06-21-2012, 07:29 PM | #226 |
Member#: 183480
South East
06-21-2012, 10:13 PM | #227 |
Member#: 130990
NWIC
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
06-21-2012, 10:35 PM | #228 |
Member#: 183480
South East
try this...
get the car to 40mph in 2nd gear, then hold the brake and floor the gas so you build boost but the car stays at or close to 40mph, and then just let the brake go. it should help that 2nd to 3rd run go alot quicker and make more use of the lower gear. just be ready to shift once you let off the brake lol...may not go too fast in your car, but if you watch my video on the first page, you will see how fast it goes with higher whp. when you combo that with all 4 wheels breaking loose and getting tq steer, it can be a handful lol |
06-22-2012, 12:14 AM | #229 | |
Member#: 130990
NWIC
07-04-2012, 03:19 AM | #230 |
Member#: 210777
SCIC
Vehicle:.. Don't worry bout' it Brah |
found this on youtube..
07-04-2012, 03:46 PM | #231 |
Member#: 183480
South East
hard for me to tell the actual time on my work computers, but i would say that was roughly 5 sec...that is a VERY rough estimation though
07-04-2012, 04:19 PM | #232 |
Member#: 130990
NWIC
07-05-2012, 05:54 PM | #233 |
Member#: 210777
SCIC
07-05-2012, 07:01 PM | #234 |
Member#: 290896
Vehicle:2004 STi, FOR SALE PSM |
07-05-2012, 09:59 PM | #235 |
Member#: 261612
Vehicle:2002 WRX - 750WHP 9.5s @ 150mph |
I'm not really that interested in adding all of these random YouTube finds to the list.
07-07-2012, 04:10 PM | #236 | |
Member#: 130990
NWIC
AFPSubaru: 607whp Xluben: 397whp amalgrover: 392whp jay05: 382whp gold rush: 356whp juanmedina: 340whp Dave D. (using my 3500lb/5.4 run): 340whp renosubby: 324whp Xluben(VF52): 251whp Synolimit: 251whp J Maher: 245 whp Also of interest is my first run with the cargo box, where I obtained a figure of 315whp, with my cargo box on. This would be a 10 percent difference due to wind resistance, which is consistent with the 10 percent poorer gas mileage I get on the freeway when the box is on. What can I say? I'm a math teacher on summer break right now! |
07-07-2012, 04:15 PM | #237 |
Member#: 261612
Well I already have all of the cars (including stock from the other list) on a scatter plot with a linear fit . Power to weight is a pretty solid correlation, especially on something like this that doesn't factor in launching. With a 50-100mph time and an accurate weight you can calculate power pretty well (similar to trap speeds but without going to the track).
07-07-2012, 04:19 PM | #238 | |
Member#: 183480
South East
just fyi, on a mustang dyno my car put down over 500whp (also in airboy old and new as well as virtual dyno), and juan's car is putting down more than mine i am pretty sure. so whatever mustang dyno math you are using...i NEVER want to get on that HEARTBREAKER DYNO . unless i am racing someone for lotso cash...then i would use the "i only make 392whp" statement so i could race a slower car and win . |
07-07-2012, 04:25 PM | #239 | |
Member#: 130990
NWIC
07-07-2012, 04:28 PM | #240 | |
Member#: 261612
07-07-2012, 04:29 PM | #241 | |
Member#: 130990
NWIC
07-07-2012, 04:59 PM | #242 | |
Member#: 130990
NWIC
Not too many cars can do what mine can do -- pull well from 50-100 in a single gear. I suggest we redo this thing all using a single gear pull in a reasonable range -- say, 60-90mph. 3rd in a WRX, 4th in an STi, perhaps. |
07-07-2012, 05:26 PM | #243 |
Member#: 183480
South East
^ this would be a really great way to gauge subaru vs. subaru or show what X whp would do to acceleration times, but comparing subaru vs. X is going to be null and void using a 60-90mph pull.
BUT...i bet 60-100mph pulls would be ridiculously fast since the bigger turbos could actually get decent boost starting at 60mph which means they wouldn't have to start in 2nd. i know my car was able to build almost full boost in 3rd by 60mph if i brake boosted. if i didn't have to shift or deal with wheel spin at the top of 2nd, my time would be REALLY good. |
07-07-2012, 05:55 PM | #244 |
Member#: 261612
Yeah, the gear for gear thing seems good but it's only really useful when comparing within the same transmission. I wanted something that can be compared across platforms. 60-130 really seems like the best option, but the drawback is that it would take miles to do on a 300WHP car. 50-100 was supposed to be slow enough to be easily attainable but fast enough to give consistent results. It may favor some gearing/powerband combos though.
