11-05-2005, 07:38 PM | #1 |
Member#: 51745
NWIC
Vehicle:LIKE A BOSS |
97 Legacy Sedan GT Strut/Spring install questions
So, we're installing some Whiteline Control springs on KYB GR-2 struts and we seem to be having some problems.
1. We're not sure because the springs look so different which way is top and which is bottom (see attached pic). 2. We are having issues also fitting the springs to the struts. We are finding that they are not lining up quite right and that the strut baskets are not quite large enough for the springs. They are leaving gaps in the top and the bottom like they're not seating properly (see pics). HELP US PLEASE!!! AND SOON. WE'RE IN THE MIDDLE OF THE INSTALL~~!!! Aaron
11-05-2005, 08:12 PM | #2 |
Member#: 4739
NESIC
(holy quick job) |
11-05-2005, 08:12 PM | #3 |
Member#: 1925
RMIC
Vehicle:01 A4 89 944s2 13 Speed 3R 99 Sprint |
try the suspension forum n00b. the springs are pictured in proper orientation.(first pic)
11-05-2005, 08:25 PM | #4 |
Member#: 51745
NWIC
I tried it, homie.
We've crossposted everywhere applicable. So, the part of the springs with the coils closer together is the bottom? Because it just doesn't seem to fit quite right when we turned them that way. |
11-05-2005, 08:27 PM | #5 |
Member#: 27261
NWIC
Vehicle:1999 I'm Ron Burgundy? |
Are you sure those are legacy specific GR2's? or springs. cross reference the measurements wioth the stock stuff.
11-05-2005, 08:32 PM | #6 |
Member#: 51745
NWIC
Well, we're going by part numbers right now. The measurements are a little lower w/ the Whiteline springs becasue they drop the car, but they look roughly the same. The part numbers on the struts match up and they seem to fit the same as well.
The only part numbers that don't match up are the Whiteline part numbers. Online in the catalog it lists PN: 70198 as the proper number, but listed on the springs (for the front themselves) are C90-20198. And on the rears the PN is 70381 from the catalog and C90-20381 from the springs themselves.... We figured they were the correct ones becasue the last few nums matched, but are checking now becasue they don't seem to fit. |
11-05-2005, 09:00 PM | #7 |
Member#: 16874
NWIC
Vehicle:2008 2008 Audi RS 4 2014 Audi S Q5 |
I have the same exact Spring and same exact struts.
First, the part of the coil with them "stacked" together is the TOP. Second, the reason it isn't fitting perfectly is because you haven't transferred that rubber pad from your stock strut to the new one. There should be rubber at both the top and bottom of the spring. So, the picture where you don't think it is seating properly is the correct spring orientation, however you're missing the rubber seat. The other picture with the strut mount has the spring in wrong. Good luck. Oh, and pay attention to the removal in the future. Jared |
11-05-2005, 10:36 PM | #8 |
Member#: 51745
NWIC
Ok, so we figured it out anyway.
1. There is no rubber bushing on the bottom of the stock strut assy. 2. Thanks for the confirmation on the orientation of the springs 3. We found that the problem can come when one lines the top spring perch up with the new springs as the lines of wear on the bushings are at different places depending on the aftermarket spring make compared to the OEM. This can cause the spring to not seat properly. 4. We did pay attention to the removal, however, the aftermarket to stock spring comparison is totally different. The Whitline springs do not look much like OEM, and therefore cannot be directly compared. Especially when taken into account with the issues we were having in #3. Does the blue dot on the top spring perch have anything to do with all this magic??? That would be a good thing to know..... Aaron |
11-06-2005, 12:49 AM | #9 |
Member#: 16874
NWIC
If you source the rubber piece for the bottom spring perch, and the springs are meant for your car along with the GR2s, then the perception of things not lining up right will go away when they whole assembly is together.
