04-27-2005, 05:47 PM | #1 |
Member#: 17615
TXIC
Vehicle:2009 Toyota Tundra |
Wide band??
I ordered an air/fuel gauge. I heard that it is pretty useless to use it with the stock rear O2 sensor. Can I just get any wide band sensor and hook it up?
04-27-2005, 08:38 PM | #2 |
Member#: 26933
BAIC
Vehicle:2006 STI CGM |
your standard a/f gauge is nothing more than a voltmeter in the range of 0-1v. A wideband sensor operates in the 0-5v range, but most wideband controllers have a standard 0-1v output that you can use to run a standard a/f gauge.
04-27-2005, 10:54 PM | #3 |
Member#: 17615
TXIC
so i should just save up for a wideband controller or something of that nature.
04-28-2005, 01:24 AM | #4 |
Member#: 69343
South East
Vehicle:1998 TransAm cnvrtbl Black |
Look into the LM-1 from innovate motorsports. Unless you plan on going with a specific EM at some point, then check out their options for W/B. The UTEC with a Tuner is a nice setup with easy to read logs.
The LM-1 has good software and some nice add ons for data logging. The narrowband AFRs are not totally worthless. I use mine tapped to the rear O2 to double check my wideband results. If the WB sensor goes bad, it's good to know the super lean (for example) reading isn't accurate since the AFR gauge is still reading over rich. |
04-28-2005, 03:01 PM | #5 |
Member#: 56902
Vehicle:2009 VW Jetta SE |
You could use a wideband to narrow band adapter with the A/F gauge so that it is less of a light show...
04-28-2005, 11:46 PM | #6 |
Member#: 29958
Vehicle:03 WRX WRB |
I was playing with my LM1 today. I really like it and I'd definitely recommend it to anyone looking into a wideband.
04-29-2005, 01:39 AM | #7 |
Member#: 26933
BAIC
the LM1 is deffinately nice. I use one for all of my road tuning customers. The Zeitronix unit is a also a good, cheaper alternative that works well if you're going to install it to be in the car at all times. The LM1 is a little large for a good permanent install IMO.
04-29-2005, 02:16 AM | #8 |
Member#: 86088
i agree
04-29-2005, 07:58 AM | #9 |
Member#: 56902
I have a Twin Tec WEGO installed in the clock gauge pod...
Similar Threads | ||||
Wide band vs narrow band O2 | mitch808 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 33 | 06-12-2002 04:13 PM |
('93-'01) Wide band O2 sensor voltage range | jeffg | Impreza Forum | 5 | 06-05-2001 02:26 PM |
New Info about my00 wide band o2 sensor??? | skidplatez | Normally Aspirated Powertrain | 3 | 11-03-2000 11:08 PM |
Wide band O2 on stock ECU? | HamFist | Normally Aspirated Powertrain | 1 | 10-30-2000 04:35 AM |
Wide-band A/F Guages? | 8Complex | Normally Aspirated Powertrain | 3 | 10-18-2000 10:51 AM |