07-07-2012, 06:03 PM | #245 | |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
Anyways on my 4.5 seconds 50-100mph I only made 440whp VD dynojet, 400whp Airboy. That was with about 27psi, 11.6 AFR, 13* of timing at peak torque and 19* of timing at redline 7500rpm. I am a little disappointed with my whp numbers but the run was done in 100* F + I am hopping that when it cools down to gain a lot whp and I may consider raising the timing. Although some people like Crystal would said that I am running to much timing already, while others like Junior, Ron, and Ed will advice me to raise it a little. Dave, I think your estimates are way too low, I would said that my car would make 400whp on a mustang dyno and trap 130mph. |
07-07-2012, 06:30 PM | #246 | |
Member#: 183480
South East
i can't believe you only put down 440whp on VD dynojet setting...thats like 100whp less than i made with the dynojet setting, and your turbo is bigger than mine plus you have cams. i put down like 560whp/530wtq on VD dynojet setting, and my boost was at 29psi tapering to 26psi, 11.7 AFR, and 19* timing at peak and 25-26* timing at redline 7500rpm (can't remember off the top of my head right now and work computers won't let me see the graphs to tell you actual numbers).
here are the graphs i posted a while back in the e85 army thread... Quote:
...just checked...it was [email protected] with a 2.42 60ft Last edited by amalgrover; 07-07-2012 at 06:40 PM. |
07-07-2012, 07:07 PM | #247 | |
Member#: 133146
Code:
Time (msec) Coolant Temperature (F) Engine Load (Calculated) (g/rev) Engine Speed (rpm) Feedback Knock Correction (4-byte)* (degrees) Fine Learning Knock Correction (degrees) IAM (multiplier) Ignition Total Timing (degrees) Injector Duty Cycle (%) Intake Air Temperature (F) Manifold Relative Pressure (4-byte)* (psi relative) Manifold Relative Pressure (Corrected) (psi) Mass Airflow (g/s) Mass Airflow Sensor Voltage (V) Throttle Opening Angle (%) Vehicle Speed (mph) Innovate Wideband AFR (AFR Gasoline) 13393 205 1.34 2330 0 0 1 20 12.43 113 0.78 0.87 52.5 2.5 100 31.00 13.33 13470 205 1.29 2364 0 0 1 20 14.12 113 0.93 1.02 50.84 2.48 100 31.00 13.89 13536 205 1.33 2372 0 0 1 19.5 14.28 113 1.03 1.02 50.54 2.52 100 32.00 13.77 13622 205 1.28 2410 0 0 1 20 14.91 113 1.11 1.16 53.1 2.5 100 32.00 12.67 13700 205 1.3 2402 0 0 1 20 14.96 113 1.26 1.31 52.35 2.54 100 32.00 11.88 13777 205 1.33 2437 0 0 1 20 14.82 113 1.36 1.31 55.25 2.52 100 32.00 11.50 13859 205 1.33 2450 0 0 1 20 15.28 113 1.45 1.45 54.56 2.5 100 32.00 11.42 13936 205 1.38 2479 0 0 1 19.5 15.34 113 1.58 1.6 54.88 2.6 100 32.00 11.50 13999 205 1.37 2525 0 0 1 20 15.83 113 1.7 1.74 57.51 2.52 100 33.00 11.50 14080 205 1.37 2549 0 0 1 20 16.31 113 1.8 1.89 56.8 2.6 100 33.00 11.45 14163 205 1.35 2553 0 0 1 19.5 16.43 113 1.93 1.89 60.47 2.56 100 33.00 11.41 14241 205 1.36 2600 0 0 1 20 16.48 113 2.01 2.03 58.43 2.64 100 33.00 11.38 14320 205 1.44 2619 0 0 1 19.5 16.76 113 2.13 2.18 59.09 2.64 100 33.00 11.42 14385 