11-27-2008, 06:32 PM | #1 |
Member Sales Rating: (1)
Member#: 14010
Vehicle:'04 APS-ified STi TopSpeed Tuned - Black |
SOLD: Sony STR-DA4ES Home Theater Receiver ($250 OBO)
SOLD - NO LONGER AVAILABLE
Upgraded my home theater and I'm selling my older receiver. Sony STR-DA4ES Receiver with remote included. Front: Rear: Remote: Specs: (copied / pasted from **here**) General Product Type AV receiver Width 16.9 in Depth 18.3 in Height 6.9 in Weight 44.1 lbs Enclosure Color Black Audio System Sound Output Mode Surround Sound Built-in Decoders Dolby Pro Logic II, Dolby Digital Surround EX, DTS Neo:6, DTS-ES Matrix 6.1, DTS-ES Discrete 6.1, DTS 96/24 Audio D/A Converter 24bit / 96kHz Surround Sound Effects Digital Cinema Sound EX Equalizer Yes Digital Sound Processor (DSP) Yes DSP Preset Qty 18 Surround System Class 5.1 channel Response Bandwidth 10 - 100000 Hz Signal-To-Noise Ratio 100 dB Output Power / Total 600 Watt Input Impedance 50 kOhm Input Sensitivity 150 mV Amplifier Output details 110 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.05% - 2 channel(s) ( front ) 110 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.05% - 1 channel(s) ( center ) 110 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.05% - 2 channel(s) ( surround ) 110 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.05% - 1 channel(s) ( rear center ) Timer Sleep Built-in Display Fluorescent Display Dimmer Yes Additional Features A-B speaker switch, gold plated connectors Connectors Headphone Jack Yes Coaxial Digital Input Yes Optical Digital Input Yes Optical Digital Output Yes Radio Type Radio tuner - AM/FM - digital Tuning Display Fluorescent display Preset Station Qty 30 preset stations Antenna Form Factor Loop AM / wire FM Response Bandwidth 30 - 15000 Hz Signal-To-Noise Ratio 76 dB Total Harmonic Distortion Mono: 0.3%, stereo: 0.5% Station Memo Display Yes Additional Features Station naming Remote Control Type Universal remote control - infrared Supported Devices LD player, MD recorder, DAT deck, projector, TV, VCR, satellite TV system, cassette deck, AV receiver, cable box, DVD player, CD player Features Macro function, learning, multi-brand compatibility Connections Connector Type 1 x headphones ( phone stereo 6.25 mm ) - front 1 x composite video/audio input ( RCA phono x 3 ) - front 1 x S-Video input ( 4 pin mini-DIN ) - front 1 x 5.1 channel audio line-in ( RCA phono x 6 ) - rear 1 x 7.1 channel audio line-in ( RCA phono x 8 ) - rear 1 x 7.1 channel audio line-out ( RCA phono x 8 ) - rear 1 x turntable audio input ( RCA phono x 2 ) - rear 3 x audio line-in ( RCA phono x 2 ) - rear 2 x audio line-out ( RCA phono x 2 ) - rear 1 x audio line-out (multi zone) ( RCA phono x 2 ) - rear 4 x composite video/audio input ( RCA phono x 3 ) - rear 2 x composite video/audio output ( RCA phono x 3 ) - rear 4 x S-Video input ( 4 pin mini-DIN ) - rear 2 x S-Video output ( 4 pin mini-DIN ) - rear 2 x component video input ( RCA phono x 3 ) - rear 1 x monitor output ( RCA phono ) - rear 1 x monitor output ( 4 pin mini-DIN ) - rear 1 x composite video output (multi zone) ( RCA phono ) - rear 4 x SPDIF input ( TOSLINK ) - rear 1 x SPDIF output ( TOSLINK ) - rear 2 x SPDIF input ( RCA phono ) - rear 1 x serial ( 9 pin D-Sub ) - rear 2 x component video output ( RCA phono x 3 ) - rear 1 x Control A1II - rear 4 x Control S - rear Remote control - rear 4 x front speakers output ( banana/spade x 2 ) - rear 2 x surround speakers output ( banana/spade x 2 ) - rear 2 x rear speakers output ( banana/spade x 2 ) - rear 1 x center speaker output ( banana/spade x 2 ) - rear Power Power Device Power supply - integrated Voltage Required AC 120 V ± 10% ( 60 Hz ) Power Consumption Operational 470 VA Power Consumption Stand by / Sleep 1 Watt Power Outlets 2 AC outlets
