05-17-2007, 12:29 PM | #1 |
Member#: 18914
South East
Vehicle:2006 WRX Black with some stuff |
Installing Deatschwerk 565's, will my car run at all before tune?
Hi,
I'm about to intall new Deatschwerk 565cc injectors on my 2005 Saabaru hybrid with VF39. My question is, will I be able to drive my car to the shop where I am getting the tune done after installing them, or will I have to have some parameters altered before I can drive it at all? Thanks, Carlos
05-17-2007, 12:33 PM | #2 |
Member#: 65065
Vehicle:2004 EJ205 STi 2007 Forester STi |
you will have a really rich condition if you dont tune it before you drive it. My car just had DW 650s installed and on the initial dyno run, the exhaust pipe looked like a diesel truck.
See if you can get a temporary tune for the bigger injectors emailed to you from the tuner to drive there with. |
05-17-2007, 12:34 PM | #3 |
Member#: 125739
South East
Vehicle:2007 1500HD Need Brakes? 919.420.0021 |
Carlos - we can help you...just let us put the injectors and turbo in as well
05-17-2007, 12:47 PM | #4 | |
Member#: 18914
South East
I'd rather go through the stress of intalling those parts, than the stress of having to spend one extra dollar. You just have no idea. The money coming in is once again pretty decent, but the amount going out is still Unforseen disasters suck!! Carlos |
05-17-2007, 03:12 PM | #5 |
Member#: 36576
Vehicle:2k2 WRB wrx WAGON 16G'd & FMIC'd |
I just did an injector and turbo install over the weekend (plus deleted the flappers in the TGV). Was quite time consuming, but worth it in the end (other than a few snafu's). I had already changed the injectors once before so thankfully I didn't have to deal with the GBOD's (never put them back on).
See if you can find someone with a tactrix cable to set the injector latency and scale. At least that way the car is driveable to get to the tuner. |
05-17-2007, 04:19 PM | #6 |
Member#: 53665
Vehicle:2022 BMW M240i Thundernight |
I would not risk running the car with larger injectors on a stock sized tune. Going from 420cc stock to 565 is a 35***37; increase in size. That will yield uber rich conditions. You'll max out the STFTs and will probably still not be close to the right values. CEL will follow and your car will hate you. This is an optimistic scenario. A bad one is that you experience cylinder wash before the ECU goes to max negative fuel trim and you seize the engine.
The risk is really not worth it. If you need to get to the pro shop, have your tuner send you a temp map with properly scaled injectors. This will all you to get to the shop safely so you can get tuned. You can risk it but if things go wrong, you'll hate yourself for it and it'll be too late at this point. Play it safe especially since it will not cost you extra money to do it. Good luck. |
05-17-2007, 04:22 PM | #7 |
Member#: 18914
South East
Thanks guys. I really appreciate everyone's advice.
I won't be attempting the drive with the new injectors without having a temp map. Carlos |
05-17-2007, 04:24 PM | #8 |
Member#: 94348
Vehicle:2oo2 StAge 2 WRX Silver |
f it start it up and let the turbo spool and dont look back lol....nah i have no input
Similar Threads | ||||
will my car even run? | dstnbmxvr6 | Newbies & FAQs | 8 | 04-23-2008 12:27 AM |
Will my car even run in CO at altitude? | mindchatter | Rocky Mountains Impreza Club Forum -- RMIC | 19 | 09-17-2006 10:06 AM |
how will my car run with if i unmarry my cobb AP??im running stage 2 now | SOCIOPATH | Engine Management & Tuning | 10 | 08-11-2006 10:35 AM |
Will my car run safely with this setup? | SlowPoke00 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 06-05-2005 11:56 PM |
