05-27-2005, 08:38 PM | #1 | |
Member#: 37716
TXIC
Vehicle:2002 ej257 Black WRX |
Confused on how to disconnect throttle cable..
I'm in the middle of doing a shortblock swap, so i'm disconnecting things to pull the motor out. I'm @ the part in the service manual where it says to disconnect the "acclerator cable", though, i can't figure how do so. I did a search, and this was the best answer i got.
Thanks for the help
05-27-2005, 09:38 PM | #2 |
Member#: 70234
Vehicle:MY86 BMW E30 325 SCIC/NWIC tranplant (-_-) |
The passenger side cable (cruise) is secured by a clip that you need to remove. IIRC, you pull the clip towards the front of the car and up. After the clip is removed, you should be able to push the cable up and out as you hold the full throttle position. The locking pin needs to be pushed towards driver side and up.
The driver side cable is removed the same but without the clip. |
05-27-2005, 11:46 PM | #3 |
Member#: 35585
Vehicle:RIP I'll always be The Ver8 Magistrate |
Same mechanism as a brake cable for a bike basicly.
05-28-2005, 04:12 PM | #4 |
Member#: 37716
TXIC
is there any description in the manuals how to do this, i'm still really confused...
I need a clear answer on how to disconnect my DRL's on my 07 WRX | jessetm | Newbies & FAQs | 5 | 11-04-2009 01:27 PM |
how to remove throttle accelerator cables from intake manifold? | anthonyrb98 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 07-03-2007 07:00 AM |
really need help with how to disconnect fuel pump relay on 05 RS | MrSaabaru | Normally Aspirated Powertrain | 2 | 08-06-2005 09:13 PM |
computer illiterateand am confused with how to actually to put a pic on here | slowstangguy | Newbies & FAQs | 4 | 01-24-2005 03:20 PM |
HELP!! How to disconnect E-Brake cable | dcgear | Brakes, Steering & Suspension | 3 | 12-20-2002 02:29 AM |
