Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 12-24-2012, 02:32 AM   #1
Btbadger
Member#: 341498
Default Check engine light on & cruise light flashing
I have a 06 WRX w/no mods, and today I got gas and about 10-15 min later my check engine light and my cruise control light came on simultaneously. The cruise light is flashing which is indicating the cruise control is deactivated according to the owners manual. As far as the check engine light goes it says in the manual that an emissions control issue has been detected BUT, also says if you have recently fueled up to make sure the gas cap is tight, which I have done. Drove the car more and the lights did not reset so I disconnected the battery to clear the computer. Drove the car for better than an hour, it runs just fine but the lights just came back on, PLEASE HELP !!! Thanks for any advice.
Btbadger is offline   Reply With Quote
Old 12-24-2012, 02:44 AM   #2
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
I think a CEL and flashing cruise means your car is in limp mode (someone confirm this), basically a failsafe fallback the ecu has when it thinks something has gone wrong that could damage the motor, it will limit revs and boost.
First don't disconnect the battery to clear the code, this only makes the warning go away it doesn't make the problem that is causing it go away. This is kinda like taking the batteries out of our smoke detectors in your house when they go off instead of putting out the fire.
Get a code reader, AP, tactrix and laptop or take it to a shop and have them read the code, then come make here with that info and we can help you better.
Good luck.
OUScooby is offline   Reply With Quote
Old 12-24-2012, 02:49 AM   #3
Btbadger
Member#: 341498
Thanks, I do know that it only clears the code. I thought from reading the owners manual about the gas cap possibly not being closed tightly, that that's what the issue was related to since it was right after I got gas and the car is still running fine as far as I can tell. I'll have to get in and have the codes pulled I guess. Hope it's not serious, especially right now at Christmas. :/
Old 12-24-2012, 02:55 AM   #4
RM_2
Member#: 163058
'20 WRX
'16 BRZ Limited
Just go to an Autozone/Advance Auto/Napa and get the codes pulled. I'm sure Uncle Scotty or someone else will tell you the same thing. There's not much we can do to help unless you know what the codes mean.
RM_2 is offline   Reply With Quote
Old 12-24-2012, 03:03 AM   #5
Btbadger
Member#: 341498
Alright, thanks. I was hoping someone had cone across this before. But yeah, I'll head to Autozone or NAPA and see what they come up with. Thanks again and Happy Holidays
Old 12-24-2012, 09:41 AM   #6
Fir3Fighter
Member#: 316780
2003 Impreza WRX
Keep us updated so we can try and help you out, hopefully its nothing serious. Have a good Christmas!
Fir3Fighter is offline   Reply With Quote
Old 12-24-2012, 09:46 AM   #7
mejifair
Member#: 11356
2012 WRX STi Hatch
In my 2012, those lights get triggered for a misfire, and don't go away until they are manually cleared. I would also recommend that you go somewhere to have them pull the codes and google what they mean.
mejifair is offline   Reply With Quote
Old 12-24-2012, 10:03 AM   #8
helli
Member#: 276215
2005 legacy gt
black pearl
Yea it's most likely some sort of misfire code currently have that problem and let me tell you it's hard to get to the bottom of it even knowing its a cylinder 2 misfire
helli is offline   Reply With Quote
Old 12-24-2012, 10:07 AM   #9
HinshawWRX
Medium Frank
Member#: 140114
2020 Subaru
Outback
You should try fixing the cause of the misfire. The CEL comes on for a reason.
OP when your CEL comes on we need to get the code (s) to help you. The list of codes that can be generated by a CEL are many and can mean different things. Being it was right after getting gas, it's likely a loose fuel cap.
For reference the cruise control is deactivated with a CEL to prevent damage to the vehicle.
Old 12-24-2012, 10:15 AM   #10
helli
Member#: 276215
2005 legacy gt
black pearl
Can u help my diagnose my cylinder 2 misfire issue ?? Spark plug n coil look fine no oil in the cylinder either also it idle when I tap the gas the Roma drop very low n then go back up
Old 12-24-2012, 10:18 AM   #11
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
http://forums.nasioc.com/forums/show...misfire+causes
Old 12-24-2012, 10:19 AM   #12
quazimoto
Member#: 70395
Old 12-24-2012, 10:22 AM   #13
helli
Member#: 276215
2005 legacy gt
black pearl
Thanks quazimoto!!!
Old 12-24-2012, 11:13 AM   #14
helli
Member#: 276215
2005 legacy gt
black pearl
How can I go about finding the coil pack where all 4 coils lead 2 maybe there's a issue there but I have no clue of where its located and what's needed to uncover it because I doubt it's exposed
Old 12-24-2012, 04:28 PM   #15
quazimoto
Member#: 70395
Spreak engrish...........
Old 12-24-2012, 06:53 PM   #16
Btbadger
Member#: 341498
The only code
Old 12-24-2012, 06:54 PM   #17
Btbadger
Member#: 341498
The code that was pulled is: P0011
Old 12-24-2012, 08:17 PM   #18
helli
Member#: 276215
2005 legacy gt
black pearl
Did they tell you what that code was
Old 12-24-2012, 08:18 PM   #19
helli
Member#: 276215
2005 legacy gt
black pearl
Each coil wire leads to 1 coil pack located somewhere on the engine bay but where
Old 12-24-2012, 08:37 PM   #20
aod12
Member#: 282701
2008 FXT
Something tells me you're better off taking it to a mechanic, you may be in over your head if you try to fix it yourself.
aod12 is offline   Reply With Quote
Old 12-24-2012, 10:35 PM   #21
Btbadger
Member#: 341498
The ECM code pulled was: P0011
Old 12-24-2012, 11:11 PM   #22
TwoFifty
Member#: 261764
2003 Impreza WRX
P0011 - "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
Sounds like you have a little diagnosing to do.
TwoFifty is offline   Reply With Quote
Old 12-24-2012, 11:29 PM   #23
Btbadger
Member#: 341498
Yeah and there was something about a blocked oil passage, low/dirty oil, timing belt mis alignment and something else I don't remember. I'm pretty sure it doesn't have to do with the timing belt as it runs just fine and doesn't seem to have lost any power. Oil level is a bit low, prob less than 1qt, but it is a bit dirty as I drive it like I stole it except for in Portland city traffic. So I think I'll start with a oil change since that's the easiest and cheapest way to start figuring it out.
Old 12-25-2012, 06:19 PM   #24
helli
Member#: 276215
2005 legacy gt
black pearl
How am I over my head because I ask a simple question like where is the coil pack location not the independent ones are but where the pack that all 4 wires lead to ????? Excuse me if I'm wrong but I honestly could just take an extra 20 min to find it just thought there would b someone on here with experience !!!!!that doesn't say take it to a mechanic over a coil pack lol wow smh......
Old 12-25-2012, 10:02 PM   #25
mejifair
Member#: 11356
2012 WRX STi Hatch
Ha thanks - I should have completed the story. I took it to the dealer and there was an ECM flash that had been made available to fix the misfire issue.
