup pajerito....so no intake really? Is it gonna heat soak that bad? Perrin film?
10-10-2012, 04:11 PM | #19 |
Member#: 253442
Stock intake is good for more whp than your stock turbo is even capable of producing.
10-10-2012, 04:12 PM | #20 |
Member#: 318755
South East
the sf is a box of metal aka a hot box, intakes are aluminum and dissipate about as quick as plastic but absorb heat more I wouldn't get an intake until im BT and need a KStech bigger maf intake. Its loud and if you think its worth it for the noise go for it but id put that money into suspension
10-10-2012, 04:16 PM | #21 |
Member#: 318755
South East
also reduce engine bay temps, see here http://forums.nasioc.com/forums/show...=fun+with+heat
best investment u can make and they arent very expensive |
10-10-2012, 05:15 PM | #22 |
Member#: 68647
Vehicle:07 STI 35R 05 BMW M3 ZCP |
You can add bolt-on's still you're blue in the face. Higher flow injectors and fuel pump, TGV deletes, larger intercooler, MBC and/or EBCS, intake, exhaust, external wastegate, etc. The list can go on and on. If you just want to lean on your stock turbo while not setting records, I'd go with a full TBE, panel filter and a hallman MBC. Drive car and enjoy.
10-10-2012, 05:34 PM | #23 |
Member#: 305152
Is there a specific tune from the AP for the panel filter or is there no need to tune for it?
10-10-2012, 05:45 PM | #24 |
Member#: 235190
Vehicle:2000 RSTi Silverthorne Metallic |
stock airbox + k&n drop in filter
hallman mbc dw65c drop in fuel pump catless dp el headers ewg up pipe with 38mm ewg TMIC Good tune done. should be good for a mid to low 12 second pass if you can drive. 108-110 traps would also invest in a boost gauge and AFR gauge and a cobb ap to monitor feedback knock. if you dont monitor any of those three you are deff more likely to mess something up |
10-10-2012, 07:56 PM | #25 |
Member#: 263470
Look at my build, I have been through enough heart ache on my11. May I suggest you stay at stage-2 with a good fitting TMIC (AVO fits best), I ve been through the IPR/Perrin headache. Go stage-2 get a good pro tune.
I would do the following: Catted DP, CDE EBCS (grimmspeed) - optional Forge BPV (Subaru specific model) TMIC of choice (mine is AVO) -Optional AEM intake AP OTS stage-2 (for now) Call it a day. You could wait on the TMIC, but to get max potential it should be tuned on the car. |