205 1.35 2634 0 0 1 20 16.97 113 2.23 2.32 63.67 2.56 100 33.00 11.41 14465 205 1.37 2674 0 0 1 20 16.94 111 2.33 2.32 61.71 2.62 100 35.00 11.39 14545 205 1.39 2687 0 0 1 20 16.89 111 2.42 2.47 63.46 2.68 100 35.00 11.42 14624 203 1.39 2722 0 0 1 20 17.86 111 2.51 2.61 63.29 2.68 100 35.00 11.41 14705 203 1.42 2736 0 0 1 20 17.24 111 2.61 2.61 65.27 2.72 100 35.00 11.42 14783 203 1.39 2792 0 0 1 20 18.25 111 2.76 2.76 65.69 2.7 100 35.00 11.50 14848 203 1.44 2787 0 0 1 20 18.58 111 2.85 2.9 67.28 2.7 100 35.00 11.45 14929 203 1.5 2841 0 0 1 20 18.62 111 3 3.05 69.73 2.72 100 37.00 11.58 15009 203 1.46 2863 0 0 1 20 19.38 111 3.13 3.19 69.73 2.74 100 37.00 11.55 15092 203 1.5 2880 0 0 1 19.5 19.38 111 3.26 3.34 70.29 2.8 100 37.00 11.47 15168 203 1.5 2922 0 0 1 20 19.95 111 3.37 3.48 74.42 2.76 100 37.00 11.41 15249 203 1.53 2955 0 0 1 19.5 20.42 111 3.51 3.63 73.85 2.8 100 37.00 11.54 15313 203 1.49 2994 0 0 1 20 20.23 111 3.62 3.77 76.09 2.8 100 37.00 11.54 15393 203 1.53 2983 0 0 1 19.5 20.49 111 3.78 3.92 75.53 2.8 100 40.00 11.55 15474 203 1.56 3024 0 0 1 19.5 21.44 111 3.96 4.06 77.02 2.88 100 40.00 11.61 15555 203 1.49 3059 0 0 1 20 20.58 111 4.15 4.21 79.07 2.86 100 40.00 11.80 15630 203 1.55 3085 0 0 1 19.5 21.86 111 4.31 4.35 79.07 2.88 100 40.00 11.94 15695 203 1.59 3107 0 0 1 19.5 22.02 111 4.5 4.5 81.57 2.92 100 40.00 12.01 15775 203 1.56 3148 0 0 1 19.5 22.33 111 4.69 4.79 81.71 2.92 100 40.00 12.16 15855 203 1.53 3182 0 0 1 20 22.1 111 4.9 4.93 79.75 2.94 100 42.00 12.27 15937 203 1.54 3207 0 0 1 20 22.78 111 5.08 5.22 83.05 2.9 100 42.00 12.32 16015 203 1.54 3284 0 0 1 20 22.63 111 5.31 5.37 82.86 2.94 100 42.00 12.39 16093 203 1.53 3302 0 0 1 20 22.29 111 5.51 5.66 84.17 3.02 100 42.00 12.45 16159 203 1.47 3326 0 0 1 20.5 22.43 111 5.77 5.8 83.38 2.94 100 42.00 12.64 16240 203 1.56 3356 0 0 1 20 23.04 111 5.98 6.09 84.31 3.08 100 42.00 13.13 16320 203 1.5 3420 0 0 1 20.5 23.19 111 6.32 6.53 86.9 3.04 100 42.00 13.32 16400 203 1.5 3412 0 0 1 20.5 23.49 111 6.61 6.67 86.65 3.04 100 45.00 13.61 16478 203 1.61 3503 0 0 1 20 24.37 111 6.94 7.11 92.02 3.1 100 45.00 13.96 16542 203 1.59 3497 0 0 1 20 24.75 111 7.23 7.4 94.14 3.1 100 45.00 13.96 16623 203 1.67 3567 0 0 1 19.5 26.43 111 7.63 7.84 98.08 3.16 100 45.00 14.02 16701 203 1.62 3574 0 0 1 19.5 25.66 111 8 8.27 104.19 3.18 100 45.00 13.94 16781 203 1.73 3642 0 0 1 19 27.72 111 8.46 8.71 105.08 3.22 100 45.00 13.73 16861 203 1.83 3678 0 0 1 18.5 28.8 111 8.9 9.29 110.12 3.26 100 47.00 13.70 16941 203 1.75 3710 0 0 1 18.5 29.79 111 9.43 9.72 113.1 3.26 100 47.00 13.52 17006 203 1.92 3736 0 0 1 18 32.08 111 9.97 10.3 119.65 3.32 100 47.00 13.17 17083 203 1.92 3821 0 0 1 17.5 32.29 111 10.61 10.88 130.11 3.38 100 47.00 13.10 17163 203 2.01 3868 0 0 1 17.5 34.85 111 11.32 11.61 130.41 3.42 100 47.00 13.05 17244 203 2.1 3908 0 0 1 17 35.5 111 12.05 12.33 137.06 3.48 100 47.00 12.99 17322 203 2.13 3961 0 0 1 17 36.85 111 12.87 13.2 138.86 3.52 100 51.00 13.23 17404 203 2.25 4008 0 0 1 