09-06-2006, 06:52 PM | #26 | |
Member#: 24038
South East
So again, isn't that average low? If you are counting stock ECU users, the average is probably 175-180, as there are tenths of thousands of stock WRX's runnign around. So if its with EM, how could the average be 15 whp LOWER than the most basic OTS EM??? Average TD04 on EM is at minimum 220-235....
09-06-2006, 07:13 PM | #27 |
Member#: 22290
TXIC
Vehicle:2002 STI Ver 9 Spec C Wagon |
The other problem here is which dyno we're measuring on. Mustang, Dynapack, butt dyno?
09-06-2006, 07:14 PM | #28 |
Member#: 92634
RMIC
09-06-2006, 08:33 PM | #29 |
Member#: 70296
Vehicle:04 WRX rally blue |
**EDIT**
Ok, I added a stock Td04 column, this is just a plain old 2.0L wrx. 150 - 185 whp, and spool around 2800. Some people said their stage 2 spools a bit quicker, so the second Td 04 is with basic mods (exhaust, EM). I put the spool lower, around 2300 and up, while the whp was increased to 210 - 230. I hope the makes everyone happy. |
09-06-2006, 10:05 PM | #30 |
Member#: 74386
Vehicle:02- 2.5 Hybrid GrimmSpeed |
a td04 DOES NOT spool under 2700-2800 without extensive pnp'ing and custom tuning. If you actually take a log you will see the td04 spools at around 3100. if you are looking at the correlation between your tach and your boost gauge, you are wrong. you need to log to find correct values.
09-06-2006, 10:43 PM | #31 |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2017 BMW X5 |
I think this thread is worthless. "Spool" means absolutely jack squat. Now hear me out on this one.
There is a thread that shows my VF23 spool log against a VF22 log against an FP Green comparing manifold pressure, maf volts, g/s, RPM ect. Both VF turbos spooled almost EXACTLY the same in terms of airflow in g/s but the VF22 lagged behind in pressure by about 300 RPM or so. The Green lagged behind in pressure but surpassed the VF series in airflow after a certain RPM. Is my VF22 going to lag because it produces less boost but makes more airflow than the TD04? Will the Green be the same? http://forums.nasioc.com/forums/show....php?t=1061674 If we want a good comparison, plot when each turbo makes 200 g/s of air and its peak g/s and at what IAT and manifold pressure. Do it in 5th gear and list what mods as well and then you have a really fair comparison. Your spool for all the VF series turbos should also be no more than 3500 on any of them. |
09-06-2006, 11:58 PM | #32 | |
Member#: 80136
NESIC
Vehicle:2006 Ford F-150 Black |
my logs dont lie (although, i dont have a boost gauge *i know i know, its on the list of ***** i need to buy*) it shocked me at first to find out i hit boost that early, but considering what i have done (PnP'd EVERYTHING, GM bcs, APS inlet+APS cai, Cobb AP + ST), its not out of the question. |
09-07-2006, 12:06 AM | #33 |
Member#: 25413
You should mention that these figures are on pump gas too..........
09-07-2006, 12:07 AM | #34 |
Member#: 89983
Vehicle:2005 vf39'd wrx 295whp stealth black |
I have an 05 with an invidia uppipe, cobb downpipe, and bosal catback.
With the Cobb OTS stage 2 map, my stock turbo is fully spooled at 15.5 - 16 psi by 2900-3000 rpms in 2nd and 3rd gear. hope this helps p.s. i run mobil 93 oct. in ny |
09-07-2006, 02:46 AM | #35 |
Member#: 62856
Vehicle:MBP SQC#197 Stockpiling parts... |
These are still 'rough' estimates....
But adding in PSI would be a great idea as well.... For example, I wouldn't mind an 18g that doesn't hit a certain psi as long as it keeps up with a 16g. subscribed |
09-07-2006, 11:45 AM | #36 | |
Member#: 70296
I really think you're looking wayyy to much into this. I looked over the thread you linked, and yeah, it's got a great comparo with plots, pressures, etc. But it would take days, probably weeks, to compile all the people's logs around nasioc, plot them, scale them, and make sure they're all in equal gears/mods/etc. I'm sorry, I just don't have that amount of free time on my hands. I was doing some independent research on turbos, decided to just type up some of the info that I'd gathered, and voila. This thread was not meant for an in depth analysis of each turbo, merely a starting point for newbs such as myself. I will more than gladly change, add, extract, data from the above chart. Hell, I know it's far from perfect. **Edit** I increased the spool times on the TD 04 Added the VF series information Anyone want to add an educated blurb about the VF39? Last edited by WoohooRX; 09-07-2006 at 12:00 PM. |
09-07-2006, 12:08 PM | #37 |
Member#: 82612
Vehicle:2015 WRX STI Ice Silver Metallic |
I have the big16G turbo. Full spool is about 3300-3500rpm in 3rd/4th gear. WHP estimate on average is 280-300.
