10-26-2012, 08:31 PM | #1 |
Member#: 220403
W. Canada
Vehicle:2002 207 V7 WRX WRB |
Logging on JDM V7 ECU problem
Hi,
I'm brand new to Romraider and open source tuning but I'm having trouble trying to figure out how to log using romraider for my tuner. I am using Tactrix 2.0 with Windows 7, I have Java 7 Update 9 installed, I have ECUFlash 1.42.2595, I have the Openport 2 drivers and J2534, Romraider v0.5.6 ECU Editor and Logger with the newest ECU Definitions and have the V95 Logger definitions. I have received and flashed a first map from my tuner and also received a file that is a romraider logging file which is titled 16bit.xml. When I try to load this file in the Romraider Logger settings as the Logger Definition I get the error "Error: Paramater arg0 must not be null" and I don't get a parameter list in the parameter window. When I try to load one of the V95 logger definitions the parameter window fills up and will read from the ecu and I can log that way, but the tuner recommends I use the 16bit.xml file for logging. I'm a bit lost, I've tried reinstalling all the programs and definitions, using an older version of Romraider (0.5.2) and tried installing everything on a different computer running windows vista. I figure I must be doing something wrong because the tuner tells me this logging file has worked for many other people with JDM ECUs but I just can't figure it out. Any help would be greatly appreciated, really want to get logging so I can start driving this thing. Thanks |
10-27-2012, 08:06 PM | #2 |
Member#: 220403
W. Canada
My question was answered on the Romraider Forums, here is the link if anyone is curious. The file in question was a logging profile and not a logging definition.
http://www.romraider.com/forum/viewtopic.php?f=5&t=8940 |