I'd never done ANY suspension stuff prior to this install. I did it just as I described and all is well. It has been on for probably 6 months and no creaking, etc. What vehicle is this going on? I could check the part#s from my springs. They may or may not match... Oh, and there MOST DEFINITELY was a rubber piece on the base of MY OEM setup. The GR2s even had little holes for "nipples" to go through. There is supposed to be one there...at least on BGs. Jared |
11-06-2005, 01:36 AM | #10 |
Member#: 65823
NWIC
Vehicle:2018 Impreza Sport Pearl White |
+1 to the rubber piece.
dont install and drive with out it. it will be loud and your spring may slide around. but you gotta post on how you like the ride, i'm thinking of going with the same setup to replace my WRX suspension i have on my wagon now. |
11-06-2005, 01:45 AM | #11 |
Member#: 16874
NWIC
The ride is nice. Barrett from Allwheelsdriven even asked me what the suspension was when he drove it a couple weeks ago. He said it was nice.
Not too harsh, but still a nice handling ride. Oh, and I see it is for a 97 GT. You definitely need the rubber piece. Jared |
11-06-2005, 03:00 AM | #12 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
I don't think my '97 GT struts had rubber at the bottom. I'm too lazy to go out to the garage and look, though.
Pat Olsen '97 Legacy 2.5GT sedan |
11-06-2005, 03:32 AM | #13 | |
Member#: 16874
NWIC
Jared |
11-06-2005, 09:11 AM | #14 |
Member#: 768
Vehicle:OB, volt, 911, ram 1500, 1098s, m620 |
iirc, my 97 gt sedan only had rubber bits on one end. it's been a while though..
11-06-2005, 09:20 AM | #15 | |
Member#: 60224
Doesn’t exist on either my stock 98 BD suspension nor 04 WRX suspension. |
11-06-2005, 11:54 AM | #16 |
Member#: 5039
South East
Vehicle:2007 Outback XT Grey 5-speed (sold) |
I'm probably late here.
First off strut GR2 PNs: Front Left 334112 Front Right 334111 Rear Left 334116 Rear Right 334115 The rears are taller. The bunched coils in this case go to the top be they front or rear springs. Which brings me to my next question. Is the spring/strut in the first pic front or rear? Regarding the rubber strut perch isolators. They are(or should be) there but only on the rear struts. You need to transfer the isolators from your rear oem struts to the GR2s. There are 3 rubber nubs that you pull through three holes on the struts and secure the isolators to the strut perch. ss edit: just saw the topmount. Front. |
11-06-2005, 12:00 PM | #17 | |
Member#: 73684
NWIC
Vehicle:2012 4Runner |
11-06-2005, 12:00 PM | #18 |
Member#: 38829
NWIC
Vehicle:Not your usual 1997 Legacy GT |
I didn't have rubber on the bottom. I took out the rubber on the top. Seems just fine so far (~1 month with iON Sport Springs).
-A |
11-06-2005, 02:35 PM | #19 | |
Member#: 5039
South East
ss |
11-06-2005, 02:41 PM | #20 | |
Member#: 5039
South East
On the oem BD/BG struts you will have rubber spring isolators on: top front - ring usually stuck to the bottom of the upper spring perch top rear - castellated donut ring that snaps into the top of the rear spring bottom rear - attached to rear strut perch The front between the bottom of the springs and the strut spring perch is the only spring mating surface without a rubber isolator. My advice is to transfer all the rubber components to your new setup possible. ss |
12-23-2011, 06:14 PM | #21 |
Member#: 280312
help meh please help meh.... 97 leggy gt kyb GR2 excel g and H&r springs rear
I'm having a lil trouble with the rear spring when i fit them up with the shock they don't quite fit in the perch snugly.what should I do??????
12-23-2011, 10:53 PM | #22 |
Member#: 280312
since the rear struts are taller what should i do???
FS: CO: OEM 2006 Legacy GT Struts/Springs/Hats | 02rusWRX | Suspension/Brakes/Handling | 4 | 02-06-2009 12:45 PM |
FS: (CO) OEM 2006 Legacy GT Struts/Springs/Hats | 02rusWRX | Legacy Specific Parts | 3 | 02-04-2009 11:51 PM |
Strut/Spring Install Question | dark_rex | Brakes, Steering & Suspension | 6 | 05-14-2004 10:11 PM |
Legacy GT struts/springs into Forester | Cajual | Forester Forum | 1 | 09-05-2002 10:46 AM |
Prodrive struts/spring installed and I have a question | Camaroman | Brakes, Steering & Suspension | 8 | 05-30-2002 09:24 PM |
