09-18-2009, 09:22 AM | #1 |
Member#: 201184
International
Vehicle:2001 WRX |
Short Shifter; Does it Affect Classing?
I have read the SCCA rules a few times, but am still unsure if a short shifter affects classing. All I can find related is this in ST and SP:
G. Any mechanical shift linkage may be used. This would be just the linkage and not the lever. So if I have short shifter I can still run in D stock, right? So long as the linkage hasn't been altered or changed. Thanks for your help!
09-18-2009, 09:31 AM | #2 | |
Member#: 442
Vehicle:17 Imp Spurt 00 S2k |
Only the Subaru short shifter is allowed, as it's a port installed option. (Page 262 in the 2009 rules):
--kC |
09-18-2009, 09:51 AM | #3 |
Member#: 201184
International
Vehicle:2001 WRX |
Well, that's too bad for me I guess. At least now I can feel better about classing myself in STU. I had people trying to put my car in D-stock because my car appears stock. My only mods are the shifter and de-badging.
Thanks for the quick answer. |
09-18-2009, 11:15 AM | #4 |
Member#: 65699
Vehicle:15 WRX WR Blue |
Running locally, I don't think one person would give a care if you ran DS. You could always ask your competitors.
09-18-2009, 11:47 AM | #5 |
Member#: 104922
Vehicle:2016 WRX |
I don't think anyone would care if you ran a short shifter in DS unless you start winning
09-18-2009, 12:59 PM | #6 | ||
Member#: 442
But you are "doing the right thing" by going to STU. --kC |
09-18-2009, 01:47 PM | #7 |
Member#: 44501
Vehicle:that 's, like, your alternate facts, man. |
The problem with asking your competitors is when someone else shows up at the last minute that you didn't ask.
Just run in STU.. get yourself some more camber and get some swaybars eventually. |
09-22-2009, 06:33 PM | #8 |
Member#: 201184
International
Vehicle:2001 WRX |
That's the plan, for now. I've decided that I'll continue to mod my car to my taste and if it bumps me into a different class; so be it. I don't intend to run at anything above local events anyway.
Similar Threads | ||||
Tint - How does it affect performance driving? | crashnscar | Interior & Exterior Modification | 19 | 07-30-2007 03:49 AM |
The fysics: compression ratio? How does it affect? | tonytiger | Normally Aspirated Powertrain | 10 | 01-16-2002 12:59 PM |
How does it affect Unichip programming? | redrex3 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 07-30-2001 10:08 PM |
CAT'S REMOVED - How does it affects the S-AFC readings/performance? | Mariano | Technical Forum Archive | 3 | 09-09-2000 12:21 AM |