09-07-2006, 12:15 PM | #38 |
Member#: 92634
RMIC
09-07-2006, 12:15 PM | #39 |
Member#: 70296
09-07-2006, 02:09 PM | #40 |
Member#: 54942
South East
Vehicle:2004 WRX |
"Spool"...as noted earlier, what is it? When the turbo starts "whistling" audibly? When it starts to show positive pressure on boost gauge? When the turbo has acheived it's max pressure?
Reading thru the responses, it's clear that folks are looking at it with different understandings. Adding an exclusive definition for "spool" to the first post would be great. |
09-07-2006, 02:30 PM | #41 | |
Member#: 70296
I added a little definition to the top, hope that helps. |
09-07-2006, 02:33 PM | #42 |
Member#: 39677
Vehicle:2008 Land Rover 02 WRX |
vf23 spools quicker than the 34.
09-07-2006, 04:19 PM | #43 |
Member#: 34832
Vehicle:1989 M3 White |
My small 16g PNP by deadbolt hits 17lbs by 3700 in 91 degree east coast humidity.
on a dyno it did 280whp dynapack XXtuning 02 wrx wagon 95,000 miles young. this was done on 3rd gear PNP small 16g TXS v1 IC Pinks Warlbro ECUTEK (tuned by xx) TGV deletes |
09-07-2006, 04:27 PM | #44 |
Member#: 70296
I put it up there, anyone know of average spool times/whp? I'm not too familiar with this turbo.
I put the spool of the small 16g at 3500 - 3700, and whp a little less than the evoIII, 240-280. That seem about right? |
09-07-2006, 04:32 PM | #45 | |
Member#: 74386
i guess i was assuming "spool" meant the rpm when the turbo hits max boost. |
09-07-2006, 04:45 PM | #46 |
Street's closed, pizza boy
Member#: 17301
Vehicle:2018 Focus RS 2006 Evo #17 STU |
Is "average" intended to be "average, with an off the shelf tune"?
Maybe you could have a "max" column as well, indicating what it would max out at on pump gas with all supporting intake/exhaust mods. Oh yeah - I would include a PnP TD04 too, not that it's a lot different. In general I think you have a good idea, other than nitpicky people like me trying to turn it into something more scientific john (247 whp on an unmodified stocker) |
09-07-2006, 04:46 PM | #47 | |
Member#: 34832
3500 seems kind of low. then again that pull is with a stock STI axleback (on a tbe) so yah 3500 could be done. I'll put a better flowing axleback on and do a pull someday... in theory the evo3 should put down much more power so i dont know how it would relate to that.. |
09-07-2006, 04:55 PM | #48 |
Member#: 87601
Vehicle:2005 wrx silver |
there is NOO chance that even the smallest 16g should make less than 275 whp even if it's an auto tranny for God's sake so just put 280 instead of 240-280...240 is for like the stock turbo
09-07-2006, 05:22 PM | #49 | |
Member#: 106117
SCIC
Vehicle:2002 WRX WRB |
i just dont like the bad rep the vf22 gets as a laggy turbo. |
09-07-2006, 05:51 PM | #50 |
Member#: 97043
TXIC
Vehicle:08 STI 02 Z28 - project |
hurray for the OP
this is a great idea and thanks a ton for doing all that work for us lazy simpletons. STICKY ! ! must have taken hours. thanks again. |
List of Turbos specs | alex02wrx | Built Motor Discussion | 1 | 09-05-2008 10:47 AM |
list of turbos capable of 500whp... | 300zrex | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 54 | 08-18-2007 12:08 PM |
Know a list of turbo sizes for all Impreza versions? WRX, STI, Spec C etc. | MarylandEcstasy | General Community | 9 | 01-01-2007 10:19 AM |
List of Turbo Kits | Unsung Boxer | Normally Aspirated with bolt-on Forced Induction Powertrain | 10 | 01-25-2005 01:47 PM |
Complete List Of Turbo Kit Suppliers For RS | subarumantoo | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 03-28-2001 09:43 AM |
