01-06-2011, 04:12 PM | #26 | |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
Darton makes three different sleeves for EJ, so having various finished cylinder wall thicknesses can already be done.
01-06-2011, 04:22 PM | #27 | |
Member#: 149114
1. dropped sleeves 2. cooling issues at track #1 has seem to be debunked with proper maching, #2 i would assume because the sleeve is much bigger and reduces the coolant passages a bit too plus is thicker |
01-06-2011, 07:06 PM | #28 |
Member#: 33782
dropped sleeves are from poor work and/or from overheating the block.
what cooling issues are you talking about?...you haven't said anything other than 'cooling issues'. The sleeve doesn't block coolant passages. |
01-06-2011, 07:08 PM | #29 |
Member#: 106909
Vehicle:2002 V7 STi Prodrive Edition... Black! |
Well hopefully my pinned stock block will hold on to a GT35R
01-06-2011, 11:10 PM | #30 |
Member#: 263724
Vehicle:07 Subaru WRX STi |
Are T sleeves good?
01-06-2011, 11:55 PM | #31 |
Member#: 149114
01-07-2011, 10:37 AM | #32 |
Member#: 33782
01-07-2011, 10:53 AM | #33 |
Member#: 9548
RMIC
Vehicle:2004 WRX STi 10.154 @139 @ 7,000'DA |
maybe sleeved blocks are pushed harder, thus more heat, thus more chance of overheating.
01-07-2011, 10:56 AM | #34 |
Member#: 33782
I actually meant to state that as a point but forgot
after all, they are sleeved for a reason. more power = more heat |
01-07-2011, 01:08 PM | #35 |
Member#: 149114
hmmm gotcha
01-07-2011, 01:41 PM | #36 | |
Member#: 159743
Vehicle:07 STI Limited TurboMike Tuned 2.35 |
So something like this? i suck at posting pictures so it may need to be edited :-p |
01-07-2011, 02:07 PM | #37 |
Member#: 263724
^ does this really work for high boost apps? I'm building my block turning it into a 2.7 but worried about the cylinders cracking on me since il be boring them out to 100mm.
The power I expect from this build is around 420whp to 460. Another thing Is that I'd sleeve it but the heat transfer isn't that great. Do they make aluminum sleeves rather then iron? |
01-07-2011, 02:07 PM | #38 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
Why do people say iron sleeve blocks are not good for daily driving?
01-07-2011, 02:18 PM | #39 |
Member#: 159743
yes thats good for high boost its alot thicker then the standard wall was and this specific one will be running 25psi+ on a dom4 Xt-r All day in S# mode. Just something to keep in mind is when you get that done, make sure to deck your heads. so w/e that equates to which will be more then your requirements.
01-07-2011, 02:18 PM | #40 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
01-07-2011, 02:31 PM | #41 |
Member#: 133146
if that one is the only reason... there should not be a reason for not getting the motor sleeved other than cost.
What material pistons and size would some one choose to run a sleeve motor reliably, keeping longevity as the main focus? links? There is EVOs on the stock pistons running about 400whp for 200K miles |
01-07-2011, 02:36 PM | #42 |
Member#: 159743
you can bore that specific sleeve from 99.5 to 102mm. so you have some gap if you blow somethign up. I like it cause it gives me a brand new start and i can setup the PW clearance perfect every time. I was sick of worrying about the sleeves cracking, pw clearances off cause the block was so worn. It personally hurts when i spend hours balancing everything to .1 gram doing clearances on all the bearings, then there is a soft spot on a cylinder wall and I have to start all over.
01-07-2011, 02:46 PM | #43 | ||
Member#: 33782
you beat me to it. I was just going to say iron block Quote:
01-07-2011, 03:02 PM | #44 | ||
Member#: 133146
If found this on the STI forums Quote:
01-07-2011, 05:19 PM | #45 |
Member#: 33782
well keep in mind that most of the failures you see here are rod bearing failures, which can be from numerous slings.
Bad oil (loose term), dirty build, poor clearances, out-right abuse... At 50k, I'd go through an EJ that gets pushed simply to inspect, do rings and bearings. |
03-16-2011, 10:05 AM | #46 |
Member#: 237759
TXIC
Vehicle:2003 WRX Wagon Built ej205 478whp 417wtq |
Not needed. Think about it. How much oil is coating your internals while your motor is running? Well its not even to within .1 gram I can tell you that.
About pinning, Ill be pinning the sleeves on one of the ej205 block I have lying around sometime in the next week. Ill post pics as soon as its done. |
03-16-2011, 10:35 AM | #47 |
Member#: 33782
03-16-2011, 03:37 PM | #48 |
Member#: 77470
Vehicle:04 sti 10.41@141 on e85@ 30psi--spinning |
^^Micah that is not a step sleeve,that is the first option sleeve in dartons catalog.To go 102mm you have to purchase the big t sleeve from darton and then have a good shop like MPS send it out to benson to have it done.
03-16-2011, 03:42 PM | #49 |
Member#: 77470
To your ? juan,no it may or may not last longer but the reason for sleeving is to run more boost which = more power,more heat and more cylinder pressure.So if your goal is huge power sleeving, if done right, will theoretically allow the sleeved motor to have a better chance at a longer life granted all the other systems(oiling) are up to the task.I hope this helps juan.
03-16-2011, 03:54 PM | #50 | |
Member#: 33782
I was asking as it looks like a run of the mill industrial/cast iron block straight sleeve. Even smaller Darton sleeves are still stepped. |
Junior's 2.5RS Built motor.. Pinned mains/sleeves/orings everything! | Junior2JZ | Built Motor Discussion | 1413 | 12-28-2018 02:10 AM |
Final Step in my EJ257 build..."To sleeve or not to sleeve?" | Wrx_Fan_0717 | Built Motor Discussion | 36 | 07-14-2010 04:36 PM |
pinning and sleeveing a block | z/ssti | Built Motor Discussion | 38 | 04-05-2010 11:59 AM |
04 sti ej257, darton sleeves, 03 ej20 | suby1man03 | Engine/Power/Exhaust | 26 | 11-26-2009 06:07 PM |
pics of sleeved ej257 by magnus? | deadred | Proven Power Bragging | 7 | 05-24-2005 02:55 PM |
