12-04-2006, 11:11 AM | #1 |
Member#: 2973
Vehicle:2018 Camaro ZL1 1LE Red |
Unix port of Windows shutdown command (to shutdown wintel hosts FROM unix)?
Does anyone know if there is a port of the windows shutdown tool to unix?
I need to shutdown a few windows hosts from a unix host.
12-04-2006, 11:13 AM | #2 | |
Member#: 111635
12-04-2006, 11:21 AM | #3 | |
Member#: 2973
12-04-2006, 11:26 AM | #4 |
Member#: 7719
Vehicle:99 F-150 crew cab with illegals in bed |
Remote Shell daemon?
12-04-2006, 11:36 AM | #5 |
Member#: 11178
South East
Vehicle:2017 Volt I can haz mod? |
if you have terminal server installed you can run "tsshutdn" or something like that.
12-04-2006, 11:40 AM | #6 | |
Member#: 2973
Basicaly the explanation, I have a linux host at home that I ssh into. I need to shutdown one of my windows boxes at home remotely, I have no access to that box other then SSH access to my linux box. So.... I can't run windows utilities like shutdown.exe or tsshutdn.exe |
12-04-2006, 11:41 AM | #7 |
Member#: 41950
International
Vehicle:faq u rug |
12-04-2006, 12:21 PM | #8 |
Member#: 2973
12-04-2006, 12:22 PM | #9 |
Member#: 48048
International
Vehicle:. |
i only understand 6 words of the title. glad i could help
12-04-2006, 12:23 PM | #10 |
Member#: 111635
No, its a python script. Its also a way to shut down a windows box from a linux box.
Windows Python script? That's like saying, "That's a Linux Java script" Anyhow, I gave you the answer :P #!/usr/bin/env python # win32shutdown.py |
12-04-2006, 12:27 PM | #11 |
Member#: 2973
ok, find me win32 python apis for linux, I cant seem to find any anywhere, they certainly arent present in my python install.
12-04-2006, 12:27 PM | #12 |
Member#: 2973
Traceback (most recent call last):
File "winshutdown.py", line 4, in ? import win32api ImportError: No module named win32api |
12-04-2006, 12:31 PM | #13 | |
Member#: 111635
Any other questions? Get the last file in the download section, platform independant. |
12-04-2006, 12:35 PM | #14 | |
Member#: 2973
Operating System : 32-bit MS Windows (95/98), 32-bit MS Windows (NT/2000/XP), All 32-bit MS Windows (95/98/NT/2000/XP), WinCE, Win2K, WinXP |
12-04-2006, 12:43 PM | #15 |
Member#: 111635
Not windows only as it includes the .py libraries if you look in the directory structure. But your right, it doesn't have the win32api. Are you sure you have python completely installed? It works for me.
12-04-2006, 12:45 PM | #16 |
Member#: 2973
yeah python is completely installed. the win32 apis are not present because I am not running win32. The win32 python apis tie into things like windows platform sdk's which are only available on windows. Sure the scripts can be platform independant, but the one you mentioned employs libraries that hook into windows functions that are only available on windows.
12-04-2006, 12:47 PM | #17 | |
Member#: 111635
12-04-2006, 12:53 PM | #18 | |
Member#: 11178
South East
turn on telnet or install ssh or rsh on your winders box. |
12-04-2006, 01:01 PM | #19 |
Member#: 111635
I was under the impression shell scripts would save us all. Apparently this isn't the case. The python trick looks possible, but there's a bit more than just importing the win32api's....you've gotta register some extra stuff using SimpleXMLRPCServer in python first. My apologies.
http://www.microsoft.com/technet/int.../sfu35rsh.mspx Looks like you could install that service and play with it on your windows box too. |
12-04-2006, 01:07 PM | #20 | |
Member#: 17974
SWIC
maybe use this to remotely run pstools on the windows box?
http://eol.ovh.org/winexe/ Quote:
12-04-2006, 01:12 PM | #21 |
Member#: 2973
thats an after the fact solution. I just need something right now
If I was actually at home, I could just forward RDP at the router as well... I just was looking to see if someone ported the shutdown.exe command or similiar to j00nix. Looks like that is not the case. |
12-04-2006, 01:31 PM | #22 | |
Member#: 2973
12-04-2006, 01:43 PM | #23 | |
Member#: 11178
South East
So if no services are running on your windows machine how did you plan on sending this reboot command? |
12-04-2006, 02:04 PM | #24 | |
Member#: 2973
2. the windows shutdown command works without any special corresponding service running. I believe it just runs through the standard remote administration stuff. Try it at home, grab the xp or w2k resource kit and install it. then run shutdown -r -m \\machinename, you can remotely reboot any machine you have administrator priveledges on. |
I figured out one of the best ways to keep your subs from moving | Un0RiGiNaL | Car Audio, Video & Security | 17 | 02-21-2009 10:24 AM |
Government of Canada announces amendment to ease vehicle importation from the U.S. | AVANTI R5 | Non-Subaru News & Rumors | 0 | 12-20-2007 02:05 PM |
windows shortcut to shutdown? | Caddy Daddy | Off-Topic | 29 | 08-04-2005 03:02 PM |
Another UNIX Q: Mounting windows shares in Solaris | TimStevens | Off-Topic | 3 | 03-18-2005 12:31 PM |
Software guys: How do I compile files in UNIX that have Windows carriage-returns? | perret318 | Off-Topic | 4 | 09-03-2004 04:22 PM |
