11-20-2000, 06:12 AM | #1 |
Member#: 2865
Vehicle:2006 Legacy 2.5i Wagon, 5MT, Blue |
Engine shudder/loss of power
I just returned from a trip to Vegas (from san diego). During that trip, my 97 Legacy GT (sedan) started acting up. When accelerating, I would experience a shuddering in the engine and dramatic loss of power between 1000-1500 rpms, but then the engine would seem to accelerate somewhat normally after that (sluggish but no shuddering). Small problem at first, but it has gotten worse. Any thoughts? I don't have any mods and I havent made in changes to the vehicle since I bought it.
11-21-2000, 12:10 AM | #2 |
Member#: 1425
Vehicle:2000 2.5RS Aspen White |
I've seen posts about knock sensors and loss of power followed by normal acceleration. Try doing s search on knock sensors.
11-20-2000, 04:54 PM | #3 |
Member#: 2865
Yeah that sounds like what I've got from what I've read. But, I'm confused on the fix. I read like 3 or 4 different fixes, none of which seemed like they were a 100% sure problem solver. I tried reseting ECU and that didnt work. Took it down to a dealer, they wanted $70 just to look at it. So I guess I'll try some of the stuff mentioned before heading their way. Thanks for the suggestion.
11-22-2000, 12:30 AM | #4 |
Member#: 1209
Hey there, if the problem is w/ the ECU (its not the knock sensor, its how the ECU over-reacts to the signal), then the ECU re-set should definitely work. I had the exact same problem, and it was between 1800 & 2500 rpms, like a giant hiccup in the engine.
What happens (and the Subaru TSB confirms this) is that the faulty ECUs (the Subaru TSB reccommended replacing the ECU, not the knock sensor) over-react to the Knock Sensor signal and retard your timing. The retarded timing gets stuck in memory. So technically, an ECU re-set should clear it out and performance, at least momentarily, should be better. If it isn't, then I'd also look into- Ignition wires, fuel filter, air filter, clogged PCV valve etc... and incidentally, I DID do the electronic fix (in line resistor, I believe) which mellows-out the signal from the piezoelectric mic on the knock sensor, and it works Great! [This message has been edited by gumball (edited November 21, 2000).] |
11-23-2000, 07:34 AM | #5 |
Member#: 2865
Ok, thanks for the extra info, I think I will be getting thinline filter. Everythiing els you had mentioned I checked right off the bat. Thanks again...
11-25-2000, 02:06 PM | #6 |
Member#: 2865
Ok, now the check engine light has come on. Normal with this ecu/knock sensor problem? Or would it be something else?
11-25-2000, 09:56 PM | #7 |
Member#: 135
Has your car been serviced recently? Check all of your plug wire connections to make sure that none are loose or off completely. Is your gas cap on tightly?
[This message has been edited by kelley nelson (edited November 25, 2000).] |
Similar Threads | ||||
'07 WRX violent shudder and loss of power to rear end - axle? diff? | DrnknZag | Transmission (AT/MT) & Driveline | 9 | 12-16-2009 11:35 PM |
loss of power within 3 weeks of purchase | KckAsX | South East Region Forum | 13 | 05-01-2002 04:13 PM |
Recent loss of power | Kachukaa | General Forum Archive | 0 | 01-15-2001 03:58 PM |
Loss of power with Unorthodox pulley | fellfrosch7 | Car Audio, Video & Security | 11 | 12-24-2000 10:09 PM |
Loss of power and engine shudder | SSLegacyGT | Legacy Forum | 12 | 11-23-2000 09:25 AM |