16.5 40.63 111 13.77 14.22 147.79 3.58 100 51.00 13.10 17466 203 2.33 4026 0 0 1 16 40.97 111 14.69 15.38 159.05 3.6 100 51.00 12.63 17548 203 2.25 4087 0 0 1 16 42.31 111 15.89 16.54 165.74 3.64 100 51.00 12.83 17623 203 2.55 4174 0 0 1 15 46.61 111 17.13 17.85 175.41 3.7 100 51.00 12.97 17706 203 2.52 4197 0 0 1 14.5 48.97 111 18.59 19.44 188.58 3.8 100 51.00 13.01 17785 203 2.69 4304 0 0 1 13.5 53.18 111 20.2 21.18 193.85 3.88 100 55.00 13.05 17867 203 2.94 4340 0 0 1 13 56.82 111 21.92 22.78 217.56 4 100 55.00 12.94 17931 203 3.04 4466 0 0 1 12.5 63.16 111 23.84 22.78 227.6 3.98 100 55.00 12.94 18009 203 3.34 4442 0 0 1 12 70.69 111 25.71 22.78 236.04 4.1 100 55.00 12.83 18094 203 3.1 4539 0 0 1 12 68.7 109 26.82 22.78 255.05 4.04 100 55.00 12.73 18174 203 3.29 4612 0 0 1 12 75.4 109 27.53 22.78 252.26 4.12 100 55.00 12.39 18251 203 3.39 4666 0 0 1 12 73.41 109 27.79 22.78 270.53 4.16 100 59.00 12.52 18314 203 3.2 4772 0 0 1 12 72.94 109 28.13 22.78 256.44 4.12 100 59.00 12.26 18394 203 3.32 4863 0 0 1 12 76.88 109 28.05 22.78 262.71 4.16 100 59.00 12.14 18474 203 3.21 4953 0 0 1 12.5 73.28 109 28.06 22.78 276.32 4.16 100 59.00 12.08 18553 203 3.23 4953 0 0 1 12 75.84 109 27.96 22.78 268.29 4.16 100 59.00 12.19 18635 203 3.32 5094 0 0 1 12.5 76.98 109 27.78 22.78 284.24 4.2 100 59.00 12.05 18715 203 3.19 5095 0 0 1 12.5 74.75 109 27.69 22.78 273.42 4.16 100 65.00 12.51 18778 203 3.38 5219 0 0 1 12.5 81.55 109 27.68 22.78 283.49 4.26 100 65.00 12.32 18858 203 3.21 5290 0 0 1 13 78.05 109 27.68 22.78 300.72 4.2 100 65.00 12.19 18938 203 3.31 5313 0 0 1 13 85.66 109 27.66 22.78 293.23 4.24 100 65.00 12.10 19016 203 3.53 5394 0 0 1 13 87.18 109 27.5 22.78 315.09 4.3 100 65.00 11.94 19095 203 3.42 5446 0 0 1 13 86.06 109 27.45 22.78 308.33 4.28 100 65.00 11.67 19161 203 3.55 5513 0 0 1 13.5 91.42 109 27.54 22.78 325.81 4.34 100 70.00 11.67 19241 203 3.42 5538 0 0 1 13.5 84.69 109 27.42 22.78 321.19 4.32 100 70.00 11.58 19320 203 3.37 5704 0 0 1 14 87.43 109 27.29 22.78 317.34 4.3 100 70.00 11.45 19401 203 3.52 5730 0 0 1 14 90.91 109 27.17 22.78 332.73 4.36 100 70.00 11.63 19478 203 3.37 5769 0 0 1 14.5 88.49 109 27.11 22.78 330.42 4.34 100 70.00 11.77 19563 203 3.44 5862 0 0 1 14.5 92.84 109 26.86 22.78 329.65 4.36 100 70.00 11.63 19624 203 3.48 5862 0 0 1 14.5 92.1 109 26.69 22.78 333.5 4.38 100 76.00 11.60 19705 203 3.29 5944 0 0 1 15 91.09 109 26.52 22.78 334.27 4.38 100 76.00 11.58 19785 203 3.38 6056 0 0 1 15 94.49 109 26.3 22.78 338.12 4.4 100 76.00 11.58 19862 203 3.21 6043 0 0 1 15.5 88.58 108 26.26 22.78 336.58 4.36 100 76.00 11.47 19943 203 3.4 6166 0 0 1 15.5 95.77 108 26.3 22.78 334.27 4.4 100 76.00 11.69 20023 203 3.34 6191 0 0 1 16 94.78 108 26.04 22.78 350.68 4.38 100 76.00 11.48 20086 203 3.37 6208 0 0 1 16 93.53 108 26.19 22.78 332.73 4.38 100 76.00 11.55 20170 203 3.25 6366 0 0 1 16.5 96.36 108 26.16 22.78 349.91 4.4 100 82.00 11.60 20247 203 3.15 6418 0 0 1 17 92.09 108 26.1 22.78 354.7 4.4 100 82.00 11.72 20329 203 3.24 6462 0 0 1 