06-20-2008, 11:22 AM | #1 |
Member#: 120985
South East
Vehicle:2002 Impreza WRX Midnight Black Pearl |
What 12V source did you use for your WI kit?
I have everything from my SMC kit hooked up and ready to go, but now I need to find a safe 12V source that can power the controller and pump without nuking a fuse.
Any suggestions? PS I have a relay under the dash that is switched off the radio. It is turning on all my gauges, LC-1 and DCCD Pro, BUT I am scared of putting a fuel pump and controller on a circuit that isn't very relaible. I have issues with the relay not tripping and with it cutting off on the highway.
06-20-2008, 11:57 AM | #2 |
Member#: 120985
South East
so after a closer look at the system... I am going to want a relay, big time. 60W at max duty cycle.
Now I ask, who sells the most reliable relay? |
06-20-2008, 01:07 PM | #3 |
Member#: 110029
Vehicle:2004 Citroen Picasso Silver |
Make you own fused/switched 12V supply with a power relay. It energises with ignition.
06-20-2008, 01:35 PM | #4 |
Member#: 120985
South East
06-20-2008, 04:27 PM | #5 |
Member#: 110029
What kind of relay is it? Almost all automotive relay can withstand a certain amount of vibration without tripping out.
06-20-2008, 04:47 PM | #6 | ||
Member#: 120985
South East
EDIT: this could be my problem: Quote:
06-20-2008, 06:43 PM | #7 |
Member#: 162593
You can tap power from the cigarette lighter. No need for a relay unless you want to add maunual on/off of the system.
Best regards, Dan |
06-20-2008, 06:44 PM | #8 |
Member#: 120985
South East
06-20-2008, 08:20 PM | #9 | ||
Member#: 110029
I am a believer of using a relay to supply your own equipement. It appeared the relay is faulty. |
06-21-2008, 01:51 AM | #10 |
Member#: 120985
South East
DVM? multimeter?
06-21-2008, 04:38 AM | #11 |
Member#: 110029
Sorry, multimeter or digital volt meter (DVM).
06-25-2008, 03:03 PM | #12 |
Member#: 114101
SCIC
Vehicle:93 Impreza L Swap |
I would connect them directly to the battery with an inline fuse and relay that is activated by the cig lighter or something. I wouldn't connect them to the cig lighter directly . The wiring on the cig lighter is TINY, like 18 gauge. I think the fuse for it is 30 amps, but I'd rather leave some room for error. Plus, what happens if you wanna use the cig lighter for something else? You'll draw even more current...
If you insist on not connecting them to the battery, the ignition harness is a good source. You'll see 4 thick wires under the gauge cluster that go to the ignition. Last edited by WReXd; 06-25-2008 at 03:09 PM. |
06-25-2008, 03:35 PM | #13 |
Member#: 120985
South East
i went and bought another relay.
when i get a break from work and school I'm going to wire it up. |
what head gasket did you use on your EJ22t hybrid? | 2.5rsDOHC | Built Motor Discussion | 18 | 09-13-2007 10:16 AM |
What did you pay for your used GC8? | adrive43 | Newbies & FAQs | 36 | 03-27-2005 03:23 AM |
what Gasket Thickness did you use in your turbo RS? | ChAi | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 07-06-2004 10:00 PM |
What winter mats are you using for your Imprezas? | essogas | General Community | 21 | 11-23-2003 06:17 PM |
