12-25-2002, 04:29 PM | #1 |
Member#: 23536
Vehicle:2000 impreza rs blue ridge pearl |
I bought a pulley set
Like the title of the topic says, I bought a set of aluminum pulleys,
and the crank pulley is underdrive. The UD crank pulley weighs 1.2lbs, and both the power-steering and alternator pulleys are said to be .8lbs lighter. How much hp should I expect to gain from this? And wich CAI should I buy? The PRM(cobb) or the Injen?
12-25-2002, 07:39 PM | #2 |
Member#: 6637
Vehicle:2005 Subaru Outback |
HP gains? ~4hp...
Are the UD pulleys the same diameter as the stock? Have fun with the install |
12-25-2002, 09:22 PM | #3 |
Member#: 5885
Vehicle:2000 RS (GME) SilvAr |
Man, that alternator pulley was a doozie. After damaging the alternator housing with "the screwdriver trick," I gave up and took it to the dealer to finish job.
Be sure to reset the ECU, that helps. - Ken |
12-26-2002, 02:08 AM | #4 |
Member#: 23536
RHdude, an Under-drive pulley is smaller in diameter than an OEM or stock pulley. And I think you're a bit shy as far power improvements go, you say ~4hp, I'm thinkin' more like 10-12, but we'll see.
And to Dr.Ken, thanks for the tip |
12-26-2002, 08:35 AM | #5 | |
Member#: 6542
South East
Vehicle:1997 Ver IV silver |
12-26-2002, 11:01 AM | #6 |
Member#: 8257
Vehicle:2004 STI Silver\Silver |
You don’t actually gain any horsepower but rather you’re freeing up the energy that was used to move the additional mass of the pulley in a lightened pulley. 10-12 HP seems a little excessive doesn’t it? I would go for the Cobb intake but I may take a while to get it.
12-26-2002, 02:46 PM | #7 |
Member#: 6637
no way in hell you'd gain 10-12hp... UD claims 4hp.
I have heard you don't want a smaller pulley, but rather a stock size, but lighter. I believe the GFB's are like that.. As for intake, Cobb makes a very very good intake, but they are expensive and hard to get your hands on one. Ganzflow's style is very similar, cheaper, and usually easier to get. It's all up to you |
12-26-2002, 02:53 PM | #8 |
Member#: 23536
Ok, thanks you guys for lighting my candle
And I'm a positive guy, so let's deduct your 4hp from my 12, and we end up with ~8hp I'm the kind of guy who sees an ½full glass, not an ½empty one, happy new year to all of ya |
12-26-2002, 03:09 PM | #9 |
Member#: 6637
Get a FAT or SPO/AVO intake, they add like 80-100hp
12-26-2002, 03:20 PM | #10 |
Member#: 21085
W. Canada
Vehicle:2.5 rs-t |
80-100hp, i hope that you are just bein sarcastic. as far as the pully goes, i went with the unorthodox racing pully and it is smaller and i hate it. first of all i noticed nothin as for as hp goes, second, it takes power from the accessories to give you more power, so all i notice is everytime im at a light, all my lights dim until i give it gas. not good if your also into a big sterio
12-26-2002, 03:37 PM | #11 |
Member#: 6637
FAT and SPO/AVO are turbo kits
12-26-2002, 03:39 PM | #12 |
Member#: 21085
W. Canada
Vehicle:2.5 rs-t |
ohhhh
12-26-2002, 05:35 PM | #13 | |
Member#: 7101
Vehicle:00RS I want to fill your mouth with spiders |
12-26-2002, 07:59 PM | #14 |
Member#: 23536
Ok ok, so instead of writing that it "ads" hp to the engine, I should've said that it "frees" hp from the engine, since your 165 little ponies have to work less hard to do the same job, is that ok now? Can I go home now?
12-27-2002, 02:51 PM | #15 |
Member#: 11349
Vehicle:2016 Mustang GT Blue |
the GFB pulleys are all smaller. Alt, pwr steering, and crank. It says it's so it doesn't underdrive, but i experiance light dimming below 1k rpm. I don't mind at all though. I love them.
12-27-2002, 05:19 PM | #16 |
Member#: 23536
DJ, have you witnessed any change regarding re-acceleration???
I mean, if you lift up the the throttle and then pin it back, is there a slight improvement? |
12-27-2002, 09:08 PM | #17 |
Member#: 11349
yes, i really like it when i'm in 3rd rolling @ 3500rpm or more then nail it. It's alot better than stock.
12-28-2002, 07:02 PM | #18 | |
Member#: 16523
12-28-2002, 09:38 PM | #19 |
Member#: 11349
how do you explain my headlights dimming at idle? also, the power steering pulley is in fact smaller!
12-28-2002, 10:15 PM | #20 | |
Member#: 16523
Are you sure? J/k You must have a set I haven't seen before. The GFB's I've seen had the crank smaller with the Alt to match, but the PS was stock size so that was the only thing being underdriven. |
Similar Threads | ||||
I just bought a new set of inline skates | TimStevens | Off-Topic | 83 | 05-21-2009 12:36 PM |
how many MAICers bought themselves a set of re01rs? | nhat | Mid Atlantic Impreza Club -- MAIC | 266 | 03-18-2009 09:06 AM |
Yay!!!!!111! I just bought a new set of tires | Jard | Mid Atlantic Impreza Club -- MAIC | 8 | 04-27-2005 04:15 PM |
Just bought an xtra set of 05 BBSs on eBay | STiMUL8 | Tire & Wheel | 4 | 04-02-2005 03:29 PM |
N1 Lightened Pulley set of UR Underdrive crank pulley | CRAZY KEN | Normally Aspirated Powertrain | 12 | 10-05-2001 03:51 PM |