17 96.61 108 25.98 22.78 338.89 4.38 100 82.00 11.70 20408 203 3.33 6477 0 0 1 17 96.39 108 25.89 22.78 356.32 4.46 100 82.00 11.61 20470 203 3.06 6578 0 0 1 18 92.6 108 25.7 22.78 344.35 4.38 100 82.00 11.61 20552 203 3.21 6628 0 0 1 18 99.35 108 25.71 22.78 353.08 4.42 100 82.00 11.48 20628 203 3.01 6720 0 0 1 18 95.89 108 25.76 22.78 356.32 4.38 100 88.00 11.66 20710 203 3.24 6683 0 0 1 18 99.57 108 25.62 22.78 340.43 4.44 100 88.00 11.41 20790 203 3.12 6800 0 0 1 19 98.7 108 25.56 22.78 349.87 4.44 100 88.00 11.29 20868 203 3 6755 0 0 1 19 93.29 108 25.62 22.78 338.92 4.38 100 88.00 11.55 20934 203 3.1 6844 0 0 1 19 96.17 108 25.43 22.78 357.95 4.44 100 88.00 11.67 21014 203 2.92 6885 0 0 1 19.5 91.13 108 25.51 22.78 348.33 4.38 100 88.00 11.72 21092 203 3.02 6957 0 0 1 19.5 97.66 108 25.55 22.78 338.89 4.4 100 93.00 11.83 21174 203 3.02 6982 0 0 1 19.5 94.61 108 25.48 22.78 341.19 4.38 100 93.00 11.67 21253 203 2.93 7029 0 0 1 19.5 92.69 106 25.55 22.78 339.66 4.4 100 93.00 11.76 21316 203 3.04 7086 0 0 1 19.5 95.36 106 25.53 22.78 350.68 4.44 100 93.00 11.79 I need to fix my fueling at low rpm but I haven't had time ... |
07-07-2012, 07:21 PM | #248 | |
Member#: 183480
South East
btw, i know you know this already, but you are SUPER lean during boost buildup and that timing is pretty low for E85. thats pretty much 93oct timing. i mean, thats close to what i was running on 93oct and i have over 9.5:1CR. obviously, there is no "magic number" for timing, but i doubt you are at MBT with it where its at...i bet you pick up quite a bit of power across the board by richening things up some and increasing timing a few degrees. Last edited by amalgrover; 07-07-2012 at 07:35 PM. |
07-07-2012, 07:31 PM | #249 | |
Member#: 133146
07-07-2012, 07:51 PM | #250 |
Member#: 183480
South East
its possible...i am a fan of giving the car what it wants and not what you think it should have (obviously within reason)...i mean, look at the ej207's timing...25* at peak and 38* at redline on the stock v8 maps.
on the opposite end of the spectrum, i know someone who is only able to run 9* at peak and 18* at redline with a 2.5L 18g setup running 20psi. with boost at 17psi and timing a couple degrees higher, the power was actually slightly lower, and the car would knock with even the slightest bit of heatsoak so...sometimes cars just don't like timing and sometimes they do. thats the beauty of e85. it allows the tuner to actually hit MBT. its pretty blatant when the car hits it because you go from making like 10ftlbs from every degree to only making like 2ftlbs with every degree. |
NASIOCers!! Starter mods list | Daniel son | Legacy Forum | 4 | 11-21-2006 03:56 PM |
50 cent listings on eBay motors | plunk10 | Off-Topic | 7 | 10-17-2006 12:15 PM |
Official NASIOC OT C List | dr_wheel | Off-Topic | 25 | 02-22-2006 05:41 PM |
NASIOC GMail Invite List | AVATAR-X | Off-Topic | 458 | 05-21-2005 10:04 AM |
Japan's Top 50 car list | Tragedy | Off-Topic | 5 | 07-29-2003 11:49 PM |
